Is There a Solution for Finding the Optimal Spring Design?
The discussion centers on optimizing spring design by determining the ideal combination of active coils (a) and wire diameter (d) for a spring that exerts 36.6 lbs of force when compressed to 20% of its available deflection. The user is attempting to find these values to maximize force at 80% compression. Key variables include shear modulus (G = 11.5 x 10^6) and diameter (D = 0.269). The user suspects potential errors in their algebraic formulation or computational translation of the equations.
  • Understanding of spring mechanics and design principles
  • Familiarity with algebraic equations and graphing
  • Knowledge of shear modulus and its application in spring calculations
  • Basic proficiency in computational tools for solving equations
  • Research the principles of spring design and optimization techniques
  • Learn about computational methods for solving nonlinear equations
  • Explore graphing tools to visualize spring force versus deflection
  • Investigate common pitfalls in algebraic manipulation of engineering equations
Mechanical engineers, spring designers, and anyone involved in optimizing spring performance in applications requiring precise force calculations.
WhiskeyHammer
I have an application involving a spring and in order to get the proper behavior, I need to solve the problem below. I've been at it for weeks and haven't been able to solve it - which tells me its time to appeal to my mathematical betters.
Given a spring that exerts 36.6lbs of force(N) while being compressed to 20% of its available deflection, find the combination of active coils(a) and wire diameter(d) that achieves the greatest force when the spring is compressed to %80 of its avilable deflection.
So basically I've boiled it down to the two values I need to solve for for each compression:
The closest I've come to something that makes sense is to solve for the first equation (the spring at 20%) in terms of a. Then Rework the second equation with th new value for a. However this seems to produce nonsense when graphed.
If its relevant the values for the other variables are as follows:
  • G= 11.5x10^6
  • D= 0.269
  • P= tan(12degrees)Pi(D-d)
If you need/want to see how I arrived at any of the above conclusions let me know and Ill put it up.
And this isn't a math problem from a book or anything like that, I structured it that way because its what I am comfortable solving.
Though if you think it might be better served in the Math area of the forum let me know.
Ive been thinking about it and theoretically what I was doing should have produced a workable result which tells me I possibly messed up at 3 points:
1) there is no solution to the first equation over my workable range (0,0.06725)
2) I messed up constructing the equation on paper (algebraic error)
3) I messed up translating the equation from paper to a computationally workable form
So for now I'm going to review point 1 and if it exists ill head over to the math section to verify my equations.
  • · Replies 18 ·
  • · Replies 39 ·
17K
