Work Energy Method for Rotational Motion
The discussion revolves around the application of the work-energy method in the context of rotational motion, specifically focusing on gravitational energy and the calculations involved in determining kinetic and potential energy for a system involving a rotating wheel and a hanging mass. Participants are exploring how to relate linear and rotational quantities in their calculations.
  • Mixed
  • Participants are attempting to calculate gravitational energy and are questioning whether to use the axle or wheel radius for their calculations. There is a focus on understanding the relationship between linear distance and angular displacement.
  • Some participants are clarifying how to compute kinetic energy for rotating objects and discussing the implications of setting a datum point for potential energy calculations.
  • Questions arise about the definitions of potential and kinetic energy, as well as the correct expressions for work done by forces in the system.
  • There is confusion regarding the separation of linear and rotational work, with participants seeking to understand how to apply the work-energy principle correctly.
The discussion is ongoing, with participants actively engaging in clarifying concepts and exploring different interpretations of the problem. Some guidance has been provided regarding the calculations of work and energy, but there is no explicit consensus on the correct approach yet.
Participants are working under the constraints of a homework assignment, which may impose specific requirements for how to define datum points and calculate energies. There is also a mention of potential confusion stemming from the problem's wording and the need to adhere to given parameters.
freshbox
I don't how how to work out for the Gravitational Energy "H".
Info given is 1.5rev converting to 9.42rad/s
S=rδ
S=0.2x9.42
=1.884
*Should i multiply the axle radius or wheel?
E1=K1+G1+S1
=1/2(8.5)202+(20)(9.81)(H)+0Thanks
Check the units for the 9.42
S=rδ
S=0.2x9.42
=1.884
What are you trying to calculate above?
E1=K1+G1+S1
Your expression for the kinetic energy is not correct. How do you calculate the kinetic energy of a rotating object? The hanging mass also has kinetic energy at the initial time.
Since the mass is located at the "datum" at the initial time, you can consider the potential energy to be zero at that time.
Sorry should be 9.42rad
S=rδ
S=0.2x9.42
=1.884
I am trying to calculate the distance for the height for gravitational energy
K=Iω2
Since v=rω
2=0.1ω
ω=20rad/s
what do you mean by potential energy? do you mean kinetic?
The equation should be:
1/2(8.5)(20)2+1/2(20)(2)2+G1+0
Rotational as "1/2(8.5)(20)2"
Linear as "1/2(20)(2)2"
G1-don't know how to form
S1 as 0 because there is no spring
S=rδ
S=0.2x9.42
=1.884
K=Iω2
Since v=rω
2=0.1ω
ω=20rad/s
OK, that looks good except for a factor of 1/2 in K.
All right. I didn't know what the symbols S and G were standing for. As you say, there's definitely no spring potential energy. For the gravitational potential energy, note that the hanging mass is located initially at the "DATUM". That's the point where the gravitational potential energy is taken to be zero. So, G1 = 0.
Did the box go down eventually? To my understanding yes because that question says in 1.5 rev" So that means the box travel 1.5 rev downwards.
So i set my datum point at the 1.5 rev point, hence there is gravitational potential energy at the initial position which i am trying to calculate but i don't know whether to use the axle or the wheel radius.
Yes. So, when you go to part (b) the box will be below the datum.
[EDIT: Did you use the correct radius for finding this distance?]
Hmm after some thinking, do you mean i have to follow the question datum and i cannot set the datum myself unless the question never state the datum in the 1st place?
You don't want to change the datum point. The answers you gave are for the datum shown in the picture. So, if you want to get the same answers, you need to keep the datum as shown.
The string tied to the box is wrapped around the pulley of radius 0.10 m. So, that's the radius you want to use to convert angle of rotation to linear distance traveled by the box.
For Part B
U1-2=T.δ+F.s
=(P)(9.42)+(P)(0.942)
For part (b) you just need to calculate the total energy at the final location. What is the kinetic energy there? What is the potential energy there?
[Sorry, that's for part (c)]
For part (b) you need to think about how to calculate the work done by a force. Do you know a formula for this?
I don't know I am just trying to calculate the linear and rotatational energy. This is getting confusing :cry:
Confusion is normal. We'll get it. The questions in the problem are sort of guiding you through step by step. So, in part (a) you find the initial energy. In part (c) you will find the final energy. For part (b), you just need to find an expression for the work done by the force P.
You have posted a couple of pages. One expresses the work in terms of force and distance, the other in terms of torque and angle. You can use either one of these expressions. They will yield the same answer.
For Part B
U1-2=T.δ+F.s
Wrong answer :cry: I assume my linear work done is correct. But my δ is definitely wrong.
*wait give me some time to work out
freshbox said:
For Part B
U1-2=T.δ+F.s
Use either force times distance or torque times angle. If you decide to use force times distance, the distance must be linear distance in meters. If, instead, you decide to use torque times angle to get the work, then you will need to express the torque in terms of P.
"Use either force times distance or torque times angle."
I thought there is linear and rotational? The parcel is moving downwards (linear) and the wheel is rotating (rotational)
The force P acts at one point and does some work. Your job is to express the work done by P. Since P acts in a direction opposite to the motion of the rim of the wheel, the work done is negative. The basic formula for work when the force acts opposite to the motion is
work = -Force.distance = -P.s
That will give you the total work done by P. (If you want to, you can express this work in terms of the torque exerted by P as work = -torque.angle).
Let's just stick with work = -P.s What value of s should you use? (Hint: you already calculated it in your first post.) Does this give you the answer for (b)?
I'm sorry i don't understand.
The question ask "Write an expression for work done by force P in stopping the wheel and axle"
Stopping the wheel - Wheel is rotating in the 1st place (Rotational Motion)
Stopping the axle - Parcel is tied to the axle (Linear Motion)
With reference to the screenshot below part C, the question ask for the work done by the frictional force on the drum,so it is only just the rotational motion and not linear motion.
So why do you say i can use either force times distance or torque times angle? But to my understanding linear and rotational exist, shouldn't i use both?
The force P acts over a distance equal to the arc length, s, that a point of the rim travels as the wheel rotates through an angle δ. The relation between s and δ is s = r.δ
The work done by P is just the force times the distance s: work = -P.s
But note that we could express this as work = -P.(r.δ) = -(P.r).δ = -T.δ = -torque.angle.
The force P does not do both "linear work" and "rotational work". The definition of work is just force times distance (when the force is parallel to the distance, as here). So, work = -P.s and that's it. It's just that sometimes you will see this work expressed as -T.δ. It represents the same work.
Then how do you explain this?
2nd diagram "Work done = Fs+Tδ"
I know there is rotational and linear motion.
They are calculating the work done by three different sources here. For the work done by the frictional torque of the flywheel, they use T.δ. For the work done by the force of friction on the slope they use F.s and for the work done by the 500 N force they use F.s.cosθ
They never use F.s + T.δ for the same force. It's either one or the other: F.s or T.δ
Can i say for post #1 question, linear and rotational motion actually exist, but i can use either force times distance or torque times angle to find the work done by P?
Yes :smile:
I'm sorry but I don't understand post #20. Can you explain the rationale behind again please?Thank you.
Well, I need to go shopping. Will be back later. Hopefully someone else can chime in.
Ok thank you for the help so far.
And if I just use U1-2=F.s
s=rδ
s=0.1x9.42
= 0.942
Subbing into formula:
=-P0.942 (Answer) Wrong.
May I know where did I go wrong?
s=rδ
s=0.1x9.42
= 0.942
Made it back. The force P is applied at the rim of the wheel. What radius should you use if you want the distance, s, that a point on the rim travels when the wheel rotates through 0.942 radians?
Thanks TSny, I managed to solved this question already.
Great! Good work.
