How Can Hydrogen Be Separated from Water Safely and Efficiently?
  • Thread starter Thread starter jack001
    Hydrogen Water
The discussion revolves around methods for safely and efficiently separating hydrogen from water, particularly exploring alternatives to electrolysis. Participants consider various processes, including the use of catalysts and membranes, while addressing the challenges associated with gas separation.
  • One participant suggests using titania as a catalyst in sunlight to convert water into hydrogen and oxygen, questioning how to separate the gases afterward.
  • Another participant notes that hydrogen will float above oxygen, raising concerns about the risks of mixing the two gases.
  • A different viewpoint emphasizes that gases do not separate solely based on density, comparing the situation to mixing different sized ping pong balls.
  • One participant proposes using valves at different vertical levels to separate the gases during the reaction.
  • Another participant mentions Pressure Swing Adsorption (PSA) as a method for separation, requesting further elaboration on the technology.
  • A detailed explanation of PSA is provided, discussing the mechanisms of semi-permeable membranes and the potential use of carbon nanotubes and graphenes for hydrogen separation.
Participants express differing views on the feasibility and methods of gas separation, with no consensus reached on the best approach. Concerns about the risks of mixing hydrogen and oxygen are acknowledged, but the discussion remains unresolved regarding the most effective separation technique.
Participants highlight various assumptions about gas behavior and separation methods, including the role of pressure differentials and the properties of materials used for separation. The discussion does not resolve the technical challenges involved in these processes.
jack001
hello folks,
i was wondering if any other possible process of separating hydrogen from water without or less risk, any alternative method of electrolysis.
i have googled this thing and stuck to process of introducing a catalyst 'titania(titanium oxide)' in the presence of sunlight, directly converts water into the molecules of hydrogen and oxygen.
But now what? I mean how to separate this two different gases?
i suppose semi-permeable membrane can help in separation.
guide me if i am wrong.
wont the hydrogen float above the oxygen?
I don't think you want to be mixing hydrogen and oxygen. They tend to explode when combined. Hence the need to separate them before they get out of the water.
^^ yes of course, they explode, so i need to separate them.
Take a look at PSA's.
so if hydrogen floats above oxygen then you could separate them by knowing where the dividing line is amd by placing valves at two distinct vertical levels to remove some gas at a time while the reaction is taking place.
Gasses do not separate just because one of them is 'lighter' than the other. They will mix just like two different sized ping pong balls bouncing around in a box.
Agreed, unless you cool the mix and separate via liquefaction.
but won't it explode as soon as it is converted into gas?
can you please elaborate this technology.
The Wiki article describes PSA pretty well- it somewhat fits into the first method below for semipermeable membrane separation, but needs a driving force to release the adsorped molecules from the pores (usually atomic dimensioned channels in Xeolites).-semi-permeable membranes rely on pores that can be used to exclude by one of several mechanisms. The most obvious one is to select by size and that H2 molecules are smaller than O2 molecules, so pores on the order of a few Angstroms can reject O2- a pressure differential exists between the two sides to drive the process.
Other methods can place an electrical or Donnan potential barrier at the pore's mouth that helps reject one type of molecule over another (mostly seen in R.O. membranes where charged dissociated salts are rejected while largely neutral H2O passes through).
Some vander Waal's forces can also create a selectivity for one type of molecule over the other, and the attractive forces used to help coax the right molecule through a pore. In this sense, the metals that are known to adsorb H2 can act as an appropriate barrier for other molecules- the downside is that these metals also recombine O2 and H2 to water catalytically, so efficiency suffers.
Thus the interest in CNT and graphenes as H2 separators; O2 stability is still a problem.
10K
