What Is the Difference Between Covariant and Contravariant Vectors?
  • Context: Graduate
  • Thread starter Thread starter codeman_nz
    Contravariant Covariant
The discussion clarifies the distinction between covariant and contravariant vectors, emphasizing that contravariant vectors, such as velocity, adjust inversely with changes in the coordinate system. When converting velocity from meters per second (m/s) to kilometers per second (km/s), the value decreases due to the increase in the coordinate system. Covariant vectors, referred to as one forms, are functions that map contravariant vectors to real numbers, illustrating their dual relationship. This conceptual understanding aligns with modern interpretations that equate vectors with equivalence classes of curves or differential operators.
  • Understanding of vector calculus
  • Familiarity with coordinate transformations
  • Basic knowledge of differential geometry
  • Concept of functions mapping vectors to real numbers
  • Study the properties of vector transformations in differential geometry
  • Learn about the mathematical definitions of one forms and their applications
  • Explore the relationship between curves and vector fields in manifolds
  • Investigate the role of differential operators in modern physics
Students and professionals in mathematics, physics, and engineering who seek a deeper understanding of vector analysis and its applications in various fields.
codeman_nz
Hi everyone,
I am having a little trouble with the difference between a covariant vector and contravariant vector. The examples that I come across say that an example of a contravariant vector is velocity and that a contravariant must contra-vary with a change of basis to compensate.
So if you have a velocity that is measured in m/s and you want to measure it in km/s then the velocity shrinks. Is that because you increased the co-ordinate system to km and so that velocity must shrink to compensate for that increase? Or am I thinking of it the wrong way?
More modern terminology has contravariant vectors simply being called vectors and covariant vectors being called one forms. Covariant vectors (one forms) are best thought of, in my opinion, as simply functions of contravariant (vectors) vectors into real numbers. In other words, one forms are functions, e.g. f(), which accept a vector argument and returns a number: f(v)=real number.
The two are dual to each other, and are defined in the classical literature by the transformation properties of their components under coordinate transformations. More recently, one tends to work more conceptually and equate vectors with either an equivalence classes of curves (1-1 mappings from R into the manifold) or with differential operators because there is a 1-1 isomorphism between these concepts. One forms are then simply defined and thought of as above, i.e., functions of vectors into real numbers.
  • · Replies 24 ·
  • · Replies 21 ·
18K
  • · Replies 16 ·
