How does light lose energy as it travels over distance?
  • Thread starter Thread starter scijeebus
    Energy Light
Light appears to lose energy as it travels due to the expansion of the universe, which stretches its wavelength and reduces its frequency. This phenomenon, known as redshift, raises questions about where the energy of these photons goes. Some argue that energy isn't lost but rather that our observations change based on distance and the Doppler effect. Others suggest that energy dissipation occurs through interactions with the medium or topological irregularities. Ultimately, the discussion highlights the complexities of energy conservation in an expanding universe and the need for further exploration of these concepts.
scijeebus
How does light "lose" energy as it travels over distance?
So the universe is said to be expanding because light's wavelength is spreading out at a greater rate per greater distance, but with the wavelength becomes longer, the energy becomes smaller, so where is that energy going? How is it actually being lost?
Science news on Phys.org
I don't think energy is being lost I think our observations of it become different. For instance when moving closer to a light source
the light becomes stronger and the frequency we observe becomes larger. The inverse happens when we move further away from
the light source. The doppler effect makes it seem like the light is changing frequency.
Sorry Gary. This is wrong. Intensity changes with distance. Energy of photons doesn't.
The question remains: where does (did) the energy of a cosmologically redshifted photon go?
If you get on a train moving very fast and look behind you the light is also redshifted. Where did the energy go in this easier case?
It's just dissipated via topological irregularities and obstructions in the medium. Why do originally very localized disturbances (say, dropping a pebble into a pond of water) on the surface of a pool of water disperse as they do (ie., propagate more or less omnidirectionally), and dissipate? These are examples of fundamental dynamical physical principles or laws. The evolutions of physical systems approach equilibrium.
If our universe is a finite expanding wave in some medium of unknown structure, then it's reasonable to suppose that the total energy of our universe is decreasing -- and if so, then the behavior of waves in media at less than the universal scale is in accordance with the behavior of the universal wave.
Sorry my mistake I didn't mean to say that the light source itself becomes stronger (I should watch my wording more closely). Light's energy doesn't actually change.
I suppose that the current consensus viewpoint is that expansion is coordinate expansion not physical expansion.
I view it that way - light that is traveling toward us does not undergo any change, it's coordinate system that changes over time i.e. measurement sticks become shorter and clocks become faster.
So the question actually should be where matter gets energy instead of where light is putting it.
I can see how it would work with waves, since although a wave would get longer it would also come in for a longer time so the total amount would stay the same. I have no idea how this would work with photon's since you'd need to get more of them somehow.
I already answered this question in https://www.physicsforums.com/showthread.php?t=613451.
Actually, it does. Each photon of the cosmic microwave background is far less energetic in our reference frame than it was in the frame from which it was originally emitted, shortly after the Big Bang. Where did that energy go? How did it get lost?
Why would you need to get more of them?
