Calculating the Z2 cohomology of the Klein Bottle using intersections
  • Context: Graduate
  • Thread starter Thread starter lavinia
    Klein
This thread discusses the calculation of the Z2 cohomology ring of the Klein bottle using intersection theory. Participants explore various aspects of cohomology, including the relationship between fiber circles, base circles, and their intersections, as well as the implications of these intersections for the cohomology structure.
  • One participant suggests viewing the Klein bottle as a circle bundle over a circle, proposing that the fiber circle and the base circle generate the first Z2 cohomology through transverse intersection.
  • It is claimed that the fiber circle has zero transverse intersection with itself and intersects the base circle at a single point, which relates to the first Stiefel Whitney class of the tangent bundle.
  • The same participant notes that the base circle intersects itself and the fiber circle at a single point, leading to a non-zero cup product for the base circle.
  • Another participant questions the relationship between Z/2 homology and dual cocycles, suggesting that Poincaré duality may hold mod 2.
  • A different participant expresses interest in computing the cohomology ring of the Klein bottle, noting a surprising 1-dimensional class whose square is not zero but not induced from the classifying map into projective space.
  • This participant raises a broader question about whether the Z2 cohomology ring of higher-dimensional flat manifolds can be computed using similar techniques and whether there are cohomology classes that cannot be obtained in this way.
  • Concerns are raised about the relationship between the Z2 fundamental cocycle of the Klein bottle and its characteristic algebra, particularly regarding the implications of the first Stiefel Whitney class being zero.
  • Another participant introduces the idea of exploring simple 3-manifolds, such as a two-way Klein bottle, and notes that similar phenomena occur in these cases.
  • One participant inquires about the possibility of setting up a 2-fold ramified cover of the sphere by the torus that projects to a 2-fold ramified cover of the projective plane by the Klein bottle, suggesting a connection to the classifying map of the tangent bundle.
Participants express various viewpoints and raise questions without reaching a consensus. There are competing ideas regarding the implications of intersection theory for the Klein bottle's cohomology and the broader applicability of these methods to other manifolds.
Some claims depend on specific assumptions about intersections and the properties of the manifolds discussed. The discussion includes unresolved mathematical steps and does not clarify the implications of certain definitions or concepts.
lavinia
This thread asks for help calculating the Z2 cohomology ring of the Klein bottle using intersections.
This is what I think.
View the Klein bottle as a circle bundle over a circle. A fiber circle and the base circle generate the first Z2 cohomology by transverse intersection.
- The fiber cicle has zero transverse intersection with itself and intersects the base circle in a single point. This would appear to be the first Stiefel Whitney class of the tangent bundle. Since itself intersection is zero the cup product of the cohomology class that it determines with itself is zero. This seems right since the Euler characteristic of the Klein bottle is zero.
- the base circle intersects both itself and the fiber circle in a single point. so its square under the cup product is not zero.
This completely describes the cohomology ring in dimension 1.
What about the pull back of these classes under the two fold cover of the Klein bottle by a torus?
- the fiber circle class now intersects the base twice as so pulls back to zero. This makes sense because the torus is orientable so its first Stiefel Whitney class is zero.
- the base circle intersects itself twice and so has zero self intersection mod 2 - so itself cup product is now zero - but still intersects the fiber circle once. So it pulls back to one of the generators of the first cohomology of the torus.
I think this right.
whats the idea here lavinia? you know the Z/2 homology and assume that poincare duality holds mod 2, so you want to find dual cocycles to the generating cycles?
Mathwonk
I was interested in computing the cohomolgy ring of the Klein bottle - not just its cohomology - using transverse circles on the boundary of its fundamental domain.
I wanted to find the first Stiefel-Whitney class and see why its square is zero and was surprised that there seems to be a 1 dimensional class whose square is not zero but which is not induced from the classifying map into projective space. I just thought I may have done it wrong and wanted to make sure.
But there is a broader idea. Can one compute the Z2 cohomology ring of a flat manifold of higher dimension using the same technique, intersection of hyperplanes on the boundary of a fundamental domain.? Are there cohomology classes that can not be obtained in this way? A priori without any other knowledge this could even be true of the Klein bottle so how does one see this?
I was hoping that for more complicated flat manifold this technique could also be used to compute the Z2 characteristic algebra and maybe to find a manifold whose fundamental Z2 cohomology class is actually in induced from the classifying map into the holonomy group.
The amazing thing to me about the Klein bottle is that its Z2 fundamental cocycle is the square of a 1 dimensional class but not the square of a class in its characteristic algebra (since the square of its 1st Stiefel Whitney class is zero).
I have started trying out some simple 3 manifolds such as two way Klein bottle - a half twist along both the y and z axes. The same sort of thing happens here but now that manifold is orientable so the 1 dimensional cohomology class induced by the classifying map into projective space is not the first Stiefel Whitney class.
Mathwonk
I have read you explanations of ramified covers in another thread and wonder whether a 2 fold ramified cover of the sphere by the torus can be set up to project to a 2 fold ramified cover of the projective plane by the Klein bottle.
This might be the classifying map of the tangent bundle.
  • · Replies 38 ·
9K
  • Poll Poll
  • · Replies 21 ·
27K
19K
