Vector diagram - particle collision
The discussion revolves around a vector diagram related to a particle collision, with participants attempting to determine the correct representation of momentum before and after the collision. The context appears to involve classical mechanics, though some participants speculate about quantum mechanics.
  • Mixed
  • Participants explore the conservation of momentum and question which diagram accurately represents this principle. There is a debate about whether the problem is framed within classical or quantum mechanics, with some suggesting that classical mechanics may not apply.
Multiple interpretations of the problem are being explored, with some participants providing guidance on the conservation of momentum. There is an ongoing examination of the assumptions regarding the nature of the question and the definitions of the variables involved.
Some participants express confusion about the distinction between momenta and velocities, indicating a potential misunderstanding of the problem's setup. The discussion also touches on the head-to-tail rule for vector addition, which some believe could be a useful approach.
jsmith613
see attached image
So I know as it is a VECTOR diagram it must either be B or C
So I checked that 1, 2, 3, 4 all pointed in the correct directions and they do in both diagrams.
I chose B (but at random) and the answer was C.
Why is the answer C?
thanks
Hi jsmith! :smile:
Use the conservation of momentum, this tells you the initial total momentum should be equal to the final total momentum. In which of the options, do you see this??
jsmith613 said:
see attached image
thanks
First of all, is this supposed to be a Classical Mechanics question or a Quantum mechanics question? Because if it is Classical mechanics, then the question is impossible. But in Quantum mechanics, it is possible.
? classical mechanism
why is it impossibel?
I'm assuming the mass is constant?
Infinitum said:
Hi jsmith! :smile:
momentum is consereved in B??
How is momentum conserved in B :confused:
resultant momentum of both is in the same direciton, no?
In classical mechanics, you have ##m_1v_{1i}+m_2v_{2i}=m_1v_{1f}+m_2v_{2f}## but that does not hold in the question, so I think it is a Quantum mechanics question...
Uh nope, it isn't. And you can't be sure about the direction in B as the exact magnitude and direction of original aren't given.
Also, direction isn't the only necessary factor. The magnitude remains same too. Observe C carefully.
I just reaslied that i have to apply head-to-tail rule
if I apply this it ALWAYS works for ALL questions that have bothered me in the past
I believe classical mechanics does hold in the question...
Yes! That's it! :smile:
Then I don't think I understood the question properly. What I understand of it is:
$$v_{1i}=1$$
$$v_{2i}=2$$
$$v_{1f}=3$$
$$v_{2f}=4$$
$$m_1,m_2=\mbox{Constant}$$
$$v_{1i}=1$$
$$v_{2i}=2$$
$$v_{1f}=3$$
$$v_{2f}=4$$
You didn't read the question properly o:)
1, 2, 3, 4 are the momenta before and after collision, not the velocities.
Oh! I didn't see that!
  • · Replies 22 ·
  • · Replies 23 ·
