How High Does Jane Swing on the Vine?
  • Thread starter Thread starter d.tran103
Jane runs at 5.5 m/s and grabs a vine hanging 4.3 m from a tree. The discussion focuses on calculating how high she can swing upward using the principles of potential energy (Pe) and kinetic energy (Ke). The calculation shows that she swings up to a height of approximately 1.5 m above her starting point, or 2.8 m below the top of the vine. There is uncertainty about the accuracy of this result, with the poster considering the possibility of a different gravitational constant affecting the outcome. The final conclusion is that Jane swings up to a height of 1.5 m, but this answer was not accepted, prompting further inquiry with the professor.
d.tran103
Jane, looking for Tarzan, is running at top speed (5.5 m/s) and grabs a vine hanging 4.3 m vertically from a tall tree in the jungle. How high can she swing upward?
Pe=mgh and Ke=1/2mv^2
Can someone tell me if I'm doing this correctly? I have one submission left.
So Pe becomes converted to Ke at the bottom of the swing. And then Ke at the bottom of the swing becomes converted back to Pe. Pe at release is 0 since the vine is hanging vertically. So I have Pe(initial)*0+Ke(initial)=Pe(final) or Ke(initial)=Pe(final)
1/2*m*vi^2=m*g*hf
1/2*vi^2=g*hf
1/2*5.5^2=9.8*hf
hf=1.54337 m.
Height swung upwards=hi-hf
h=4.3-1.54337=2.8 m
Is this correct? Thanks!
Well Jane will swing up to a point 1.5 m vertically above her start point. Or 2.8m below the top of the vine. So how high does she swing up?
Okay thanks. My first answer was 1.5 however, it wasn't accepted. I'm thinking that the logarithm is using some weird value for g? I'll just ask my professor. Thanks again
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
