Flawed Vector Space Example: Showing Failures of Commutativity and Associativity
The discussion revolves around a specific example in linear algebra concerning a set defined as S={(a_1,a_2):a_1,a_2 ∈ ℝ} with a non-standard addition operation defined as (a_1,a_2)+(b_1,b_2)=(a_1+b_1,a_2-b_2) and scalar multiplication defined as c(a_1,a_2)=(ca_1,ca_2). Participants are tasked with demonstrating that this structure does not satisfy the axioms of a vector space.
  • Participants discuss the failure of commutativity and associativity in the defined addition operation, with one participant attempting to verify these properties. Questions arise regarding the validity of their findings, particularly concerning associativity and the distributive law.
Some participants have confirmed their understanding of the failure of commutativity and are exploring associativity. One participant has indicated they believe they have resolved the associativity issue, while others are still working through the distributive law. There is an ongoing exchange of ideas and verification of concepts related to vector space axioms.
Participants are referencing a specific textbook and are navigating the complexities of vector space definitions for the first time, indicating a learning context with potential gaps in understanding. There is mention of specific axioms that may be failing, particularly related to the distributive property.
miglo
let [tex]S={(a_1,a_2):a_1,a_2 \in \mathbb{R}}[/tex] For [tex](a_1,a_2),(b_1,b_2)\in{S}[/tex] and [tex]c\in\mathbb{R}[/tex] define [tex](a_1,a_2)+(b_1,b_2)=(a_1+b_1,a_2-b_2)[/tex] and [tex]c(a_1,a_2)=(ca_1,ca_2)[/tex].
show that this is not a vector space
vector space axioms
this isn't an exercise in the book, but an example from the book that states that commutativity and associativity of addition and the distributive law all fail, so this in fact is not a vector space
i tried working these out and i think i got commutativity one right
because then you have [tex](a_1+b_1,a_2-b_2)[/tex] does not equal [tex](b_1+a_1,b_2-a_2)[/tex] is this correct?
i got stuck on associativity, i worked it out but to me it seems that it does in fact hold true
haven't check the distributive law though
the book I am using is linear algebra by friedberg, insel and spence, second edition
vector space axioms
Yes, that is correct.
"Associativity of addition" would require that ((a1, b1)+ (a2, b2))+ (a3, b3)= (a1+ b1)+ ((a2, b2)+ (a3, b3)). What do you get for each of those?
Distributivity requires that (a1, b1)((a2, b2)+ (a3, b3))= (a1,b1)(a2,b2)+ (a1,b1)(a3,b3). What do you get for each of those?
nevermind i just checked my work again and i think i figured it out
for associativity we end up with
[tex](a_1+b_1+c_1,a_2-b_2-c_2)[/tex] on the left side while the right side gives us
[tex](a_1+b_1+c_1,a_2-b_2+c_2)[/tex]
which aren't equal, so this shows associativity of addition fails right?
im going to work on the distributive law, if i get stuck on that ill post back on this thread for help
first time working with vector spaces, so I am just trying to make sure i get this right before i actually start my linear algebra class in the fall haha
thanks hallsofivy
looking back into my book I am not even sure if its the distributive law that fails
my book says VS8 fails which is for a,b of elements in F(field) and each element x in V
(a+b)x=ax+bx, is this the distributive law? it doesn't look like the one you posted hallsofivy
anyways i checked it using x,y as the elements of the field
[tex](x+y)(a_1,a_2)=(xa_1+ya_1,xa_2+ya_2)[/tex] and [tex]x(a_1,a_2)+y(a_1,a_2)=(xa_1,xa_2)+(ya_1,ya_2)[/tex]
both sides are not equal so it fails that axiom
  • · Replies 17 ·
