Magnetic field from stream of protons
A stream of protons moving in one direction induces a magnetic field, similar to the effect observed with electrons. The right-hand rule applies to both cases, indicating that the direction of the magnetic field is determined by the direction of the current flow. Therefore, if protons flow from left to right, the induced magnetic field will have a specific configuration that mirrors that of electrons moving in the same direction. The discussion clarifies that the left-hand rule is not applicable in this context.
  • Understanding of electromagnetic theory
  • Familiarity with the right-hand rule in physics
  • Knowledge of particle physics, specifically protons and electrons
  • Basic concepts of magnetic fields and current flow
  • Study the right-hand rule in electromagnetic theory
  • Research the properties of magnetic fields generated by charged particles
  • Explore the differences between electron and proton behavior in magnetic fields
  • Investigate applications of magnetic fields in particle physics experiments
Physics students, educators, and professionals in the field of electromagnetism or particle physics will benefit from this discussion, particularly those interested in the behavior of charged particles and their magnetic interactions.
rrosenthal
Quick question. With electric current flow thru wire, the "right hand" rule indicates direction and position of the induced magnetic field. With a flow of protons in one direction, would a magnetic field be induced, and would a "left hand" rule be appropriate to describe this magnetic field ?------------Randall Rosenthal
If protons are moving to the left, which way is the current flowing?
rather than get caught up in semantics, let me rephrase the question. A stream of electrons moving from left to right induces a magnetic field in a specific configeration. Would a stream of protons--also moving from left to right--also induce a magnetic field and would this be of opposite or mirror image configaration--??---r rosenthal
  • · Replies 42 ·
