Can a magnetic fields/forces do work on a current carrying wire?
The discussion centers around whether magnetic fields can do work on a current-carrying wire, exploring the implications of magnetic forces in the context of electric motors and the behavior of charges within a wire. Participants examine theoretical aspects, practical applications, and the mechanics involved in such systems.
  • Some participants assert that magnetic fields can only do work on pure magnetic dipoles, citing the perpendicular nature of the magnetic force on a charge as the reason it does no work.
  • Others propose that while magnetic fields do not do work on charges directly, they can influence motion through internal forces within the wire, which are responsible for the work done in a motor.
  • A participant highlights that the torque in a motor is not directly caused by the magnetic field but rather by the contact forces between the electric current and the wire itself.
  • There is a discussion about the role of internal forces in maintaining the structure of the wire and how these forces interact with the motion of electrons, suggesting that these internal forces are crucial for understanding the system's behavior.
  • Some participants emphasize the importance of boundary conditions and constraints in analyzing the forces at play, noting that these factors are often overlooked in simplified explanations.
Participants do not reach a consensus on whether magnetic fields can do work on current-carrying wires. Multiple competing views are presented, with some focusing on the role of magnetic fields and others emphasizing internal forces and constraints within the wire.
The discussion reveals limitations in understanding the interactions between magnetic fields and electric currents, particularly regarding the assumptions made about forces and constraints in the system. The complexity of internal forces and their implications for motion are noted but not fully resolved.
  • #31
Darwin123 said:
I agree that the work is done be several forces. However, that requires a bit of semantics.
In common usage, work is done by the system providing the energy. If a person used a bicycling generator to provide the current, then he would have to work harder to keep the current going. However, he is not applying force directly to the motor.
I would say that the magnetic isn't really doing work at all. The energy isn't providing the energy. It is only supplying the force.
In a lever problem, we seldom say that the lever is doing work. The person pushing down on the lever is doing work. The internal forces of the lever are the ones that end up pushing the object that is being lifted. However, the work is done only by the system that provides the energy.
Therefore, I would turn your idea around a bit. Instead of saying,
I believe there are multiple forces in the "motor effect" that do a "net work".
I would say,
I believe the electric current in the wire does the "net work". Multiple forces cause the motor effect.
The forces exerted by the magnet and wire on the carriers cause the "motor effect." Since the work of internal forces cancel out, I can't see how the internal forces can be said to do work.
I world restrict the phrase "doing work" to the system that provides the energy and not the forces that change direction.
This idea may also be useful in thermodynamics. In the case of the Carnot cycle, the cylinder with the gas is filled with gas molecules. Each gas molecule hitting the piston does work on the piston. The force of each gas molecule on the piston is different. However, these are internal forces. In the end, the contribution of the gas molecules averages out to one parameter which is the pressure. It is the gas in the cylinder that does the work, not the forces of the individual molecules.
I would agree with you if you'd say magnets do a "part" of the total work. As you said its all about the force supplied by the battery. Which then creates multiple forces within the wire.
As I said before, without the presence of a B field, no work would be done. Indeed the electrical forces are the main reason why this whole process would occur.However, without the existence of a magnet/electromagnet etc... No work will be done and the motor effect wouldn't be created.
Here's an example of what I mean:
Take a computer... You'd agree that a processor is a key element of the system like a permanent magnet in a motor. Now a processor is pointless without what? A motherboard! To link it with the other parts of the system. Hence in a way the motherboard acts like the electrical forces or viceversa. Without one element the other can't do anything. When both are present something can occur.
If you'd say magnets alone do the work, I would not agree. If you'd say the electrical force alone are doing work, hmm... I'd still not agree. If you'd say BOTH forces do the work. I would clap and agree :approve: .
You know Darwin123, its all linked to one another. We can't point out one culprit and say it did all the work now can we? We would assume that there was an associate in this whole business lol,
Again I would reifer to this law: F = IL x B, The magnetic force applied on the wire is created from both I & B, Without them both nothing would happen, A force would be present but no work would be done. I do acknowledge all the inner force generated by the electrical force, all the small part that make up the whole force and I do agree that "force" is supplied by the battery in a distance. When we break done energy you'd find its all about the forces :-p
  • #32
What an interesting discussion this turned out to be. I found that I understood more and more of this effect. Wonderful!
I appreciate all you're efforts everyone! Thank you all!
  • #33
Actually there are 3 forces involved. Without strong nuclear force, SNF, the neutrons would not be moved. It takes all 3, magnetic, electric, & SNF. But it is important to emphasize that the currents in the field & armature windings (rotor & stator if you prefer), control the value of magnetic force, which results in electric & SNF matching the mag force.
Ultimately the value of interacting magnetic fields determine the torque. But this force acts only on electrons directly & relies on the E & SN forces to yank protons & neutrons along via tethering. This is why motor/generator theory places so much emphasis on magnetic forces & not the others. I believe that energy conversion is taught the right way at engineering colleges. Interesting discussion, thanks to all.
Claude
  • #34
I agree. The real issue here is how to draw the boundaries of our interacting systems. The boundary of an interacting system determines which are the internal forces and which are the external forces.
This is why I said that the issue was one of semantics. No boundary was drawn in the diagram. So different people here may be envisioning different subsystems. There are several composite bodies in the problem. What everyone says is correct, but they are talking about different composite bodies.
  • #35
What do you mean by the SNF? &"important to emphasize that the currents in the field & armature windings (rotor & stator if you prefer), control the value of magnetic force, which results in electric & SNF matching the mag force."
Could you clarify this a bit more(Simpler way), I do understand the "tethered" part. But not sure what you're talking about hee...
Claude
Hence the idea of opposing and attracting magnetic fields.
E forces... Whats SN forces?
I thought by applying the magnetic force on the electron directly, an indirect force is applied on the proton and neutron?
  • #36
I guess we truly need to breakdown things to the quantum level to understand how energy,force,work is all processed in this system. Interesting topic.
  • #37
The tethering was explained in the link I referred to, from a thread in 2009. If you review the link then I will clarify if needed. SNF is the "strong nuclear force", which tethers the neutron & proton together. I brought it up simply because some suggest that the "E forces" are "really doing the work". I just wanted to remind all that an E field cannot move a neutron. The neutrons are roughly half the mass of any element/compound, except those with hydrogen. So neutron forces/motion cannot be explained with B or E forces, only SNF.
Have I helped? BR.
Claude
  • #38
Have I helped? BR.
Claude
Claude, Based on what you said and Darwin123. Is it safe to say: Magnetic field's can do work under certain circumstances? ONLY in the presence of both E forces + N forces can magnetic fields do work.
In a sense they are... So as E force, So as the N force.
They all were triggered in this even or "action" to do work. I would say this in a general simpler way:
Magnetic force can do work with the presence of E,force + N,force.
Electric force can do work with the presence of M,force + N,force.
N force can do work with the presence of M,force + E,force.
In a sense the motor effect... A simple effect CAN NEVER occur without the upper 3 rules.
They are all dependent on each other. without one of them. Nothing would happen.
Simple forces added up together to give the total work.
  • #39
That sounds pretty reasonable to me. Several of us examined this exhaustively, & collectively we ascertained what you just said. Ultimately, though, I believe that the actual work is done by the power source driving the motor. Although energy can be stored in fields, then released to another entity, it is the power source, i.e. the wall outlet power mains, that is providing ALL the energy/power.
In a motor, of course all 3 forces work in unison, but it is safe to say that the magnetic forces, i.e. B/H, are the quantities that literally control the motor action. SNF & E tag along like an obedient shadow, but magnetic is in charge. Using my 3 ball analogy, a magnet lifts 3 tethered balls, steel, wood, & rubber. The magnet cannot lift wood and/or rubber, but it lifts them indirectly by lifting the steel ball directly, & relying on the E & SN tether forces to lift the rubber & wood balls.
But let us not forget, the magnet must provide a lifting force equal to the combined weight of all 3 balls. If each ball weighs a pound force, then the mag force must be 3 lbf. But the E & SN forces are only equal to the weight they carry. If the steel ball is on top, then E & SN provide 2 lbf, while the mag is 3 lbf. So the magnetic force is definitely the prime mover but it still relies on help from E & SN.
Interesting question. These puzzles get us thinking. I want to thank everybody here for being polite. These types of questions usually end up in a mud wrestling match. Everybody on this thread conducted themselves very well, & I take my hat off to all. I hope future discussions can be this civil. Best regards.
Claude
  • #40
And gravitational forces. Let us not forget those! Furthermore, you have to say what it does work on. I think that you are asking whether a magnetic field can do work on an electric charge or electric current.
I think the following is valid, but demonstrating it may sometimes be difficult.
ONLY in the presence of both E forces + N forces+gravitational forces can magnetic fields do work on an electric charge or electric current.
  • #41
Other than gravity, we seem to have reached a unanimous agreement. But gravity is too weak to be concerned with as it is many orders of magnitude smaller than E, M, or N. Nonetheless, we cannot deny its presence, nor that of "W" (weak force", if such materials are present, but I don't think beta decay is present in motor materials).
Thanks again to all. BR.
Claude
  • #42
When you break that down you'd realize that what the energy source is really just supplying the E forces within a distance. Already energy has been transferred on the wire, and work has been done.
I believe then the E force + SN force would interact with the M forces. We all should break down the concept of Work in, and Work out. Its more understanding when you would say the Forces in and the Netforce out. If you see where I'm going with this... It simply draws a better picture you can visualize it and understand everything more clearly then saying energy In and the energy converted(With respect to all laws, that's just my own way of understanding the relationship of energy,work,force all together).
Claude
Thanks! We should raise questions similar to this! To understand the truth about it more!
  • #43
Thank you all again for you're efforts!
  • #44
It is important to note that magnetic fields apply forces only on moving charged particles, and for example in the the case of the electric motor, not on the wire itself but on the electrons.
I found this picture from google:
Consider a stationary particle that is on the path of the moving charged particle after it has moved through the magnetic field (for example where the arrow points that is with the text "Path of the particle"). The charged particle would collide with the stationary one after having gone through the magnetic field. Note that the magnetic field does no work on the charged particle, gives it no additional kinetic energy, only changes its direction. If there were no magnetic field, the particles wouldn't collide, but the magnetic field makes them collide and "makes" the second particle move. So it would seem that the magnetic field did work on the other particle, but it didn't, it simply redirected the first particle to hit something it otherwise wouldn't.
The energy to do the work came from the kinetic energy of the first particle, yet without the magnetic field the work couldn't not have been done on the other particle. Nevertheless, the magnetic field did no work, it simply redirected a particle's path.
In the case of the electric motor, the magnetic field would also simply change the paths of electrons, but would not give them any additional energy. The kinetic energy for the moving wire would come from the kinetic energy the electrons had before.
  • #45
Um, if you say that magnets do no work... Check this out
1 - Yes they can,
2 - Why?
3 - Convinced?
If you still need some more "worded" detail check theses links out: 1, 2,
As I said before and I will say this again. Magnets/magnetic fields/etc... Are not understood fairly well... I mean so many attention went for complex idea how the most simplest products of nature and most important forces have been underrated... :frown:
  • #46
But we're discussing forces between current carrying wires, akin to motor operation. We're not discussing collisions among particles. It has already been stated unanimously that a single charged particle, or several, moving through a magnetic field can only have its momentun changed, not its kinetic energy.
The rebuttal directly before this one by Miyz addresses what we've been talking about. When 2 current loops interact resulting in a net torque, we are examining the work done, forces involved, etc. Please review the link I gave earlier. Rather than repeat what has already been discussed, I will elaborate if you still have questions. Best regards.
Claude
  • #47
Claude
He should review you're thread and ours. Then he would understand our common conclusion about magnets doing work or not.(Again, THEY DO but UNDER CERTAIN circumstances)
  • #48
Claude
A current through a wire is several charged particles moving. They feel the magnetic force, not the wire directly, and respond to the force by changing their direction and giving some of their momentum in the new direction to the wire, creating a force on the wire.
It should be similar to the collision. The direction of the electrons is changed and thus allowing them to do work on the wire by colliding with it. Otherwise the collisions would be chaotic, but the magnetic force changes the directions of the electrons in a consistent manner and allows the work to be done at the expense of the electrons kinetic energy, as in the case of a simple collision.
  • #49
Claude
Another assumption implicit in your diagram is that the permanent magnets don't move. This is one reason the magnetic field is static. If the magnets were allowed to move, then the problem would be more complicated.
The magnets keep their shape by rigid body forces. They may be held stationary on the horizontal plane also by rigid body forces. For instance, the mangets may be attached by glue to the horizontal surface. However, suppose the magnets are not attached directly to the plane.
If the magnets are not attached directly to the surface, then there has to be other forces involved. The magnets may have to be held still by a mixture of both gravity, contact force and static friction. The gravity prevents the magnet from moving up. The contact force (i.e., the normal force) prevents the magnet from sinking down. The static friction prevents it from moving in the horizontal plane.
Similarly, the wire loop has some weight. If the wire loop is not uniform in thickness, the unbalanced wire could be affected by gravity.
The weight of a single carrier may be negligible. However, the weight of other components in the system may not be negligible.
The discussion has turned to the contribution of nonmagnetic forces to the work done on the wire loop. The conjecture has been raised that maybe nonmagnetic forces "do work" in a motor. Gravity may well "do work" on a motor.
Fortunately, the problem can be solved without enumerating all the forces "that do work". The work done by most of those forces cancel out. By choosing the boundaries on the system properly, one can "hide" the forces that cancel out. In general, this is what has to be done.
  • #50
An internal collision does not do work on the wire since conservation of momentum requires that the wire moves, i.e. undergo a momentum change, only when acted upon by an external force. This force is M. But, M exerts no force on stationary lattice protons & neutrons. Hence E & SN forces provide the tether force so that when M yanks on the electrons, the protons & neutrons are tethered along by E & SN forces.
Claude
  • #51
How can gravity "do work" on a motor? I just want to know how.
Claude
  • #52
I think that has a smal weak effect on the motor... It can't do work if it was it would have been added in this formula F = IL x B.
And if you think it does Darwin123,how is it so?
  • #53
Darwin123, You're really confusing me here... Could you give me a SIMPLE conclusion that you agree upon? In a sentence perhaps?(Makes it all clear.)
As I said before and will continue to stand upon this point magnets can do work under certain circumstances. And magnetic field will possesses potential energy which depends upon its orientation with respect to the magnetic field.
It's all complicated business lol, however. Interesting as ever :)
  • #54
A magnetic field can certainly do work on a current carrying wire.
For example, consider a superconducting loop with current. Such a current carrying wire forms a magnetic dipole. A uniform external magnetic field can exert a torque, and a non-uniform field can exert a net force, both of which may be arranged to do work on the wire.
A magnetic field can not do work on a classical isolated point charge, but that doesn't prevent it from doing work on other things.
  • #55
I provided an example where it does. I am sorry, but nature disagrees with you.
  • #56
But isn't it also correct to say that the magnetic field does no work on the electrons, it just changes their path, and then the changed paths of the electrons cause the torque or force on the wire? As the electrons paths are changed, electric forces keep them from escaping the wire and due to Newton's third law the wire experiences a force.
  • #57
hahahahahaha! THAT JUST MADE MY DAY! Seriously.
  • #58
Good point. Now I'm starting to get confused here to :confused:
  • #59
Didn't really understand that point well... Could you elaborate more DaleSpam?
  • #60
I doubt that it is correct to say in a superconducting wire. In general, electrons are not little classical point particles, but in most normal situations it is probably an OK approximation.
However, superconduction electrons are not even approximately like that. They are in a very strange quantum state where an individual electron is literally not localizable to any location in the wire and all of the superconduction electron pairs share the same state.
I don't think that under those conditions the Lorentz force law for a point charge is correct.
  • · Replies 30 ·
  • · Replies 36 ·
