How are Tranverse Magnetic and Transverse Electric Polarisations defined?
Transverse Magnetic (TM), Transverse Electric (TE), and Transverse Electro-Magnetic (TEM) polarizations are defined in relation to cylindrical wave guides, where the cylinder can have any cross-section. TM modes have no magnetic field component along the cylinder axis, while TE modes have no electric field component along the cylinder axis. TEM modes, which require a non-simply connected cross-section, exhibit both electric and magnetic fields with no components along the cylinder axis. TEM modes are advantageous as they allow for undisturbed signal propagation without dispersion in ideally conducting wave guides.
  • Understanding of Maxwell's equations
  • Familiarity with electromagnetic field theory
  • Knowledge of wave guide structures
  • Concept of dispersion in signal propagation
  • Study the derivation of eigenmodes in cylindrical wave guides
  • Explore the implications of dispersion in electromagnetic wave propagation
  • Learn about the design and applications of coaxial cables
  • Investigate the boundary conditions for electromagnetic fields in wave guides
Electrical engineers, physicists, and students studying electromagnetic theory, particularly those focusing on wave guide technology and signal propagation.
StephanJ
I've seen this terminology being used a few times and knowing what it means exactly would be great. I gather that it's used to define Polarisations relative to a plane?
Any help would be great.
The terminology usually applies for cylindrical wave guides, where the cylinder can have any cross section, not only a circular one. One can prove from Maxwell's equations and the appropriate boundary conditions for the fields that each em. field can be expanded in a set of three types of eigenmodes that are
transverse electric (TE): The electric field has no component in direction of the cylinder axis,
transverse magnetic (TM): The magnetic field has no component in direction of the cylinder axis,
transverse electro-magnetic (TEM): both the electric and the magnetic field have no component in direction of the cylinder axis.
So, transverse is meant with respect to the cylinder axis. The TEM modes only exist if the cross section of the cylinder is not simply connected. A typical example is the usual caxial cable. These modes are particularly nice since they show no dispersion (in an ideally conducting wave guide), i.e., they admit an undistrubed signal propagation along the wave guide.
  • · Replies 42 ·
