How Does Acceleration Affect Perceived Gravity in Space?
The discussion centers on the effects of acceleration on perceived gravity in a hypothetical spaceship scenario, exploring concepts of force, energy, and the implications of traveling at relativistic speeds. The conversation includes theoretical considerations without delving into engineering specifics.
  • One participant introduces a fictional unit of energy (CNU) and questions whether a constant application of 1 CNU would maintain 1 G of acceleration indefinitely.
  • Another participant suggests that from the spaceship's perspective, maintaining 1 G does not require increasing power as speed approaches light, implying a unique relativistic perspective.
  • A follow-up question seeks clarification on whether increasing power to 2 CNU would result in 2 G of acceleration, with a focus on the frame of reference of the spaceship.
  • It is noted that if CNU is considered a unit of force, then power and force are generally proportional, which could influence the relationship between acceleration and energy consumption.
  • Concerns are raised about the need for energy to sustain speed in space, with one participant mentioning friction from the interstellar medium as a factor affecting velocity maintenance.
  • Discussion includes the idea that velocity does not have an absolute reference, complicating the understanding of gravitational effects from external bodies at different speeds.
Participants express differing views on the implications of acceleration and energy requirements, with some agreeing on the theoretical aspects of maintaining acceleration while others question the effects of external forces and reference frames. The discussion remains unresolved regarding the specifics of energy consumption and gravitational effects at varying speeds.
Limitations include assumptions about the nature of CNU, the effects of interstellar medium friction, and the lack of consensus on how velocity impacts gravitational pull from external objects.
vrghost
On the way into work this morning, happily reading my book (Leviathan Wakes, would suggest it to any sci-fi space opera fan) and there was a passage that read along the lines “they reduced acceleration to sustain a 1g force during the meal” or something along those lines. Its something you often read in books where authors have decided that future spaceships will use acceleration to generate gravity, and clearly that is an option.
So ignoring all the engineering factors, humanity has access to the anti super kung-fu kickass particle that can provide loads of energy indefinitely and they got an engine even more kickass than Chuck Norris. Actually, it is so cool that it can deliver 10 CNU (Chuck Norris Units). Also to have something to work with, from standstill, 1 CNU will provide acceleration equal to 1 G.
Also, to start with, we say that gravity from planets have no impact at all, and that no power is required to sustain speed (will get back to this later)
With these rather general statements, and I am sitting completely still in the space, and I decided to generate 1 G so I could drink my coffee comfortably, I just turn up the power to 1 CNU. But my question is, would 1 CNU of energy continuously give my spaceship 1 G, or would I have to increase the power as my acceleration increases. If the later, would this be just as I am approaching the speed of light, or would it be noticeable pretty much instantly?
The next questions (the ones I said I would get back to) is, would it be true to say that in space, ignoring the occasional particle, would an object accelerated sustain its speed indefinitely or does my ship have to use some of its energy to sustain the speed?
Last question, does the speed of an object impact the amount of gravitational pull an external object will have, so let's say I am going close to a moon, will the amount of pull differ if I am doing it at 0.01 c or 0.1 c
Welcome to the forums! From your perspective nothing would ever change. You can continually spend 1 CNU and never have to increase it and never reach the speed of light.
Thank you very much Ryan_m_b
Just to confirm, and continuously have one G in my space ship?
Would that also mean that if I crank it up to 2 CNU I would get 2 g in my spaceship?
If CNU is a unit of force, yes. For a given design, force and power are usually proportional, therefore you can use a unit of power, too.
The velocity of the spaceship (relative to what?) does not matter, as there is no absolute velocity anyway.
Energy is power multiplied with time. Therefore, you need a certain energy per time to maintain the acceleration.
You would have some friction from the interstellar medium. But apart from that, the spaceship will keep its velocity (relative to any inertial system) if you do not use any propulsion method.I assume that the spaceship has no access to any other structures (like a railroad in space), otherwise things would be a bit different.
yes. But that is in the frame [reference] of the spaceship itself. Outside observers willsee different effects.
  • · Replies 61 ·
15K
  • · Replies 16 ·
9K
16K
  • · Replies 34 ·
