Can a magnetic fields/forces do work on a current carrying wire?
The discussion centers around whether magnetic fields can do work on a current-carrying wire, exploring the implications of magnetic forces in the context of electric motors and the behavior of charges within a wire. Participants examine theoretical aspects, practical applications, and the mechanics involved in such systems.
  • Some participants assert that magnetic fields can only do work on pure magnetic dipoles, citing the perpendicular nature of the magnetic force on a charge as the reason it does no work.
  • Others propose that while magnetic fields do not do work on charges directly, they can influence motion through internal forces within the wire, which are responsible for the work done in a motor.
  • A participant highlights that the torque in a motor is not directly caused by the magnetic field but rather by the contact forces between the electric current and the wire itself.
  • There is a discussion about the role of internal forces in maintaining the structure of the wire and how these forces interact with the motion of electrons, suggesting that these internal forces are crucial for understanding the system's behavior.
  • Some participants emphasize the importance of boundary conditions and constraints in analyzing the forces at play, noting that these factors are often overlooked in simplified explanations.
Participants do not reach a consensus on whether magnetic fields can do work on current-carrying wires. Multiple competing views are presented, with some focusing on the role of magnetic fields and others emphasizing internal forces and constraints within the wire.
The discussion reveals limitations in understanding the interactions between magnetic fields and electric currents, particularly regarding the assumptions made about forces and constraints in the system. The complexity of internal forces and their implications for motion are noted but not fully resolved.
  • #301
DaleSpam said:
I am sorry, but this is very funny advice coming from you. You are very closed-minded, and have shown no indication of even considering alternative viewpoints.
:rolleyes: Well... Thats because my knowledge about this matter is basic you and Claude are speaking an entirely different language I do not understand what you are all saying although I am trying to keep up! How could I show any indications far beyond the simplicity I've understood about this matter?
DaleSpam said:
I am torn on the subject, as should be obvious.
I noticed.
DaleSpam said:
I personally would like to be able to say that magnetic fields do work. But the math says that they don't on point charges. So I thought that dealing with non point charges was a loophole, but vanhees71's paper closed that loophole. And looking deeper into the math shows that the power density is E.j for a continuous distribution also. So my loophole is slammed shut.
Nobody else has shown another loophole that holds up, and both you and cabraham seem to avoid the discussion of the energy conservation equation entirely.
Well I didn't avoid that I just don't have any clue as I stated above. What makes sense to me the most is looking at the forces that actually are doing work. However, I speak nothing I do not understand of. I honestly don't know anything about this and its new for me. I'm only catching up and reading you're posts.
But again and again. I don't look at the energy conservation alone but... I look at the forces as well.
Because that matter is confusing as hell. I'd rather study it step by step to finally understand and discuss about it. Till then I'm a spectator.
It's wise for me to admit I know nothing of this matter and just let the experts do their work instead. If I did you'd seen me post a lot. All my post on E.J are nothing useful why? As I said before its new for me.
  • #302
andrien said:
these kinds of simple manipulation are not right.I would like to know about that B.Because so far I know E.J is rate at which electromagnetic field does work on the charges per unit volume and if B is magnetic field acting on charges in that volume,then for the case of an electromagnetic wave shinning on a hydrogen atom of certain frequency it will never be able to ionize the atom because in case of light E.B=0.Electric and magnetic fields are perpendicular to each other in light however strong it's frequency is.
But E & B are from interacting loops. Maybe E1, E2, B1, & B2 are more appropriate.
E.J is no problem, & is consistent w/ what I've presented. You acknowledge B as producing torque, yet you deny its work contribution. For the 4thtime please draw a sketch showing the fields doing work. All work is ultimately done by input power source. We have 2 loops. Each loop has E & B. It is the interaction that makes motors run. An e/m have not ionizing an H atom is too simplistic dealing w/ motors. Please draw us a pic. Thanks.
Claude
  • #303
DaleSpam said:
Yes, it does. x.0=0 for any vector, x.
E.j is a power density at every point in space. It is, in fact, zero everywhere outside the wire. Therefore, there is zero work done on matter outside the wire (since there is no matter there). This should be obvious.
Work is a transfer of energy. According to the equation I posted E transfers energy and B does not.
Look up dot product of 2 parallel vectors, non-zero if both are non-zero.
Your equation could be expressed in terms of J & B, so what? It doesn't prove that E is irrelevant.
But the E that transfers energy must include inductive, external to wire. If the stator winding is powered from 120 V rms ac, let's say the current is 1.0 amp, the winding ersistance is 1.0 ohm. Te voltage drop inside the wire is 1.0 volt, & the other 119 volts appears across the inductance as well as core loss, leakage reactance, etc.
You claim that E.J inside the wire accounts for all work. But if the wire is superconduction E is zero inside. You should reexamine that whole theory. I say with firm conviction that E.J must be based on total E, not just inside wire. We seem to have come to a stand still since you insist E is inside, I say E is both outside & inside. Until this is resolved it is pointless to argue. BR.
Claude
  • #304
I think we can show that the work done is clearly zero. The general expression for work is
[itex]W = \int_{\ i}^f F \cdot ds \ \ \ \ \[/itex] where F is the applied force and ds is the displacement from initial [itex]i[/itex] to final [itex]f[/itex] position
[itex]ds = \sqrt{\Delta x^2 + \Delta y^2 + \Delta z^2}[/itex]
This can be decomposed such that [itex]\ \ \ \ \ W = {\int_{\ x_i}}^{x_f} F_x \ dx + {\int_{\ y_i}}^{y_f} F_y \ dy + {\int_{\ z_i}}^{z_f} F_z \ dz[/itex]
According to the Lorentz force equation the force produced by the magnetic field is
[itex]F \ \ = \ \ q \ (v \times B) \ \ = \ \ q \ \langle v_z B_y - v_y B_z, \ \ v_x B_z - v_z B_x, \ \ v_y B_x - v_x B_y \rangle[/itex]
This can be broken down to the following equations
[itex]F_x \ = \ q(v_z B_y - v_y B_z) \ = \ q\ (\frac{\partial z}{\partial t} B_y - \frac{\partial y}{\partial t} B_z)[/itex]
[itex]F_y \ = \ q(v_x B_z - v_z B_x) \ = \ q\ (\frac{\partial x}{\partial t} B_z - \frac{\partial z}{\partial t} B_x)[/itex]
[itex]F_z \ = \ q(v_y B_x - v_x B_y) \ = \ q\ (\frac{\partial y}{\partial t} B_x - \frac{\partial x}{\partial t} B_y)[/itex]
Taking the integral with respect to x in the first equation gives
[itex]{\int_{\ x_i}}^{x_f} F_x \ dx \ \ = \ \ {\int_{\ x_i}}^{x_f} q(\frac{\partial z}{\partial t} B_y - \frac{\partial y}{\partial t} B_z) \ dx \ \ = \ \ 0[/itex]
And likewise for [itex]F_y[/itex] and [itex]F_z[/itex]
So the work done by the magnetic field is zero (because only the direction of the velocity changes not its magnitude). However, we're assuming in using the Lorentz force equation that it applies to an instantaneously steady magnetic field. There are no parameters in the force equation for dealing with a changing magnetic field.
  • #305
True, but j is 0 outside of the wire, therefore the dot product is 0 outside of the wire.
Weren't you going to look at a textbook last night?
A field at a location far from the wire cannot deliver power to a wire. That energy must first be transported to the location of the wire, and then it can be delivered to the wire.
It is obviously nonsense to claim that the E field a light year away from a wire can do any work on the wire now. For the same reason that is nonsense, it is also nonsense that the field a foot away or a millimeter away can do any work on the wire now. Only the fields at the location of the matter at a given time can deliver power to the matter at that time.
  • #306
Another thing to consider is that work and torque share the same dimensions and measurement units: [itex]\frac{ML^2}{T^2}[/itex] with measurements in [itex]N \cdot m[/itex].
In a pure numeric sense they're equivalent, but in terms of semantics work refers to force exercised over a linear displacement while torque refers to force exercised over a rotational displacement.
Can one simply say that a magnetic field produces torque? In order to use it to do work you need to find a mechanical means of converting the rotary motion into linear motion?
  • #307
The inner product between two vector fields is a scalar field; its value, just like the two vector fields, depends on position. If either of the two vector fields is zero at a specific location, their inner product will also be zero there.
Maxwell's equations, and the Lorentz Force Law both deal with vector fields. If you don't understand how to take the inner product of two vector fields, you don't fully understand Maxwell's equations.
Now, as for whether Magnetic field/forces do work on any classical system, the answer is fundamentally no. This assumes only that you take Maxwell's equations and the Lorentz force law as the basis for classical electrodynamics (which 99.9% of the current physics community likely does).
In many cases, the work done on an object depends on the value of the magnetic field applied to it, but this does not mean that the magnetic field is directly doing the work (and it isn't!).
  • #308
Do the followers of Gauss-Ampere-Weber make up the remaining 0.1%?
Respectfully submitted,
Steve
  • #309
Steve
I wouldn't count them as part of the physics community. I was thinking more along the lines of actual physicists who have just spent too much time staring at equations and now believe that all of physics can be described by tiny Leprechauns made of Ether throwing God particles at each-other in a giant game of dodge-ball.
/sarcasm
  • #310
I don't think that a field of any type does work but a force does.When F=Bev is summed for all of the current carrying electrons in a wire at 90 degrees to a B field the total force is given by F=BIL.If free to move in a vacuum these electrons follow circular paths and no work is done.Within the confines of the wire,however,any resultant motion of the whole conductor is in the direction of the force.I think it's safe to say that movement of the wire results in work being done.But is it being suggested that F=BIL,which comes from summing F=Bev is not a magnetic force?
  • #311
Good grief, you think I don't how to take the inner product of 2 vectors? Just who are you? Physicist, EE? How much education - Ph.D., MS, BS? You talk like I'm an 18 year old just out of HS. If I've erred, show me where & offer correction. You state your position that mag fields do no work, & offer nothing in terms of proof.
You are just 1 more talker who says "Claude you're wrong!" but then fails to follow through & show why I'm wrong. Prove your case, until you do all you offer is emoty word.
Clauide
  • #312
Force is a field.
Yes, this is due to the fact that there are other internal forces at play inside the wire. In this case, the only forces that directly contribute to the work on the wire are the internal electric forces that maintain the current (these of course are created by a battery or other power source providing a potential difference along the wire. cf. Example 5.3 from Griffith's Introduction to Electrodynamics 3rd edition)
The general idea is that since all of Classical Electrodynamics (including all composite force laws such as F=IBL) can be derived from The Lorentz Force Law, Maxwell's equations and some assumptions about the composition of certain macroscopic bodies (like a bar magnet, etc), one can treat [itex]\mathbf{F}_{ \text{mag} } = q \mathbf{v} \times \mathbf{B}[/itex] (the magnetic part of the Lorentz force law) as being the fundamental magnetic force and [itex]\mathbf{F}_{ \text{e} } = q \mathbf{E}[/itex] as being the fundamental electric force. All other EM forces are treated as composites. So, when one says that magnetic forces do no work, one is unambiguosly referring to [itex]\mathbf{F}_{ \text{mag, net } } = \int dq \mathbf{v} \times \mathbf{B}[/itex] as the magnetic force on an object (where the integral is over the object's volume/charge distribution)
  • #313
Clauide
I am only going by your previous posts.
cabraham said:
Outside the wire, I don't believe that the E.J value vanishes.
As Dale Spam has said, outside the wire the current density [itex]\mathbf{J}(\mathbf{r})[/itex] is zero, so the dot product of it with any vector field will also be zero there. Do you really need me to prove this to you?
  • #314
I'll find the textbook. But here is a flaw in your reasoning. If only the interior of the wire matters, E is zero inside a superconductor, herein SC. So E.J = 0, & you insist E.J = 0 outside the wire. So we have 0 power at the inpout hence 0 work done. But SC motors have been built & affirmed. They draw current from an input voltage source, store energy in fields, tranfer energy to output as rotor spins. Yet E.J = 0 for a SC.
How do you explain that one? Remember that the energy in a motor that transfers from stator to rotor is chiefly in the air gap. If the energy was all confined to the wire, how does it transfer? The stator L has a flux which is in the stator iron core, links to the rotor iron core via the air gap. This flux is energy, LI2/2. This energy does not appear in the E.J product inside the wire.
An example which is simpler to visualize is a 120 volt xfmr secondary driving a heater. The secondary winding resistance is 0.10 Ω, & the heater R is 11.9 Ω. The total is 12 Ω. Current is 10 amps. The power inside the secondary winding is 1.0V * 10A = 10W. If we only consider the inside of the sec winding, we get 10W, instead of 1200W total. Why is that?
The voltage across the sec terminals depends on path taken. Outside the Cu it is 119V, inside it is 1.0V. To get the total power you need to consider both. When both are accounted for we get 10 + 1190 = 1200W, the right answer. Once again we appear to agree on almost everything but for the inside/outside question. I will search for the text & post. BR.
Claude
  • #315
The applied magnetic field will penetrate the superconductor up to the London penetration depth. The E-field will also be, in general, non-zero up to that depth.
  • #316
In this case it isn't reasoning, that is just what the equations say. E.j is 0 anywhere E or j is 0. That is simply what E.j means. If you have a problem with it you need to take it up with Maxwell and Lorentz, they aren't my equations.
If you believe that the energy can transfer from a point in the air gap directly to the wire without passing through the intervening space then do you also believe that a field a light year away can transfer energy to the wire now?
Please do so.
  • #317
Claude
you did not really answer that.but apart from that I am saying it once again that magnetic field can not do work on electric charges because of lorentz force law so F.v is zero.but on a magnetic dipole the force is ∇(m.B) and it is not perpendicular to any velocity so it can do work.electric charges no work but magnetic charges there can be.
  • #318
Classically, magnetic dipoles are treated on the same footing as any other current distribution.
Specifically, the force on an ideal dipole [itex]\mathbf{m}[/itex] is derived (typically as an example in a textbook or as an exercise for the student - c.f. Problem 6.4 from Griffith's Introduction to Electrodynamics 3rd edition ) from the Lorentz force law by treating the dipole as a limiting case of a current loop (with current [itex]I[/itex] running through it), as the vector area [itex]\mathbf{a} \equiv \oint \mathbf{ \hat{n} } da[/itex] scribed/enclosed (subtended?) by the loop is shrunk to zero in such a way that the product [itex]\mathbf{m}=I \mathbf{a}[/itex] remains unchanged. Thus [itex]\mathbf{F}=\nabla( \mathbf{m} \cdot \mathbf{B} )[/itex] is regarded as a composite force law in the sense that it can be derived from the Lorentz Force Law and Maxwell's equations, like every other EM force law, and not a pure magnetic force. The work on a dipole in an external magnetic field must once again come directly from the electric field that maintains the current, which is produced by an unknown (classically) energy source (Of course, permanent dipoles like those associated with an electron's spin are really a quantum phenomenon, but classically they are treated as described)
True Magnetic charges (monopoles) have never been observed, despite the repeated efforts of many experimentalists, so whether or not a magnetic field does work on them is purely speculation.
  • #319
of course,but the result is of more general character then for any current loop.there is a mechanical energy associated with it amount to -m.B.the potential energy of the dipole from where the force formula comes.
  • #320
Somewhere in this huge thread, I've shown that this is no exception to Maxwell's theory. The power density is again given by
[tex]\vec{E} \cdot \vec{j}=\vec{E} \cdot (c \vec{\nabla} \times \vec{M}).[/tex]
In fact you can derive the coupled set of equations of motion for fields and matter by using the fundamental conservation laws from space-time symmetry, i.e., for total energy, momentum, and angular momentum.
  • #321
gabbagabbahey said:
Force is a field.
( FROM DADFACE-No,work done is force times distance not field times distance.Perhaps I am being nit-picky here.)
(FROM DADFACE_Extending this, the B field of the magnets is one of the factors that determines how much input power there is and how much is converted to mechanical power and how much is converted to electrical heating power losses.As I have stated before the mechanical power is given by
EbI {Eb=back(counter) emf,I= current})
THE NOTES ABOVE IN BRACKETS ARE FROM MYSELF(Dadface).WHAT IS A BETTER WAY TO HIGHLIGHT THEM? THANKS.
The section starting with "the general idea" is the point that interests me most.It might be considered as trivial because it is to do with definitions.It all boils down to the question:
Is the force F as given by F=BIL a magnetic force?
I find your notes above confusing.Reference to a "composite force" seems to suggest that it is not a magnetic force,so what,if anything,should it be described as? In a previous post I suggested(if I remember correctly)that it could be described as an electromagnetic force.
The notes go on to express an integral in terms of Fmag.net and then describe this as as "the magnetic force on an object".So is it a magnetic force or not?(A quick google lead me to the hyperphysics textbook which described it as a magnetic force)
If the wire contained just one moving electron BIl would equal Bqv, so if BIl is not regarded as the fundamental magnetic force it could be argued that nor is Bqv.For N electrons F=NBqv=BIl.The electrons may be in a wire which restricts their movements but the force on each one is still Bqv.
  • #322
Hi vanhees.I would be interested to hear your answers to the following:
1.Can the force BIl do work?
2.Would you describe BIL as a magnetic force or otherwise?
Thanks if you can find the time to answer.
  • #323
My take on the original op question is that a magnetic field can exert torque but do no work.
If a put a weight on a frictionless horizontal bar I can increase or decrease at will the torque or moment around each support without input of any effort/work/joules. So torque and work done are different concepts.
If I hold 2 equal poles of a permanent magnet close together and let go the 2 magnets will push each other away and therefore it looks like the magnetic fields are doing work. However in the process of flying apart there are always electrical fields involved, since there are traveling magnetic fields. The Poynting vector shows the flow of energy.
The question of HOW energy reaches the rotor of a motor is an entirely different problem.
Earlier studies of the Poynting vector and the rate of flow of energy considered only idealized geometries in which the Poynting vector was confined to the space within the circuit. But in more realistic cases the Poynting vector is nonzero outside as well as inside the circuit. An expression is obtained for the Poynting vector in terms of products of integrals, which are evaluated numerically to show the energy flow.
The above reference is not the only one I have come across in the past. As to how reliable the above source is I really don’t know.
Just to make again another point: LI2/2 does exist but has nothing to do with the output power of a motor. Asked for references are in short supply.
  • #324
Then if magnetic field/force do no work. Then what does it do in this system?
We all agreed that the main source of doing work is the current throughout the wire. Work is done due to multiple forces interacting with each other. Not only by the magnetic field/force.
By saying the magnetic field/force do no work that makes no sense. Although its a known fact that magnetic field's do work on dipoles.
A loop is technically is a dipole.
Im not familiar fully with the equations. However, in the process of studying them.
Only equations I do know: F= q(v x B) , F = IL x B
Both applied on different states.
  • #325
Miyz, it is really a bit disturbing that you obviously do not read my answers. I have clearly demonstrated by using Maxwell's equations that not the magnetic field is doing work on a magnetic dipole but the induced electric field. If you don't agree with that simple calculation, tell me where you think I (or all physicists since Maxwell ;-))) made a mistake!
  • #326
I do apologize.
Maxwell's equations to me personally is not fully understood. So I can't judge or say anything till I do understand them all.
Be back soon. Till then.
  • #327
I think dividing the quote up into sections that you wish to respond to and responding outside the quote is the best way. Adding text to a quote is usually considered a no-no.
Force is still a vector field, for example the force on a point charge [itex]q[/itex] placed at location [itex]\mathbf{r}[/itex] (relative to some origin) in an external electric field [itex]\mathbf{E} ( \mathbf{r} )[/itex] is [itex]\mathbf{F} ( \mathbf{r} ) = q \mathbf{E} ( \mathbf{r} )[/itex]. Its value depends on the position of the charge, since the electric field, in general, varies in space.
Is this just a general note, or are you trying to make some point about magnetic force and work here?
Certainly, the force on the current [itex]I[/itex] through a wire in an external magnetic field [itex]\mathbf{B}[/itex]
[tex]\mathbf{F}_{ \text{mag} } = \int dq\mathbf{v} \times \mathbf{B} = \int I d \mathbf{l} \times \mathbf{B}[/tex]
is a magnetic force, but it is incapable of doing work on the charges that make up the current (and hence on the wire) since it is everywhere perpendicular to the current (motion of the charges).
There are situations, where it appears as though this force is doing work (again, c.f. Example 5.3 from Griffith's Introduction to Electrodynamics 3rd Ed.) but these can all be shown to be due to whatever other agent which maintains the current.
  • #328
Can you be more specific? Which system in particular are you talking about here? I have seen multiple systems mentioned in this thread, so I am unsure which one you are referring to in this instance.
But magnetic fields don't do work on dipoles. The net force on a (ideal) dipole in an external magnetic field is given by [itex]\mathbf{F} = \mathbf{ \nabla } ( \mathbf{m} \cdot \mathbf{B} )[/itex], and this net force certainly does work (and depends on the magnetic field), but it is not truly a magnetic force.
Then this discussion is probably very difficult to follow for you, but will likely make more sense once you've continued your studies of Electrodynamics.
  • #329
On a loop.
I believe you use this law F = qv x B to argue that magnetic field/force do no work at all? Since it can't do work on a charged particle and charged particles flowing through a conductor makes no difference?
So you agree that magnetic fields do no work in ANY CASE directly or indirectly?
Look at this.
  • #330
Please have a look at #255 in this thread.
The best discussion on this issue concerning macroscopic electromagnetics can be found in Landau-Lifgarbages's textbook (vol. 8 of the textbook on theoretical physics). There the whole issue of work and electromagnetic fields in matter is treated using (relatively simple) thermodynamics, and there it's stressed that magnetic fields do not do work on charge and current distributions.
  • · Replies 30 ·
  • · Replies 36 ·
