Force between magnet and metal
  • Context: Undergrad
  • Thread starter Thread starter McSquirrel
    Force Magnet Metal
The discussion focuses on calculating the attractive force between a cylindrical magnet and a sheet of iron. It highlights that while equations exist for the force between two magnets, similar calculations for non-magnetized materials require understanding the magnetic flux density (B) in the gap between the magnet and the metal. The flux density approaches \mu_{0}M, where M is the magnetization density of the magnet. For precise calculations, the use of the Maxwell stress tensor is essential to determine the total force on the object.
  • Understanding of magnetic flux density (B)
  • Familiarity with magnetization density (M)
  • Knowledge of Maxwell stress tensor
  • Basic principles of magnetism and magnetic forces
  • Research numerical methods for calculating magnetic flux density in gaps
  • Study the application of the Maxwell stress tensor in magnetic force calculations
  • Explore resources on magnetization density and its effects on magnetic interactions
  • Investigate the equations for force between magnetized surfaces
Physicists, engineers, and students involved in magnetism studies, as well as anyone interested in calculating magnetic forces between magnets and non-magnetized materials.
McSquirrel
Hello,
I am trying to calculate the magnitude of the attractive force between a cylindrical magnet and a sheet of iron. A bit of searching found some equations that can be used to calculate the force between two magnets but I could not find anything related to magnetic force on non magnetized materials. I can't link them as this is my first post but searching wikipedia for "force between two magnets" will yield them.
Can you use a similar equation to find the force between a magnet and a metal?
For nearby magnetized surfaces, the equation is given in the same Wiki page. But you need to calculate B in the gap between the two surfaces which usually requires numerical methods. When a magnet is brought very close to an iron sheet, the flux density B approaches [itex]\mu_{0}M[/itex] where M is the magnetization density of the magnet which is constant.
For an accurate calculation of the force for arbitrary shape and distance, you need to find the B distribution in the air region and use Maxwell stress tensor to calculate the total force on the object. see this page: http://www.fieldp.com/documents/stresstensor.pdf
That is quite helpful. Thank you Hassan!
