For each real number x, let f(x) be the minimum of the numbers 4x+1,
  • Context: Undergrad
  • Thread starter Thread starter azizlwl
    Minimum Numbers
The discussion revolves around the function f(x), defined as the minimum of the expressions 4x+1, x+2, and -2x+4 for each real number x. Participants are exploring the maximum value of this function, considering the nature of the problem and the range of x.
  • Homework-related
  • One participant asks for the maximum value of f(x) based on its definition.
  • Another participant questions whether the problem is a homework assignment.
  • A later reply clarifies that it is not a homework problem but references a source, "The Advanced Mathematical Thinking," suggesting a reversal tactic for solving it.
  • Several participants inquire about the range of x, questioning if it can be any real number, an integer, or a subset.
  • One participant suggests that the minimum of the functions will vary depending on the subsets of the domain considered and proposes a method to construct a piecewise function based on which expression dominates in different intervals.
Participants express uncertainty regarding the range of x and whether the problem is homework-related. There is no consensus on the maximum value of f(x) or the approach to solving it.
Participants note that the solution may depend on the subsets of the domain considered, indicating that different approaches could yield different results.
azizlwl
For each real number x, let f(x) be the minimum of the numbers 4x+1, x+2, and -2x+4. What is the maximum value of f(x)?
Is this a homework problem?
No, Sir.
It is too taken from The Advanced Mathematical Thinking where the author said it can be solved by reversal tactic.
Sorry if it is incomplete since I copied whatever written in the book.
Is there a range for these numbers, i.e., is x any real number, integer, subset of these
or other?
or other?
http://img214.imageshack.us/img214/5270/35240583.jpg
2.https://www.physicsforums.com/showthread.php?t=632495
http://img850.imageshack.us/img850/1995/68878748.jpg
Well, the reason I was asking is that , if the minimum of these numbers is done
over different subsets of the line, then the results will be different. The solution
is straightforward: compare the functions and see which of the three dominates
over which part of the domain, and construct a piecewise function: set
f1>f2 ,f1>f3 , f2>f3 , etc., and select, for each interval the smallest.
  • · Replies 24 ·
  • · Replies 17 ·
  • · Replies 36 ·
