UV light absorption by transparent sheets – how?
The discussion revolves around the mechanisms of UV light absorption by transparent materials, particularly polycarbonate sheets and other plastics. Participants explore the underlying physics of how these materials can absorb a wide spectrum of UV light, questioning the electron frequency models typically used to explain absorption phenomena.
  • One participant questions how polycarbonate sheets can absorb all UV wavelengths if absorption is based on specific electron frequencies, suggesting that there must be a different mechanism at play.
  • Another participant challenges this assumption, proposing that the band structure of polycarbonate may have resonances that account for UV absorption.
  • A participant speculates that if a polycarbonate sheet absorbs all UV light, it implies a lack of electron frequencies in the relevant range, which seems unlikely given the number of possible frequencies.
  • One participant notes that the actual absorption spectra are more complex than simple models suggest, mentioning that absorption can occur over a continuum of energies in solids.
  • There is a discussion about misconceptions regarding energy levels in solids, with a focus on the broad band nature of absorption in condensed media compared to gases.
  • A participant expresses a desire for peer-reviewed sources that provide detailed information on UV absorption in polycarbonate, indicating a need for reliable data beyond marketing claims.
Participants do not reach a consensus on the mechanisms of UV absorption in polycarbonate sheets. Multiple competing views are presented regarding the nature of electron interactions and the complexity of absorption spectra.
Participants acknowledge limitations in their understanding and express a need for further reading and research on the topic. There are references to the complexity of absorption mechanisms that are not fully resolved in the discussion.
karen_lorr
Ok thanks for the responses to my other question; I think I now have it.
I have a follow up question – that is almost on the same topic (but not quite)
The complete spectrum (arund 200nm to 380nm) of UV light is absorbed by some plastics??
Elections will be moved to a more energetic orbital when absorbing photons with the same frequency, any wavelengths with non similar frequency with be emitted (e.g. red flower) or transmitted (e.g. glass). Water doesn’t use this electron reflection/absorption as it “just happens” to have the same frequency in the hydrogen bond that will absorb a portion of the lower (red) end of the spectrum.
This is all well and good UNTIL I got to thinking about something like a clear polycarbonate sheet.
If absorption is due to specific frequency of electron vibration – how can a polycarbonate sheet (or most types of glass and lots of other “stuff” for the matter) absorb virtually all wavelengths between around 200nm to 380nm. (UV a,b and c)
Surely there must be something else going on.
How does a polycarbonate sheet (e.g. sunglass lens) absorb ALL ultraviolet light. It must be a different process as I don’t think there that many electron frequencies. I have looked on google for many days and there are many descriptions of the results but I can't find one that gives a complete (physics) reason.
Thank youLoL – this all follows on a from a discussion my family were having regarding the colour of beer and as I kept digging deeper and deeper more question seem to appear. I hope you all don’t mind me asking such (what must be to you) simple questions.
Science news on Phys.org
Why do you believe it has to be a different mechanism?
What's wrong with the band structure of a polycarbonate sheet having resonances for UV?
Well I “assume” that there is a similar process taking place for most reasonably similar wavelengths.
May be totally wrong about that.
Say you have a blue ball. It has absorbed all wavelengths other than (for example) 470nm as there are no electron frequencies of 6.3786e+14 (well that’s what my calculator says it should be :-). For a polycarbonate sheet to use the same process it would mean that there were "no" (not one) electrons with frequencies of between 1.4990e+15 and 7.8893e+14 (200nm to 380nm) - I have not included VUV in this.
Now I may not have a big enough calculator (and I am not a statistician) but let’s just say that between 1.4990e+15 and 7.8893e+14 there are a “lot” of possible frequencies. Surely there would be a least a few electrons with the same – there must be?. Would this not lead to some transmittance. But it is claimed that aren’t.
Hmmm OK.
In contrast - the actual spectra is more complicated than they show. eg.
... see how the transmission bottoms out at short wavelengths? Remember that short wavelengths = higher energy.
Above a certain energy the energy band is basically a continuum in solids so you get a whole chunk being absorbed like that.
Get to a higher energy and different processes start to dominate - at very high energy you have matter and that just punches holes in things.
[/I]
This is a common misconception about what happens in condensed media (solids, for instance). It is much too simplistic a picture of what goes on to talk of orbitals and levels. In solids, there is not a set of quantised energy levels but a whole band of energies that electrons occupy. All the atoms in the vicinity of a given atom contribute to the energy of the outer electrons.
Colour due to absorption in pigments tends to be very broad band and not like the pictures of absorption lines in gases (which you see in textbooks).
Thanks for that.
I need to do some more reading :redface:
I have found this on wiki but (as you can see) it does not go down far enough.
http://en.wikipedia.org/wiki/File:Polycarbonate_IR_transmission.png
Does anyone have a link to a (peer reviewed) paper with the same info but going down into the UV area
I say peer reviewed to keep away from the vast amount of rubbish put out by sun glass makers ?
Thank you
karen_lorr said:
Thanks for that.
Don't worry. We all need to do more reading on lots of stuff. There's no end to it. ;-)
9K
10K
  • · Replies 207 ·
16K
