Nonregular icosahedral die approximating a bell curve
  • Context: Graduate
  • Thread starter Thread starter diceman
    Bell Curve
The discussion focuses on designing a nonregular icosahedral die that approximates a bell curve in its probability distribution across 20 sides. Key challenges include calculating the "landing probability" for each face of the convex polyhedron and ensuring that the die maintains stability with a defined "up face." The conversation suggests that achieving a bell-curve distribution may require specific geometric constraints, such as bilateral symmetry, and proposes a practical solution using a modified d100 die for those less interested in the underlying mathematics.
  • Understanding of convex polyhedra and their properties
  • Knowledge of probability distribution concepts, specifically bell curves
  • Familiarity with geometric calculations related to surface area and angles
  • Basic principles of symmetry in three-dimensional shapes
  • Research methods for calculating landing probabilities on convex polyhedra
  • Explore geometric properties of nonregular icosahedra and their implications for dice design
  • Study the principles of probability distributions and how they apply to gaming dice
  • Investigate the use of modified d100 dice for creating custom probability distributions
This discussion is beneficial for game designers, mathematicians interested in geometric probability, and hobbyists looking to create custom gaming dice with specific probability distributions.
diceman
Can somebody provide a solution for creating a nonregular icosahedron whose facets are sized in such a way that, when used as a die, the probability distribution of the 20 sides would approximate a (stepped) bell-curve??
Hmm...I really like this problem, but I don't know offhand how to attack it. A simpler question, which I still don't know how to answer, is how to compute, for each face of some given convex polyhedron, the "landing probability". Your problem is a kind of inverse--given some probabilities, find a convex polyhedron that realizes them.
All the standard dice (except for d4) have faces arranged in parallel pairs; without this arrangement, there won't necessarily be a side facing "up". I'd avoid this problem by just deciding that it's the down face that determines the result of a roll.
I wonder if a random 20-sided convex polyhedron tends to have a certain kind of distribution? We'd have to decide what we mean by "random", and probably need to restrict to some kind of "nice" subset, e.g. reject dice that are a million times as long as they are wide. Also, a given face could have probability zero, i.e. the die is not even stable with that face down, so ruling that out gives us another restriction on our space of dice.
Finally, since this is your first post here, it's possible that you really just want a bell-curve d20 and you're not interested in the mathematics for its own sake. In that case, I have a "cheating" solution for you: get one of those d100 dice, the ones that look like a golf ball, and mark your own 1-20 numbers on it, with the central ones appearing more times than the extremes.
Yes, Tinyboss, one step of the solution is determining how landing probability is calculated. At first, I thought it might just be a proportion of the surface area of a given face to total surface area, but perhaps angles influence that, too. In which case, it could be quite a complex calculation.
As for having a clearly defined "up face" -- I think the only additional requirement you would have to add is that the solid would have to have bilateral symmetry.
  • · Replies 25 ·
11K
  • · Replies 39 ·
