Making a box to always fall on the same side
  • Context: Undergrad
  • Thread starter Thread starter abcrwes
    Box Fall
The discussion centers around the design of a cuboid box that can be engineered to always land on a preferred side when dropped, exploring the effects of mass distribution, air resistance, and stability during free fall. Participants consider both theoretical and practical aspects of this problem, including the influence of shape and material properties.
  • One participant suggests that adding non-uniform mass to one side of the box could help position the center of gravity favorably, potentially ensuring it lands on that side when dropped from a sufficient height.
  • Another participant notes that the height of the drop is crucial, as dropping from a low height may not allow the box to stabilize in the desired orientation.
  • A question is raised about whether evenly distributed mass would still allow the box to land on a specific side, with the understanding that a lower center of gravity might not guarantee stability when dropped horizontally.
  • Concerns are expressed regarding the role of air resistance and how it may affect the orientation of the box during free fall, particularly in comparison to a shuttlecock.
  • One participant acknowledges a misunderstanding about the forces acting on the box during free fall, emphasizing that a heavier mass would result in a fall closer to gravitational acceleration.
  • Another participant reiterates that a design with one heavy side could help achieve the desired orientation quickly, while also suggesting that increasing air resistance could aid in reaching equilibrium velocity.
Participants generally agree on the importance of mass distribution and air resistance in determining how the box will land, but there are competing views on the effectiveness of different designs and the implications of the equivalence principle. The discussion remains unresolved regarding the optimal design parameters.
Participants express uncertainty about the effects of mass distribution on stability and the role of air resistance in achieving the desired orientation. There are also unresolved questions about the specific dimensions and materials that would best facilitate the intended behavior of the box.
abcrwes
Say I have a cuboid box (eg 120 * 60 * 10cm (lbh)). Is there a way I can add non-uniform mass to it to force the center of gravity on a preferred point (eg making one half heavier than other) - and then when I drop it horizontally or vertically, it always touches the ground at same side (but may be different edges)?
Eg: A shuttle cock always falls down on its heavier side. I understand aero-dynamics are involved. I want to know if the same can be done for a box. The box may also have non-uniform thickness or smoothened edges if that would force a solution. Thanks.
Assuming the height is sufficient to reach the equilibrium velocity*, adding enough mass to the preferred side (and making the other parts very light) should work. It might be quite unstable if 10cm are the "height".
*the shuttle cock has a high air resistance and reaches this quite fast. If you drop it from 1-2cm above the ground, it will not always land on the right side. With 1m, it does.
Thank you for your reply. Wanted to confirm this:
The height from which the object will be dropped is 1m.
1) Will this happen even if the mass is distributed evenly? Eg: I may choose to distribute it such that the mass rises upto 2 cm or I may also distribute it unevenly such that it rises to 5cm on one side and 1 cm on the other.
My understanding - If the mass is distributed evenly, the center of gravity will still be in the center (but may be located lower or higher depending on which side is facing the ground). In that case, the object may not be unstable when dropped from a horizontal position (0 degrees)
2) Is there a way to design such that equilibrium velocity will be obtained quickly?
Basically my intention is to design a very small box container (around 120 * 60 * 15mm) that can hold upto 200g mass, and will not get damaged when dropped. I plan to keep a soft material on just one side with the objective that, the object when dropped will always hit at that side.
Doesn't the shuttlecock orient itself because the air resistance on the feathers is different than on the tip? If you create a weight distribution *inside* of an otherwise symmetrical box, you have not created any difference in air resistance between light side and heavy side. With equal air resistance (dictated by shape of box), light side and heavy side fall at same rate right? (equivalence principal).
I agree on the equivalence principal. But wanted to check what would be the scenario if an object is unstable when held horizontally. Will it try to get into a stable position even when falling down in motion?
Just realized that I got this *dead wrong*.
The acceleration of a box subject to some wind resistance force (f) will be:
a = g - f/m
The bigger its mass, the closer its free fall is to g.
A bowling ball size rubber ball could be held aloft using a leaf blower (large f). An actual bowling ball would come crashing right down.
In this case, it will usually tend to get a small front area (~60mm x 15mm with the dimensions of post 3, not very stable). Opposite sides are perfectly symmetric.
Make the object light and with a lot of air resistance.
However, one heavy side (the one which should be the bottom) will help to reach the correct orientation quickly.
  • · Replies 30 ·
10K
  • · Replies 17 ·
  • · Replies 32 ·
