Why Don't Rotations Contribute to the Average Energy of a Monatomic Gas?
The average energy of a monatomic gas particle is primarily attributed to its translational motion, amounting to 3kT/2, as rotational degrees of freedom are generally not considered. This is due to the quantum mechanics effect where the rotational energy levels are quantized, with the first excited state being significantly higher than kT/2, resulting in most particles remaining in the ground state at room temperature. While rotational energy may become relevant at higher temperatures, for typical conditions, it is assumed that monatomic gases do not rotate. Additionally, internal degrees of freedom, such as electronic transitions, can contribute to heat capacity but require much higher temperatures to be significant. Overall, the assumption of no rotational contribution holds true for monatomic gases under standard conditions.
sanbyakuman
Greetings, this is my first post, though I have been reading these forums for a while.
I understand that the average energy of each degree of freedom in a thermodynamic system in equilibrium is kT/2. My textbook says that for a monatomic gas particle, the only degrees of freedom that count are movement in three dimensional space, so the average energy of such a particle is 3kT/2.
My question is, why don't rotations contribute toward the average energy? My textbook suggests that this is because the moment of inertia is vanishingly small. However, my thought is that if the moment of inertia is very small, it just means that the particle would be spinning extremely fast in order to reach an average energy of kT/2 for each rotational axis.
sanbyakuman
Your description is one of classical physics. You are correct: rotational energy may be significant.
Try these sections in this link:
http://en.wikipedia.org/wiki/Heat_capacity#The_storage_of_energy_into_degrees_of_freedom
The effect of quantum energy levels in storing energy in degrees of freedom
Energy storage mode "freeze-out" temperatures
It should be noted that it has been assumed that atoms have no rotational or internal degrees of freedom. This is in fact untrue. For example, atomic electrons can exist in excited states and even the atomic nucleus can have excited states as well. Each of these internal degrees of freedom are assumed to be frozen out due to their relatively high excitation energy. Nevertheless, for sufficiently high temperatures, these degrees of freedom cannot be ignored. In a few exceptional cases, such molecular electronic transitions are of sufficiently low energy that they contribute to heat capacity at room temperature, or even at cryogenic temperatures. One example of an electronic transition degree of freedom which contributes heat capacity at standard temperature is that of nitric oxide (NO), in which the single electron in an anti-bonding molecular orbital has energy transitions which contribute to the heat capacity of the gas even at room temperature.
If that was correct, you need a way to apply forces to a particle to make it spin very fast. It's not very obvious how that would work.
Making an unsymmetrical object like a diatomic molecule spin isn't a problem. All you have to do is hit one end of it in a collusion, for example.
sanbyakuman
Its a quantum mechanics effect. The rotational energy of a monatomic gas particle is quantized, it has a ground value of zero, and then it jumps to a non zero energy for the first (rotationally) excited state, and then a higher number for the second, etc. If the energy of the first excited state is much, much larger than kT/2, then there won't be many particles in that state, or any higher state. For all practical purposes you can say that all particles are in the ground state - that is, they are not rotating. For a monatomic gas at room temperature, this is the case. If you raise the temperature of a monatomic gas high enough, there will be a significant number of particles in the first and possibly higher excited states, and then you cannot assume that they are not rotating, and the average energy per particle will be higher than 3kT/2.
single atoms are considered to not be able to rotate. this is taught in basic statistical mechanics. there are electronic degrees of freedom but they require such high temperature to excite for most molecules that they don't play a major role.
Thanks everyone for your replies. I understand now.
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
