How to calculate the magnetic field and pull force generated by current?
The discussion focuses on calculating the magnetic field generated by current flowing through copper wire, specifically using the formula B = (μ₀I)/(2πr), where B is the magnetic field in Tesla, μ₀ is the permeability constant (1.26 x 10-6 T m/A), I is the current in Amps, and r is the distance from the wire in meters. The "right-hand rule" is mentioned for determining the direction of the magnetic field. For non-straight wires, integration is required to accurately calculate the magnetic field. The user expresses interest in exploring additional equations for looped wire configurations.
  • Understanding of electromagnetic principles
  • Familiarity with the formula for magnetic fields around current-carrying conductors
  • Knowledge of integration techniques for complex wire shapes
  • Basic grasp of the "right-hand rule" for magnetic field direction
  • Research the application of integration in calculating magnetic fields for non-linear wire configurations
  • Explore the effects of looped wire arrangements on magnetic field strength
  • Study the Ampère's Law and its implications for magnetic field calculations
  • Investigate the use of simulation tools for visualizing magnetic fields around conductors
Students and professionals in physics, electrical engineering, and anyone interested in the practical applications of electromagnetism, particularly in designing systems involving current-carrying wires.
Momento
Hallo all,
I've been looking around to find the best way to calculate the magnetic field generated by current flowing through copper wire... There were many sites I've found but its kinda confusing
One of the laws:
I thought it was simple to determine the magnetic field... Is there a way to calculate the pull force as well?!
Thanks in advance!
The strength of the magnetic field around a long, straight wire is:
[itex]\Large B=\frac{μ_{0}I}{2\pi r}[/itex]
B is the magnetic field in Tesla, μ0 is the permeability constant (1.26*10-6 T m/A), I is current in Amps, and r is distance from the wire in meters.
The direction of the field is given by the following "right-hand rule":
When you want to calculate for a wire that's not perfectly straight, this equation isn't valid, and you must use integration to account for an odd-shaped wire.
Thank you so much for that!
I'm looking up for more equations because most probably I'll make a series of looped wires and tie the together...
  • · Replies 21 ·
  • · Replies 22 ·
