Can a magnetic fields/forces do work on a current carrying wire?
The discussion centers around whether magnetic fields can do work on a current-carrying wire, exploring the implications of magnetic forces in the context of electric motors and the behavior of charges within a wire. Participants examine theoretical aspects, practical applications, and the mechanics involved in such systems.
  • Some participants assert that magnetic fields can only do work on pure magnetic dipoles, citing the perpendicular nature of the magnetic force on a charge as the reason it does no work.
  • Others propose that while magnetic fields do not do work on charges directly, they can influence motion through internal forces within the wire, which are responsible for the work done in a motor.
  • A participant highlights that the torque in a motor is not directly caused by the magnetic field but rather by the contact forces between the electric current and the wire itself.
  • There is a discussion about the role of internal forces in maintaining the structure of the wire and how these forces interact with the motion of electrons, suggesting that these internal forces are crucial for understanding the system's behavior.
  • Some participants emphasize the importance of boundary conditions and constraints in analyzing the forces at play, noting that these factors are often overlooked in simplified explanations.
Participants do not reach a consensus on whether magnetic fields can do work on current-carrying wires. Multiple competing views are presented, with some focusing on the role of magnetic fields and others emphasizing internal forces and constraints within the wire.
The discussion reveals limitations in understanding the interactions between magnetic fields and electric currents, particularly regarding the assumptions made about forces and constraints in the system. The complexity of internal forces and their implications for motion are noted but not fully resolved.
  • #61
DaleSpam said:
I doubt that it is correct to say in a superconducting wire. In general, electrons are not little classical point particles, but in most normal situations it is probably an OK approximation.
However, superconduction electrons are not even approximately like that. They are in a very strange quantum state where an individual electron is literally not localizable to any location in the wire and all of the superconduction electron pairs share the same state.
I don't think that under those conditions the Lorentz force law for a point charge is correct.
Then in a normal non-superconducting loop. Are magnet's doing work?
  • #62
Miyz said:
Didn't really understand that point well... Could you elaborate more DaleSpam?
Here is a good page to begin understanding the forces between different configurations of magnets:
http://en.wikipedia.org/wiki/Force_between_magnets
A loop of current forms a magnetic field which is called a magnetic dipole. It is called that because it has the same mathematical form as an electical dipole (two point charges of equal and opposite polarity).
When a magnetic dipole is placed in a uniform external magnetic field it tends to align with the external magnetic field, this is how a compass needle functions. In a uniform field it experiences this torque, but no net force. However, in a non-uniform field it also experiences a net force, as described in the page above.
  • #63
DaleSpam said:
A magnetic field can certainly do work on a current carrying wire.
For example, consider a superconducting loop with current. Such a current carrying wire forms a magnetic dipole. A uniform external magnetic field can exert a torque, and a non-uniform field can exert a net force, both of which may be arranged to do work on the wire.
A magnetic field can not do work on a classical isolated point charge, but that doesn't prevent it from doing work on other things.
An isolated magnetic dipole can't exist without nonmagnetic forces that keep the current going in circles. The carriers in you superconducting loop are carrying the electric current through the wire. However, carrier would not move in circles unless an electric field applied a centripetal force to the carriers.
An electric field exists at the border of the superconducting loop, In addition, the superconductivity itself depends on forces other than the magnetic force. The conduction electrons in the "typical" superconductor are coupled by phonons to form Cooper pairs. The phonons are vibrational modes caused by the electric field of the nuclei of the atoms.
The force on a magnetic dipole by a magnetic field also has contributions from "nonmagnetic" forces. In fact, the example with the wire loop is also a magnetic dipole. Nonmagnetic forces make the carriers move in a closed curve, which generates a magnetic dipole.
  • #64
You are thinking of the superconduction electrons as classical little balls with a well-defined position and velocity and acceleration, it is simply an incorrect idea. A superconduction electron pair is not localized around the loop, there is no centripetal force because it is not accelerating. I.e. its wavefunction is not changing over time.
In fact, the electric field that you are describing does not exist in a superconductor. It is one of the defining properties of superconduction that the material cannot support such an E-field.
  • #65
If the loops was not a superconductor... Would the magnetic fields still be able to do work? On a regular loop. Generally what's you conclusion? Can magnetic fields do work on a current carrying loop?(That's not superconducting)
  • #66
Surly work being done here is by the magnetic force's...
  • #67
I mention the superconductor because it gets rid of a lot of the "smokescreens" that people try to put up in asserting that a magnetic field cannot do work. It shows that it is not impossible for a magnetic field to do work. Given that it is not impossible then I have no qualms about saying that the magnetic field in a motor does work on the wire.
The only formula which justifies the contrary applies only for classical point particles and is not a general law of nature.
  • #68
So F = q(V x B) Is only applied on the particle scale of things?
  • #69
+ Magnets are permanent dipole's
Current carrying loop is considered a temporary dipole?(No electricity not magnetic field)
  • #71
Thanks DaleSpam,
  • #72
Sounds reasonable.
Claude
  • #73
cabraham said:
Sounds reasonable.
Claude
I guess you and I stand corrected huh Claude? :-p
  • #74
It is very clear that the power of any electromagnetic field on charges is given, according to Poynting's theorem by
[tex]P(t)=\int_{\mathbb{R}^3} \mathrm{d}^3 \vec{x} \; \vec{E}(t,\vec{x}) \cdot \vec{j}(t,\vec{x}).[/tex]
Of course a motor does work, but it's the electric field according to the above equation.
  • #75
I believe that my earlier post (13) shows in some detail how this work done by the electric field (post 75) appears as work done on the wire as the wire moves. This electric field is set up by the battery connected across the wire. Throughout this thread I don't think there's been nearly enough emphasis on the battery as the source of the work that's done when the wire moves in the magnetic field.
[Incidentally, for a wire of cross-sectional area A, lying in the ±x direction and carrying current I, vanhees's formula yields
Work done per unit time in length [itex]\Delta x[/itex] of wire = [itex](A\Delta x) E_x (\frac{I}{A}) = I E_x \Delta x = -I \Delta V[/itex],
which is rather familiar!]
  • #76
Miyz said:
[..] As I said before and will continue to stand upon this point magnets can do work under certain circumstances. [..]
After skimming through this discussion, I wonder if this is the main point of misunderstanding. In your original post you referred to a permanent magnet. I don't believe that this magnet cools down in the process, and it certainly has no energy source. Obviously it does not output energy in the process.
Another, related possible point of confusion that I think has been mentioned earlier is that work is typically done through several intermediates, for example you can pull on something heavy with a rope, supporting the force with your feet on the street. Does one then say that the rope does work, or that the street does work? I think that that isn't a common way of formulating things; the permanent magnet acts like the street.
  • #77
Magnets, are no energy source. However, a source of force. That can do work in certain orientation example: MOTOR.
If you'd disagree please use equation's to back you're opinion. Because its a known fact the magnets can do work on a dipole(Repel/attract). Now in the case of a motor its stator that is winded up with coil wires generates a magnetic field and acts as a magnet(dipole) thus is attracted/repeled by the magnetic field of the magnets.
F = IL x B
If you break any system that is doing work, its just applying forces. In some complicated physical systems they apply MULTIPLE FORCES just like a motor.
DaleSpam gave out a good point, so as Claude, and Darwin123.
If you're still not convinced I'd recommend studying this matter more.
Miyz,
  • #78
Ow yea and don't Skimm since you might have skipped a lot of good info.
  • #79
Sigh! The equation, I've given is exact (within classical Maxwell theory). A nice paper about this question is the following one. The classical part of it precisely answers the question discussed here on hand of a simple example:
http://link.aps.org/doi/10.1103/PhysRevE.77.036609
  • #80
I noticed Maxwell's equations are relevant to this topic. What was his theories about this matter that some find it to be absurd?
  • #81
Miyz said:
Magnets, are no energy source. However, a source of force. That can do work in certain orientation example: MOTOR. If you'd disagree please use equation's to back you're opinion.[..]
DaleSpam gave out a good point, so as Claude, and Darwin123. [..]
Today vanhees gave you the equation you asked for, and also philipwood and I gave you good points. The most pertinent one is just your first sentence here: Permanent magnets are no energy source. That means that they do not give off energy, and most physicists mean with "doing work" that a system provides energy to one or more other systems.
Compare: http://www.lightandmatter.com/html_books/lm/ch13/ch13.html#Section13.1
The tractor does work, but the rope does not.
  • #83
DaleSpam said:
On the contrary, the magnetic field does store energy. That energy can be used to do work, every bit as much as the energy stored in a battery or a capacitor can.
To aid DaleSpam's point look at this.
  • #84
They don't "give off energy" they have magnetic fields that have potential energy. A wheel has not energy? But its the main source for transferring force, for work to be done, that eventually "TRANSFERS" energy.
  • #85
That WHOLE idea is irrelevant to this topic.
  • #86
After one turn the potential energy is identical - no change over one cycle. So, as Darwin already pointed out in post#30, it reduces to a disagreement about the meaning of words. In physics language the rope behind the tractor and the permanent magnet in the motor do no work - that has nothing to do with equations, just with definitions. :-p
That is, the definition of work and many explanations of how to deal with it "is irrelevant to this topic"... Well then, good luck!
  • #87
Thanks, I will give it a read before making more assertions about magnetic fields and work.
  • #88
I would say that whether or not the rope does work depends on where you arbitrarily draw your system boundary.
  • #89
http://en.wikipedia.org/wiki/Magnetic_field#Energy_stored_in_magnetic_fields
Miyz seems to think that you were talking to me. I did not mention the magnetic field, as my comment was on a post about the magnet. And sure the magnetic field can act like a spring. Moreover, a spring can do work. However, there is over one full turn of the motor no change in the field. The magnetic force of the OP is a force between the magnet and the coil, and the coil's field energy is provided by the current source.
Note: it seems fair to assume that the coil's magnetic field increases the permanent magnet's field energy - if so, then in that sense one could say that these fields do work, just after they were made/increased.
  • #90
I would say that such arbitrary conventions are not to be preferred. As described there, the system that looses the energy is the one that does the work. Anyway, I have no interest in discussions over words and supposedly that wasn't the purpose of this topic.
  • · Replies 30 ·
  • · Replies 36 ·
