DC Lighting Control - Power 3 LED Strips
The discussion focuses on powering three LED strips using a 12V DC source while allowing for simultaneous operation, blinking patterns, or complete shutdown. The user explored using 555 timers but determined they are inadequate for handling the required current. The recommended solution involves using a 555 timer to control a transistor or relay, which can effectively manage the power to the LED strips without exceeding the timer's current limitations.
  • Understanding of 555 timer circuits
  • Knowledge of transistor and relay operation
  • Basic principles of LED strip wiring
  • Familiarity with DC power sources
  • Research how to use a 555 timer to control a transistor for LED applications
  • Learn about different types of relays suitable for LED strip control
  • Explore LED strip power requirements and current ratings
  • Investigate circuit protection methods for LED strips
Electronics hobbyists, DIY enthusiasts, and anyone interested in controlling LED lighting systems efficiently and cost-effectively.
striker21
I currently have available a 12V DC source and from that I want to power 3 LED strips but I want to be able to either have them all on at the same time, blink the strips in a pattern, or have them off. I have done some research into 555 timers but it looks like they won't be able to handle the current. I'm looking for some ideas on how I can implement this simply and keep it on the cheap side.
use the 555 timer to drive a transistor or relay instead of directly driving the LEDs.
  • · Replies 17 ·
