Japan Earthquake: Nuclear Plants at Fukushima Daiichi
The discussion revolves around the technical aspects and current status of the nuclear plants at Fukushima Daiichi following the earthquake and tsunami in Japan. Participants are seeking reliable information regarding the operational conditions, safety measures, and potential risks associated with the nuclear reactors in the aftermath of the disaster.
  • Some participants express skepticism about the reliability of media reports and emphasize the need for technical information from official sources like TEPCO and METI.
  • There are concerns regarding the reactor pressure levels, with reports suggesting that pressure may have exceeded safe limits, which some participants describe as a significant issue.
  • Questions are raised about the likelihood of a meltdown, with differing opinions on whether this is a realistic concern or media exaggeration.
  • One participant explains the role of coolant in a nuclear power plant, noting that it is essential for cooling the reactor and managing decay heat after shutdown.
  • There is discussion about the reactor's ability to be scrammed (shut down) and the implications of losing coolant, with some participants clarifying that decay heat continues to be produced even after shutdown.
  • Concerns are raised about the explosion of the containment building and its implications for safety, with speculation about the potential release of radioactive materials.
  • Participants discuss the wind direction at the time of the explosion and its potential impact on the dispersion of any radioactive materials released.
Participants do not reach a consensus on the likelihood of a meltdown or the implications of the current situation at Fukushima Daiichi. There are multiple competing views regarding the severity of the situation and the reliability of information being reported.
Participants note the limitations of available information, including the reliance on second-hand reports and the challenges in verifying the status of the reactors and containment structures. There are also unresolved questions regarding the operational status of safety systems and the exact nature of the explosion.
  • #13,651
tsutsuji said:
27 August 2012 government-Tokyo Electric mid and long term response committee, steering committee (9th meeting)
3-1 Cooling by closed loop water injection
http://www.meti.go.jp/earthquake/nuclear/pdf/120827/120827_01j.pdf Nitrogen injection into unit 1's suppression chamber
2) Translation:
01/11
02/11
03/11
  • #13,652
2) Translation:
04/11
05/11
06/11
  • #13,653
2) Translation:
07/11
08/11
09/11
  • #13,654
2) Translation:
10/11
11/11
  • #13,655
We all owe a vote of thanks to Tsutsuji-san for his extraordinary work.
Without his efforts, there would be essentially no ongoing english language coverage of this unprecedented engineering effort. Instead, we are getting almost real time updates on the clean up as it progresses.
I am impressed by the effort put forth, even though we can deplore that this huge investment will at best be a dead weight loss to the Japanese economy.
  • #13,656
Those four units were a loss to the Japanese economy as soon as the tsunami hit and took out the ECCSs followed by flooding with seawater. The recovery (and decontamination and decomissinoning) adds more to the loss column. They also lost the infrastructure and housing that was destroyed by the tsunami - not to mention the loss of life.
The cost to replace the power plants on the order of $billions.
  • #13,657
Hear Hear, thank you Tsutsuji!
  • #13,658
Yes, Tsutsuji has made a tremendous and effective effort to keep us informed. I absolutely appreciate it.
  • #13,659
The burden of the Chernobyl clean-up was no small part in the collapse of the Soviet Union either...
  • #13,660
Thanks everybody for the encouraging comments. I have started translating http://www.meti.go.jp/earthquake/nuclear/pdf/120827/120827_02c.pdf "Progress status of development of machinery and equipments to prepare fuel debris removal" which will give a glimpse of the research & development planned by Toshiba/Hitachi/Mitsubishi over the longer term. But this will take me quite some time as these are 34 pages, some of which are rather dense.
The first diagram:
  • #13,661
mscharisma said:
I'm having a bit of trouble understanding how they measure injection rates given that they can't actually look inside the reactors and see what arrives inside the vessel. And not knowing exactly where the core(s) is (are) and temperature gauges not necessarily working well or at all, I somehow can't seem to wrap my head around how they determine how much water is needed and, hence, whether or not it is getting to where it is needed.
Could someone here maybe offer a "dumbed-down" explanation for a non-technical person like me how this is done?
Many thanks.
No takers or too dumb or complicated a question? Thanks.
  • #13,662
What _can_ they do, except do trial adjustment of injection while monitoring temperature trends. I'd expect them to be pretty 'familiar' by now with what can be expected by the beasts they are handling, although as you point out they are beasts pretty much inside black boxes.
  • #13,663
I assume that the reported injection rates are those measured before and/or after the pumps and that they don't know how much water actually reaches the damaged cores. But as MadderDoc says: It's not that important whether those numbers reflect the exact amount of water reaching the reactor insides but whether adjusting those rates changes other measurable parameters (temperature, pressure) at various measuring points.
  • #13,664
mach i think a simple heat balance suffices
they know the boundaries and how much they're pumping in and about how much heat the core is making, so they also know what should be conditions exiting those boundaries;
successful control of temperature coming out confirms those expectations.
  • #13,665
They also used crude but informative observations during the period last year where they were still trying to find the right balance. For example at reactor 2 they had seen steam from containment entering the upper building levels. When they looked again later (perhaps September) after making various changes to water flow rates & location , they saw no steam and the paint had flaked off of the overhead crane, suggesting the atmosphere was now much less humid.
They shouldn't have used the term cold shutdown, since that implies a routine state and this situation is anything but, and the term 'relatively stable' is fairer in my book. Relative to how unstable the reactors were earlier on, newsworthy events in the reactors that can be detected by humans have been few since the early months.
Knowledge about the state of the cores is obviously far more limited than we'd like, but its not surprising that it will take years to learn more. In the meantime I don't think many would claim that the available monitoring data is perfect, especially at reactor 2 where there are far too few correctly functioning temperature monitoring devices working in many important parts of the reactor. Indeed when many of these sensors started to go wrong, resulting concerns about reactor 2 temperature rises were the biggest safety scare we've had for a long time, until they decided it was faulty sensors rather than actual temperature rises. I think they just lost another temperature sensor at reactor 2 the other day, although it may not yet have officially been declared as broken quite yet. So they better hope the mission to try fitting replacement sensors works, though its certainly not an easy mission and the state of the reactor core may well be responsible for the problems they have already faced with an 'obstruction' at the end of the pipe they originally wanted to use. In the meantime they will just have to rely on temperature indications in other parts of the reactor, and observations such as the steam one I mentioned earlier.
  • #13,666
Some bits and bobs:
Over at Fukushima Daini reactor 4 they are going to open the top of containment and remove the RPV lid, steam dryer & separator on September 10th.
http://www.tepco.co.jp/en/press/corp-com/release/betu12_e/images/120903e0403.pdf
The latest building integrity study of Daiichi reactor 4 found a few more cracks but nothing they think is significant. One of the photos that was originally part of this release caused a small internet stink because they had crudely photoshopped out the area of the west wall where the truck bay used to be before they demolished it. In response to the complaints they simply reissued the photo with the section cropped out instead of painted over, and mention security of nuclear material as the justification. Personally I do not suspect they were hiding anything too interesting, so its another one of those stories which is more about crude censorship backfiring, suspicion and lack of trust in official information than anything else. Anyway, here is the report:
http://www.tepco.co.jp/en/nu/fukushima-np/images/handouts_120830_02-e.pdf
More recent attempts to discover the cause of the reactor water injection flow rate decreases are discussed in the September 7th plant status press release. The temperature sensor that has become suspect at reactor 2 is also mentioned:
http://www.tepco.co.jp/en/press/corp-com/release/2012/1218114_1870.html
  • #13,667
At this stage I sometimes wonder if I have missed any technical reports, so I was going through some older stuff and found an english document from June 15th that I don't think I have talked about before:
Technical knowledge of the Accident at Fukushima Dai-ici Nuclear Power Station:
http://www.nisa.meti.go.jp/english/press/2012/06/en20120615-1-1.pdf
It does not cover everything, or contain new information not seen elsewhere, but the areas it does look at are covered in pretty clear english.
Those interested in the containment equipment hatch at reactor 3 may be interested to check pages 33-37, where it discusses possible containment leak points at the reactors. They look at radiation levels detected at different points in the different reactors, and also analysis of hydrogen behaviour. They are quite clear to mention the possibility of leakage from the 'machine hatch' at reactor 3. Plenty else is discussed too, I just thought Id mention that one since on this thread we had quite a lengthy discussion about the equipment hatch at reactor 3, back when TEPCO sent a camera into that area. But as usual TEPCO were not talking usefully about leaks, leaving us to come up with our own narrative to go with the images.
  • #13,668
I forgot to mention there is also a large set of diagrams for that report:
http://www.nisa.meti.go.jp/english/press/2012/06/en20120615-1-2.pdf
For example diagrams relating to hydrogen leak point modelling are on pages 101-106 and pages 118-122 deal with the effect that an open blowout panel can have on hydrogen buildup.
  • #13,669
http://www3.nhk.or.jp/news/genpatsu-fukushima/20120907/index.html The US National Academy of Sciences heard Tepco employees about the Fukushima Daiichi accident. Some tough remarks were made such as "Why wasn't there specialists on the site, able to give guidance about the condenser [the IC, I guess] ?", "there are problems with Japan's basic safety philosophy" (compared with the measures taken in the USA in consequence of the 9-11 terrorist attacks, like preparing manuals for worse case situations, and for the loss of offsite power with back-up power sources).
See also http://www.rttnews.com/1961281/tepco-quizzed-over-fukushima-preparedness.aspx?type=gn&Node=B1 (English)
  • #13,670
tsutsuji said:
27 August 2012 government-Tokyo Electric mid and long term response committee, technical development progress headquarters (8th meeting) ( http://www.meti.go.jp/earthquake/nuclear/20120827_02.html )
Document 2
http://www.meti.go.jp/earthquake/nuclear/pdf/120827/120827_02c.pdf Progress status of development of machinery and equipments to prepare fuel debris removal
1) Previous related topics:
http://www.tepco.co.jp/en/press/corp-com/release/betu11_e/images/111221e14.pdf (English) p. 54/94-94/94: "Research and Development Road Map for Decommissioning Units 1~4 at TEPCO's Fukushima Daiichi Nuclear Power Plant" (1st meeting of the Government-TEPCO Mid-and-long Term Response Council, 21 December 2011)
2) Translation: [installment 1: abstract]
01/34 (1/4)
01/34 (2/4)
  • #13,671
01/34 (3/4)
01/34 (4/4)
  • #13,672
02/34 (1/3)
02/34 (2/3)
02/34 (3/3)
  • #13,673
tsutsuji said:
Tepco is saying so in the note at the bottom of http://www.meti.go.jp/earthquake/nuclear/pdf/120827/120827_01d.pdf page 1:
効率的な冷却のため,7/27,8/13に注水流量を減少させた結果,原子炉関連温度は上昇傾向を示しており,引き続き傾向監視を継続している。
Because cooling is efficient, water injection rate was reduced on 27 July and 13 August, and as a result, reactor related temperatures are indicating a rising trend. As a follow-up, we are continuously monitoring the trend.
Okay, so we have had slightly rising temperatures in June/July, subsequently a chiller installed, and then deliberately reduced water injection rates at stable temperatures. At the end of August, we have injections rates that inexplicably dropped below the required amounts and, one has to assume, again rising temperatures as at least one of the indicators for or results of that. (By the way, thanks to everyone who responded to my question how injection rates and what gets to the core is measured.)
Bottom line seems to be, temperatures are rising. No?
And we (or TEPCO) assume(s) its because its summer and/or because something is clogging up the pipes or valves or whatever.
And so here's my new question: with so many unknowns and variables, is the real message/news here not that temperatures are rising for uncertain reasons and we're all guessing why, likely including TEPCO?
  • #13,674
Document 2
https://www.physicsforums.com/showthread.php?p=4064968&posted=1#post4064968 Translation [installment 1: abstract]
Translation [installment 2: remote decontamination]
03/34 1/4
03/34 2/4
03/34 3/4
  • #13,675
03/34 4/4
04/34 1/2
04/34 2/2
  • #13,676
05/34
06/34
07/34
  • #13,677
In some ways you could say that about many aspects of the disaster since day one. Thats why far more speculation has been allowed on the Fukushima topic than would normally be tolerated on a forum that holds the values of science dear.
But even at worst its still fairly educated guessing, often supported by more than one kind of observation or test.
In the case of these temperature changes its not hard for TEPCO etc to compare the ambient temperature, amount of sunlight and other weather issues with flow rates and the history of temperatures at the reactors, and to work out whether what is happening is within the bounds explained by seasonal variations. And let's not forget that the actual temperature increases have really not been anywhere close to substantial enough to warrant much exploration of alternative hypothesise.
And as for the flow rates, the drops in water injection rates seen since late August were certainly substantial enough for them to investigate. It now seems likely that a change of pipework at that time lead to foreign objects in the buffer tank, in this case plastic shavings:
http://www.tepco.co.jp/en/nu/fukushima-np/images/handouts_120911_02-e.pdf
  • #13,678
tsutsuji said:
]27 August 2012 government-Tokyo Electric mid and long term response committee, technical development progress headquarters (8th meeting) ( http://www.meti.go.jp/earthquake/nuclear/20120827_02.html )
Document 2
https://www.physicsforums.com/showthread.php?p=4064974&posted=1#post4064974 Translation [installment 1: abstract]
https://www.physicsforums.com/showthread.php?p=4068601&posted=1#post4068601 Translation [installment 2: remote decontamination]
Translation [installment 3: PCV leakage points identification]
09/34 1/2
09/34 2/2
10/34
  • #13,679
11/34 1/2
11/34 2/2
12/34
  • #13,680
http://www3.nhk.or.jp/news/genpatsu-fukushima/20120912/0745_syasin.html Tepco is releasing 600 photographs taken from 11 March 2011 to 28 March 2011. "Because of bad coordination within the company, we were not able to fully grasp the photograph status and were late to release them. It is possible that more unreleased pictures are remaining, so we are checking in order to release them", they explain. Pictures showing accumulated water in power equipment rooms in unit 1 and unit 2 turbine buildings are included.
http://photo.tepco.co.jp/index-j.html [the 600 new pictures are in the links numbered (1) to (40)]
50K
  • · Replies 41 ·
  • · Replies 2K ·
60
470K
21K
  • · Replies 763 ·
284K
  • · Replies 38 ·
17K
12K
