Reasons why the Franck Hertz experiment might fail
  • Thread starter Thread starter sunrah
    Experiment Hertz
The Franck Hertz experiment conducted with mercury vapour yielded excitation potential intervals of 5.75 V and 6.40 V, deviating from the expected 4.9 V. Potential measurement was performed using an oscilloscope, which may require calibration. Possible causes for the discrepancies include faulty tube or air mixture, improper grounding, and issues with cable connections. Additionally, the glass tube's capacitance can affect results, necessitating precautions against physical contact during the experiment.
  • Understanding of the Franck Hertz experiment principles
  • Familiarity with oscilloscope operation and calibration
  • Knowledge of electrical grounding techniques
  • Awareness of capacitance effects in glass materials
  • Research techniques for calibrating oscilloscopes
  • Learn about proper grounding methods in experimental setups
  • Investigate the effects of capacitance in glass and its implications for experiments
  • Explore troubleshooting methods for electrical connections and solder joints
Physics students, laboratory technicians, and educators conducting experiments related to atomic structure and electron excitation.
sunrah
We conducted the Franck Hertz experiment with mercury vapour and got intervals for the excitation potential of 5.75 and 6.40 V. I know that the intervals should be 4.9 V.
The potentials were measured using an oscilloscope at the most convenient scales.
I just can't think what may have gone wrong other than faulty tube/air in mixture (although we should still see some intervals at 4.9 V I think?) or oscilloscope needs callibrating. The apparatus was allowed to heat up a good ten minutes before we started.
What else could have affected things?
Check your cables. Sometimes the solder joints to the plugs at the end of the cables break.
Check your grounding.
Glass has capacitance and can accumulate charge but any good company will usually coat their tubes will an extremely thin metallic film to dissipate it.
Because of the capacitance, don't let anyone touch the tube during the experiment.
Did you give the filament a little time to warm up?
10K
14K
