What is energy's role in natural forces like gravity and magnetism?
  • Context: Undergrad
  • Thread starter Thread starter Momento
    Force
The discussion revolves around the relationship between energy and natural forces such as gravity and magnetism. Participants explore whether force requires energy to be produced and the role energy plays in various physical interactions, including work done by forces and the nature of energy itself.
  • Some participants question whether force requires energy to be produced, suggesting that energy is the ability to perform work, while forces are responsible for causing changes in motion.
  • Others argue that work is a strictly defined quantity involving force and displacement, and that energy cannot be equated with work in a general sense.
  • A few participants propose that different forms of work (mechanical, electrical, chemical, thermodynamic) may not always involve a force, raising questions about the definitions of work and energy.
  • There is a suggestion that heat and work are both exchanges of energy, but the distinction between them remains a point of contention.
  • Some participants assert that without a force, there can be no interaction or energy exchange between particles, while others argue that force is a result of interaction.
Participants do not reach a consensus on the relationship between energy and force, with multiple competing views and ongoing debate about definitions and concepts related to work and energy.
There are limitations in the discussion regarding the definitions of work and energy, as well as the assumptions underlying the claims made by participants. The discussion also highlights the complexity of distinguishing between different types of work and their relationship to force.
Momento
Hallo,
When force is acted upon a certain object it could change its direction,movement. Does force require energy to be produced?
Looking at all the natural forces they seem to be created and force comes along with them. If force can move an object or stop an object or ever accelerate one. What is energy's role in all of them? Is it like this example:
Magnetic fields producing a natural force that can only be triggered by energy, same as gravity. Are natural force only triggered by energy?
Science news on Phys.org
Momento said:
Hallo,
The short answer is no, but it is kind of a complicated question.
I think you have a misunderstanding of what energy is. Energy is simply the ability for one system to perform work on another. Energy does not cause things to happen, that is the result of forces.
The key word is could. If it does not in fact change anything, no work has been done. Work = force * distance through which the force produced movement of the point of application, in the direction of the force.
If force is produced over a distance is there energy being stored/converted...?
So force is crucial for a system to do work right?
In as far as it's included in the definition, you can't have one without the other.
If the car's not in gear (to transmit a force), the engine can't do any work in getting it moving.
That doesn't logically follow. I stated how a force does work. Perhaps things other than forces can do work. Heat flow, e.g.
Nope. 'Work' is a strictly defined quantity, involving force and displacement. You are trying to associate work with energy in general, which is not precise.
That's not universal. Many authorities distinguish between mechanical work, electrical work, chemical work and thermodynamic work (heat).
That's not how I am used to it. Do you have a reference to these other uses of the word? There seems little point in expanding its meaning so that it becomes synonymous with 'Energy' or 'Potential'.
I do know that 'work function' is used in respect of the energy required to remove photo-electrons but even that involves a mechanical idea, albeit small scale. (And it is a fairly ancient concept along with Electro Motive Force)
I am far from an authority, but I have never heard heat referred to as thermodynamic work. In fact, the two are strictly different according to the first law of thermodynamics. Electrical work is the work done on a charged particle by the electric field. A charged particle feels a force in an electric field.
These specific cases of work can be distinguished, but the definition of work requires a force. If you don't explicitly define a force, it follows from the definition that [itex]-\frac{dW}{dr}=F[/itex].
I would be surprised to see work used in a situation where a force could not be easily defined unless the author was explicitly being loose with definitions.
It's not so much a matter of expanding the meaning. It's more that the meaning of the word "work" has tended to contract to cover only mechanical work in most usage. It's a bit like the use of "forensic" to mean specifically forensic science. It really means "pertaining to law".
Early statements of the laws of thermodynamics included "heat is work and work is heat". The term energy was not so widespread.
But I was wrong to say thermodynamic work meant heat - it's everything except heat. For the rest, see http://en.wikipedia.org/wiki/Work_(thermodynamics).
Ok, Some of you are realting work to energy and I doubt their the same. I'm kinda confused and stuck in the middle here...
All I know now is a system that is able to work will always require "Force" to do so. In many system their are countless forces that have to come into account. Some forces are already being generated from a system's energy and other may have forces upon them such as you and I and all objects that have gravitational force on them.
"sophiecentaur" has a good point about the matter so far.
But isn't heat energy from its origins? I mean heat is the act of atoms having a lot of movement isn't it, so that's energy right?
Heat and work are exchange of energy.
If you only consider work to cover mechanical work then, yes, force will be required.
The references I've found show that 'work' nowadays means any form of energy other than heat, and that if you care about the specific form of work then you should qualify it as mechanical, chemical, electrical, and so on.
For some of these it is not so clear that there would always be a force involved in transfer. Is there a force involved when a photon excites an electron in an atom? Maybe.
The interaction by which any transfer of energy takes place is the result of a force. Without a force there would be no interaction between two particles and no energy would be exchanged.
I would say force is a result of interaction not the other way around.
Thank you! Thats what I've been looking for. Force is crucial in a system to convert energy from its orignal form to another. Thats why we mainly use the formula W = F x D...
I just need to know that force is the tool for energy to use to be able to do "work". Without it you would not be able to do anything with that energy. Hope I'm on the right page here.
Honestly doubt that.
I think that even applies to electrical or chemical systems.
I think it would apply to all those system. However, heat is another different matter...
Flanders and Swann did a memorable rendition of this, way back.
Well, I would say that energy doesn't do work at all. Forces do work and a change is incurred in the system. Energy is simply a measure of how much work something can do.
I think it is a pointless distinction. Let us forget about force fields so we can separate force and energy from each other. Now if I throw a ball in space, we have something called kinetic energy and that energy can do work on object B when it is in contact.
But you could just as easily say that it is the force that did work by the equation F=ma. I accelerated mass A and it hits object B with force F and does work.
So which one is the "culprit"?
The work done is going to depend on all the properties of an object, from it's mass to it's velocity to whichever forces it interacts by. (Along with the same things for the object it interacts with)
But if one were to choose which one does the work I would say it is the force. If two particles don't interact by a force at all, then they cannot perform work on each other. But then would the particles still have energy, at least with respect to one another? I don't know.
I really like you descriptions! I believe that FORCE is the key for work without as I said before work can't be done. Really really interesting thing. Thank you so much for you're answers!
For all the others I appreciate you're effort too! Thing is we could all agree at a certain point that without force the system can NOT do any work at all! I'd be glade to read more ideas from anyone else!
If force was applied to an object will there be work done? Would there be energy stored?
I think that force is the main reason why energy could possibly be converted... Like friction its a force on moving objects it converts their energy into heat, its possible that it could convert it to another form of energy?
True, for kinetic energy to happen there needs to be a force (acceleration or "imbalance" if you will).
Yes work is done when ever you displace an object X distance. Force does work because it accelerates things, and hence displaces it.
Well it kind of depends on what you mean by stored. Under certain parameters like in gravitational fields where energy is conservative, potential energy is stored.
Based on other principles, you can argue that kinetic energy is given to the object since it picks up velocity. Whether you want to call that stored is semantics.
I'm not following this point.
Look at the rotational kinetic energy of a wheel that is being rotated by a motor for example.
That motor would convert electricity into mechanical energy to rotate the wheel. Let's say based on the work model 1000J was supplied of electricity, if the motor would lose some of that energy due to countless reason. One of them is "Friction" of the bearings.
Now friction is a force, it distribute a small amount of the 1000J to another form of energy like heat,sound,etc...
:approve:
  • · Replies 51 ·
  • · Replies 69 ·
