Determining the Shape of a Water Clock: How to Find the Flow Rate?
The discussion focuses on determining the shape of a water clock, specifically a conical tank, to achieve a drainage volumetric flow rate proportional to the square root of the liquid height (h^(1/2)). The participants conclude that the volume of the conical water clock must be expressed as V(h) = (pi*R^2*h^3)/(3L^2) and that the derivative of volume with respect to time must equal k*h^(1/2), where k is a proportionality constant. The use of Torricelli's Law is recommended to relate the outflow rate to the column height, aiding in the solution of the problem.
  • Understanding of fluid dynamics principles, specifically Torricelli's Law
  • Familiarity with calculus, particularly differentiation of volume with respect to time
  • Knowledge of geometric properties of conical shapes
  • Basic engineering concepts related to volumetric flow rates
  • Study the application of Torricelli's Law in fluid dynamics
  • Learn about the derivation and application of the volume formula for conical shapes
  • Explore the relationship between flow rates and liquid height in conical tanks
  • Investigate additional resources on the calculus of volume changes over time
Engineering students, fluid dynamics enthusiasts, and anyone interested in the mathematical modeling of fluid flow in conical tanks.
jbarker91
1. Homework Statement
Hi guys,
A few friends and myself are having some trouble determining how to go about solving this problem for our engineering class.
"An emptying tank in which the water level drops at a constant rate in time can be used as a water clock. Consider a tank where the drainage volumetric flow rate is proportional to h^(1/2), where h is the liquid height. What must be the shape of the tank so that the draining vessel may be used as a water clock?"
The shape of the water clock isn't given, but we all know it's a conical water clock, where the flow rate isn't constant, but dh/dt is, which allows for a linear scale to be read from. The goal is to prove that it the volume is a conical shaped water clock or the flow rate is equivalent to what was stated in the problem. We can assume it's a conical water clock to prove that it equates to the flow rate.
2. Homework Equations
There weren't any equations given, but this is the most generic form used for this engineering type problem.
d/dt(p*V) = p*Qe
3. The Attempt at a Solution
We've attempted multiple different ways, but it ultimately ended up in the same situation.
I started with
dV(h) = A*dh; A = pi*[r(h)]^2
r(h)=(R*h)/L, where R is the radius of the top of the cone, and L is the height of the entire water clock.
Took the derivative with respect to time and set it equal to the flow rate
dV/dt = (pi*R^2*h^2/L^2)*dh/dt = k*h^(1/2), where k is a proportionality constant.
This is where we continuously get stuck at, because we see no way to get an h^(1/2) from anywhere.
You're on the right track, I think what you may be missing is the relation of outflow rate (dV/dt) with column height. This is probably most easily adapted through the use of http://en.wikipedia.org/wiki/Torricelli's_law]Torricelli's[/PLAIN] Principle which is basically a simplified Bernoulli relation showing the flow speed of an orifice can be balanced with the potential energy in the water column. In other words, ignoring effiency concerns the speed water exits an orifice can be approximated as v = sqrt(2*g*h).
You will probably also appreicate this PDF which might help you clarify the calculation you're trying to achieve: http://www.math.usma.edu/people/rickey/hm/CalcNotes/clepsydra.pdf
  • · Replies 16 ·
  • · Replies 24 ·
