Lumens and photon flux density
Calculating photon flux density from lumens produced by a fluorescent tube requires knowledge of the spectral power distribution (SPD) and the radiation pattern of the light. The SPD provides essential data about the light's wavelength distribution, while the radiation pattern helps in understanding how the light is emitted in space. These two factors are critical for accurate calculations, as lumens alone do not provide sufficient information for determining photon flux density.
  • Spectral power distribution (SPD) of fluorescent light
  • Understanding of radiation patterns in lighting
  • Basic knowledge of photometry
  • Familiarity with lumens as a measure of light output
  • Research methods for obtaining spectral power distribution (SPD) data
  • Learn about different radiation patterns of light sources
  • Explore photometric calculations for converting lumens to photon flux density
  • Investigate tools for measuring light intensity and distribution
Lighting designers, photometric engineers, and anyone involved in the analysis of fluorescent lighting performance and its effects on environments.
DMS-Aberdeen
Is there a simple way of calculating photon flux density from the lumens produced by a fluorescent tube?
Not exactly. You need to know the spectrum (spectral power distribution, or SPD) of the fluorescent light, and the radiation pattern. The SPD should be available, and you could estimate the radiation pattern.
  • · Replies 24 ·
  • · Replies 28 ·
