Heat Capacity and Entropy Textbook Definition - Quick Question
The discussion revolves around the definitions and relationships of heat capacity at constant pressure (C_p) and constant volume (C_V), particularly focusing on the derivation and implications of the equations involving heat (Q), temperature (T), and entropy (S). Participants explore the conditions under which these definitions hold, the role of reversible processes, and the distinctions between internal energy (U) and enthalpy (H).
  • One participant questions the validity of the equation C_p = T(∂S/∂T)_p, suggesting it should only apply to C_V due to the conditions of reversible processes.
  • Another participant argues that the definitions of C_p and C_V are derived from different thermodynamic potentials, specifically noting that C_p is related to enthalpy (H) while C_V is related to internal energy (U).
  • A participant emphasizes that the equation dQ = TdS applies only to reversible processes, which raises concerns about applying it to C_p where volume is not constant.
  • Some participants clarify that C_p is determined by reversible processes, and they provide mathematical derivations to support this claim.
  • There is a discussion about the implications of irreversible processes on the definitions of heat capacity, with one participant introducing a hypothetical scenario involving kinetic friction in a Carnot engine.
Participants express differing views on the applicability of certain equations to C_p and C_V, with no consensus reached on the implications of irreversible processes. Some agree on the definitions and derivations, while others challenge the assumptions made in the reasoning.
Participants note that the definitions of specific heat and entropy depend on the conditions of the processes being considered, particularly emphasizing the distinction between reversible and irreversible processes. There are unresolved questions regarding the impact of kinetic friction on thermodynamic cycles.
weeksy
Just a quick question of something I found in my textbook but can't get how they produced it.
C_p =(∂Q/∂T)_p
that is the definition of heat capacity at a constant pressure p. Q is heat and T is temperature. This equation is fine and I know how to derive it. Now it is the next line which worries me.
C_p=(∂Q/∂T)_p = T(∂S/∂T)_p
where S is the entropy
why this bothers me is that this equation as I understand should only hold for C_V (heat capacity with constant volume)
thats because dQ=TdS for a REVERSE-ABLE ONLY expansion (i.e dQ=0 , dS=0) ie adiabatic all of which occur as V, the volume is held constant for C_V. Hence dU=dQ and dQ(rev)=TdS = dU , which can then be simply substituted into the definition. OK
Sorry for the spiel, but my question is how can this same line of reasoning be true for C_p where dV is not constant and dU is not equal to dQ and expansion isn't reversible?
Thanks
I think you are confusing U and H, have another look at your textbook.
The partial differential expressions you give for Cp are correct, but they are obtained by substituting Tds into the definition of H not U.
Similar partials can be derived for Cv by substituting Tds into the definition of U.
C_p =(∂Q/∂T)_p
The definition of specific heat, C, under any condition is:
C= ∂Q/∂T
The definition of S, under any condition is:
dQ=TdS
where Q is the heat energy being transferred.
So regardless of whether the process is isobaric or isovolumeteric,
C= T(∂S/∂T)
Thanks
You have made an incorrect hypothesis. The definition of specific heat, C, is not:
C= (∂U/∂T)
where U is the internal energy. The definition of specific heat is:
C= (∂Q/∂T)
One can easily prove that:
C_V= (∂U/∂T)_V
C_P= (∂H/∂T)_P
where H is the enthalpy, not the internal energy. Your logic worked
for C_V, but it didn't work for C_P because of the incorrect hypothesis.
C_p =(∂Q/∂T)_p
Your question is why:
[tex]C_p=\left(\frac{\partial{Q}}{\partial{T}}\right)_p = \left(\frac{\partial{Q_{rev}}}{\partial{T}}\right)_p[/tex]
The answer is that it is implicit in the left side that Q is Qrev. Cp is determined by a reversible process:
Cp = dQ/dT = dU/dT + dW/dT
Now if dW = PdV and if P is constant,
Cp = dU/dT + PdV/dT = Cv + PdV/dT = Cv + P(RdT/P)dT = Cv+R
But dW = PdV ONLY in a quasi-static process.
AM
Ok very good Andrew, makes sense though seems a rather large implication that C_p is determined by a reversible process only. Oh and Darwin as I understand it entropy S is not defined by dQ=TdS for all conditions but dQ(rev)=TdS where (res) is for a reversible process only. Huge difference.
Thanks for the fast responses, I have an exam next week where I have to use that substitution and am much happier now I know where It comes from. Thanks again
I'm new to this forum, is there some sort of thanks button / points system to show appreciation ?
your 100% right.
dH=dU+pdV
=TdS-pdV+pdV+Vdp
=TdS+Vdp
since dQ(rev)=TdS
dH=dQ(rev) at at constant pressure
since C_p=∂Q/∂T we have
C_p=T(∂S/∂T)
awesome
thanks a bunch
The fact that you have come back to the thread to let us know how you got on is great, keep it up.
It is quite dispiriting if you put in a deal of effort to write something and you never hear further. Others have put in more the I have here.
go well
:approve:
weeksy said:
your 100% right.
dH=dU+pdV
=TdS-pdV+pdV+Vdp
=TdS+Vdp
You seem to be missing a step at the beginning. Start with:
H = U + PV
dH = dU + PdV + VdP
For constant pressure dP = 0 so:
dH = dU + PdV = dQrev (first law, substituting PdV for ∂W).
Since dQrev = TdS by definition (ie dS = dQrev/T), then
[tex]\left(\frac{\partial H}{\partial T}\right)_P = \left(\frac{T\partial S}{\partial T}\right)_P = \left(\frac{\partial Q_{rev}}{\partial T}\right)_P = C_p[/tex]
Similarly, since
dU = TdS - PdV , for a constant volume process (dV = 0):
[tex]\left(\frac{\partial U}{\partial T}\right)_V = \left(\frac{T\partial S}{\partial T}\right)_V = \left(\frac{\partial Q_{rev}}{\partial T}\right)_V = C_V[/tex]AM
This hypothesis is not valid for conditions under which the process is irreversible. Once example would be if a Carnot engine where modified by having kinetic friction between the movable piston and the cylinder. I would call this the "the rusty Carnot problem".
This probably won't appear on any test. However, I am now interested for its
own sake. I am curious how one would take into account kinetic friction. I think I have an idea, but I am not sure. I also wonder if a solution to "the rusty Carnot problem"
could be published anywhere.
The work done by the rusty Carnot would include the friction. There would be no change the efficiency of the engine if you include that friction as part of the output.
The Carnot cycle is reversible in the sense that if you were able to store the output mechanical work you could reverse the heat flow and restore the original state of the reservoirs using that stored energy. So in the forward Carnot engine cycle if the output work was used to lift a weight, you could then lower that weight to reverse the direction of the cycle so that it acts as a Carnot refrigerator and flow all that heat back to the hot reservoir.
AM
