Friction and rolling resistance, and work done queries
The discussion revolves around the concepts of friction, rolling resistance, and work done in the context of wheels and vehicles. Participants explore the mechanics of how wheels turn, the forces acting on them, and the implications of different types of friction in various scenarios, including inclines and vehicle dynamics.
  • Some participants propose that when a wheel turns, the forward-acting friction is opposed by rolling resistance, questioning if successful movement indicates that friction exceeds rolling resistance.
  • There is a discussion about the forces acting on the back wheels of a car, with some suggesting that static friction from the road is responsible for forward movement, while others clarify that rolling resistance is not friction but energy lost due to tire deformation.
  • One participant raises a question about the work done against gravity being the same for different inclines, while noting that work done against friction varies, leading to confusion about how these forces interact.
  • Concerns are expressed regarding the applicability of the work-energy equation in incline scenarios, with some participants affirming its general validity.
  • There is uncertainty about the role of high-friction tires and their relationship to rolling resistance, with some questioning how frictional forces act on non-driving wheels and their contribution to turning motion.
  • Participants discuss the nature of static and kinetic friction, noting that static friction prevents movement up to a certain point, while kinetic friction is dependent on the normal force.
  • Some participants clarify that once non-driving wheels are turning, they require no additional force to maintain speed, while others mention the need for torque to counteract frictional forces.
  • There is a debate about the purpose of high-friction tires, with some asserting that they do not aid rolling but rather increase the threshold for skidding.
Participants express multiple competing views regarding the nature of friction, rolling resistance, and their implications in various scenarios. The discussion remains unresolved, with differing interpretations and understandings of the concepts involved.
Participants highlight limitations in their understanding of how forces interact in different scenarios, particularly regarding the roles of static and kinetic friction, and the effects of incline angles on work done against friction.
This discussion may be useful for individuals interested in the mechanics of motion, vehicle dynamics, and the principles of friction and work in physics.
  • #31
sgstudent said:
hi tiny tim, i was thinking about the problem with the wheels again so for the non-driving wheels shouldn't the friction be forwards also? Since by torque they are both having the same direction ( as in turning direction)
the angular acceleration and the linear acceleration have to be balanced …
the direction of friction is decided by which one is too big for the other​
for the driving wheels, there was angular acceleration from the engine
for the non-driving wheels, there is no angular acceleration from the engine
also, when principle of moments occurs where there is no net moment where clockwise moment=anticlockwise moment can there be rotation? Like even constant speed rotation or will there be always no net moment?
at constant angular speed, the net moment is zero
  • #32
Hi tiny Tim! :smile: thanks for the help all this while so for the driving wheel is positive work being done? Doc Al said no here: https://www.physicsforums.com/showthread.php?t=92895 but in your previous post it was otherwise..
Also I came across a weird moments question. They asked me to find the moment about a point to lift a trap door. I'm not sure if I can use principles of moment here cos lifting it requires a net moment but then again constant speed moment can also occur. So I'm sure how does this work..
Thanks for the help tiny Tim you rock!
  • #33
no, i think Doc Al said that kinetic friction always does negative work, but static friction can do positive work
(eg static friction on a rolling driving wheel is what accelerates the car)
they're talking about constant speed moment!
the minimum force necessary is the force that gives zero acceleration (anything less doesn't open the trap door, anything more isn't the minimum)
(the net moment is of course the applied moment plus the moment of the weight)
  • #34
Hi Tim! :smile: it makes more sense this way. So when a car travels at constant speed is the forward friction equal to the backwards friction (non driving wheels) then when the forward wheel's friction is equal to the turning of the wheel such that the forward friction is equal to the turning force at the point of contact? Will the backwards resistance change accordingly since it is still static friction at the backwheels?
Also how do I tell when a moment will travel at constant speed or stay motionless when a equilibrium occurs similarly how do i tell when net force is 0 whether it is constant or 0 speed. Thanks for the help
  • #35
yes :smile:
… then when the forward wheel's friction is equal to the turning of the wheel such that the forward friction is equal to the turning force at the point of contact? Will the backwards resistance change accordingly since it is still static friction at the backwheels?
not following you :confused:
at constant speed, there is no turning force from the engine (i'm assuming we're ignoring air resistance etc)
if the net force is zero, the speed stays whatever it was in the first place :confused:
  • #36
Like when I pull that trapdoor the net moment is 0 but there is constant speed while when a ruler is place on a pivot and two objects resting on both sides and moment is 0 it there is no movement of the plank even though in both cases net moment is 0 so how do I tell if an plane will move with constant speed or 0 speed at all. Thanks for the help!
  • #37
it depends what the angular speed was just before the net moment was zero
for the trap door, you had to get it moving at that angular speed by using a slightly greater applied moment, and then when you reckoned that the angular speed was just right, you reduced the applied moment so that the net moment was zero
  • #38
Oh so it depends on the angular speed before I reduce the moment to 0 does it work the same as for forces. Like if I apply a force then when I stop applying force (assuming no friction or retarding force) then it will stay at that speed forever? Thanks for the help!
  • #39
sgstudent said:
… Like if I apply a force then when I stop applying force (assuming no friction or retarding force) then it will stay at that speed forever?
that's absolutely correct :smile:
also, if you apply a force to a body that is impeded by friction, then if you stop increasing the force when it balances the friction force, it will stay at that speed forever
  • #40
tiny-tim said:
yes :smile:
Hi tiny tim! :smile: After discussing this with my friend using our O level knowledge, we came to a conclusion. But we have some queries.
So firstly, we have our driving wheel on the air and the engine is turned on. So the Free Body Diagram would look like this: http://imgur.com/xVk0w
So in this case the net force of the wheel is 0N as F2 and F1 are equal in magnitude. However, about F1, there is a net moment which turns clockwise (F1XL).
Then now we put it on the ground and and experiences a friction oppsoing F1 as friction opposes force in a single plane of contact. So now, the Free Body Diagram would look like this: http://imgur.com/Pw1oh
From this, since F2-F1=0N, so the net force=friction only. While the wheel still has to maintain its clockwise moment so F1L > FrictionL and since L is a constant, so F1>Friction.
So from here, it all makes sense to us, but then after thinking again since that friction force that we have been dealing up to now is static friction so shouldn't F1 be equal to friction? But if F1 is equal to the friction, the the wheel would not be able to turn in the first place.
So we were stuck at this part with no solution in mind. Could you help us out with this? Thanks :smile:7
  • #41
hi sgstudent! :smile:
first, can i check that we mean the same thing by "driving wheel"?
a driving wheel is one that is forced to turn by a torque from another part of the vehicle
a non-driving wheel is one that simply receives a (linear) force from another part of the vehicle, or another vehicle (or animal)
so we normally draw the free body diagram of a non-driving wheel with a straight arrow, usually from the centre of the wheel, representing the force
while we draw the free body diagram of a driving wheel with a small circular arrow (anywhere), representing the torque
alternatively, we can represent that torque by two equal and opposite straight arrows, but although i agree we could place them anywhere, it would be normal to place them equal distances above and below the centre of the wheel …
your arrow at the bottom of the wheel may be confusing you, since the bottom of the wheel has no significance
of course, as shown, the centre of the wheel will stay where it is, but the wheel's rotation will accelerate​
again, the position of F1 at the bottom of the wheel has no significance, it could be anywhere (so long as FL equals the torque)
in this case, the wheel's rotation will accelerate slower than before (because the friction is an opposing torque about the centre of mass), but the centre of the wheel will (linearly) accelerate​
i did the calculation for a non-driving wheel in post #14
do the calculation for this driving wheel, and you should see that there is no difficulty :smile:
i don't understand why you say "since that friction force that we have been dealing up to now is static friction so shouldn't F1 be equal to friction?"
static friction is not µN, or any other formula, it is simply the horizontal component of the total reaction force at the surface …
and the reaction force is always calculated (even in non-rotational cases, such as a static ladder) as the "missing" force that has to be inserted to make the equation (between the known forces and the geometric constraint of the surface) balance …
so the static friction can be anything between 0 and µN :wink:
  • #42
Hi Tiny Tim, it has been a while! :smile:
Yup, we have the same defination of the wheel whereby the force is actually turning it. But again for the engine i was thinking the force turing it looks like this: http://imgur.com/8doMX
whereby the engine has an axle to push against to turn it. So in air/ice one force (by the engine) would be at the wheel's end and one at the centre of the wheel (equal in magnitude) which prevents it from moving forward? So it is something like this: http://imgur.com/h4wg3 I think this picture would work even if its not a car as wheelchairs use the same pinciples where the person sitting would push the wheel for it to turn.
So after googling about this topic for a long while i came across a old post by you haha. This was what you said: A car moves forward because the engine forces the back axle to turn.
If the car was on ice, the back wheels would spin, but the rest of the car would be still.
The torque from the engine causes a force at the bit of the tyre in contact with the road. So long as that force does not exceed the maximum static friction, that force will equal the actual friction force, and the bit of the tyre in contact with the road will not move.
(Newton's first law on that bit of the tyre: zero total force means zero change in movement.)
The car will move, because the only external horizontal force on it is the actual friction force.
So i understand now that the F engine=Static friction (without slipping though). But if F engine=Static friction, the won't the net moment be 0Nm and as a result, the wheel should not even be able to start turning (if we consider the wheel to be at rest initially). Even if the wheel has a net force which is the friction (http://imgur.com/uMQjk).
So I don't understand how the wheel can rotate. The car and wheel experiences a net force but no net moment. So I'm pretty confused about this.
Also, another thing that I'm confused is that in the wheelchair/driving wheel example, the wheelchair bound person would push the wheel only at the top, so would that mean the static friction at the bottom would have the same magnitude (http://imgur.com/Kafh6)? What allows this phenomenon to happen since the force is not at the same point of each other?
Thanks Tiny Tim, you rock! :smile:
  • #43
sgstudent said:
… But again for the engine i was thinking the force turing it looks like this: http://imgur.com/8doMX
no, even at zero acceleration, you also have to include the reaction force from the load
in all cases, the equations come from two free body diagrams: one for the wheel, and one for the load (or for the wheel-and-load combined) …
in particular, the first one will include the reaction force between the wheel and the load …
i think it's your failure to include that that is confusing you​
… in the wheelchair/driving wheel example, the wheelchair bound person would push the wheel only at the top, so would that mean the static friction at the bottom would have the same magnitude (http://imgur.com/Kafh6)? What allows this phenomenon to happen since the force is not at the same point of each other?
try writing out the actual equations, one for the wheel and one for the person (including the reaction force between them in each), and using the same linear acceleration for both …
what do you get? :smile:
  • #44
Hi tiny tim :smile: because we haven't learned any theory on this so we don't really know any equations besides F=ma and moment=Fd.. Also, what was that reaction force you mentioned? Thanks!
  • #45
sgstudent said:
… we haven't learned any theory on this so we don't really know any equations besides F=ma and moment=Fd.. Also, what was that reaction force you mentioned? Thanks!
the only other equations you need are τ = Iα (total moment of force = moment of inertia times angular acceleration), and the "rolling constraint" v = ωr, a = αr …
just do F = ma for the person, and τ = Iα for the wheel (about the centre of the wheel), remembering to include the reaction force ±R in both (it'll be + for one and - for the other) :smile:
the reaction force is the "internal" (linear) force between the axle-and-wheels and the body of the wheelchair …
it's what pulls the body! …
for each part separately, it's an external force, of course :wink:
(technically, there's also a reaction torque, from the friction between the axle and the body)
  • #46
Hi Tiny Tim, are there any pictures because i can't virtualise that. I was thinking the forces should look like this: http://imgur.com/WNSV7
Firstly, will my F friction = F push? Because of static friction.
So using the formula, the net F=F friction for the wheel but for the person on the seat the net F= 0?
As for moment of the wheel, it is 0Nm?
I'm getting realize confused about this now. Is there a explanation for this concept? Because I'm really curious about this haha. Thanks :smile:
  • #47
i'm sorry for the delay
first, it's a lot better if you stop using "F" for all your forces: use eg P for push, F for friction, R for reaction etc
for the free body diagram of the person, there's two horizontal forces …
(i'm ignoring all vertical forces)
… the push force (same as the reaction force) from the wheel onto the person's arm, and the friction force from the seat
together, they make the mass of the person times acceleration​
for the free body diagram of the wheelchair, there's three horizontal forces …
… the push force (same as the reaction force) from the person's arm onto the wheel, the friction force from the person onto the seat, and the friction force from the ground
together, they make the mass of the wheelchair times acceleration​
of course, you can also do a free body diagram for the wheel on it own, or for the person and the chair combined (excluding the wheel), or for the person the chair and the wheel all combined
(for the wheel on its own, there's also a small friction torque from the axle of the wheel onto the wheel)
there's only two forces, so Fpush - Ffriction = ma (which is 0 only if a = 0)
if a = 0, yes
if α = 0, yes (otherwise, it's Iα) :wink:
  • #48
if a = 0, yes
Hi Tiny Tim :smile:
But i thought the Fpush must always be equal to Ffriction as the Ffriction is static friction. So does it mean that the torque of the wheel will be just the friction from the person to the seat? Thanks :smile:
  • #49
if the rider is accelerating, then the friction force from the seat must be more than the force on his arm from the wheel, mustn't it? :wink:
  • #50
But how is that possible? Isn't the push force equal to the static friction?
  • #51
which static friction?
the push force from his arm on the wheel equals the static friction force on the top of the wheel (it's just another name for it)
but that doesn't equal either of the other two friction forces (on the seat, and on the ground) unless the acceleration is zero
  • #52
Hi tiny tim! I thought the static friction of the push is the friction from the ground?
  • #53
well, you push the wheel of a wheelchair using static friction also (and there's static friction on the seat)
anyway, nothing equals anything else unless the acceleration is zero​
  • #54
Oh but since the friction acting on the wheels by the ground is also static friction, then shouldn't there be a push force that is equal to the friction on the ground? What would that push force be and since the push force is equal to the static friction on the wheel how can there be a net force?
  • #55
hi sgstudent! happy new year! :smile:
no, the push force P on the top of the wheel is forward
and the friction F from the ground is also forward
for example, if there is a horizontal wind resistance force of W, and if the acceleration is zero,
then P = F (because the angular acceleration is zero), and so P = W/2 :wink:
  • · Replies 59 ·
  • · Replies 30 ·
  • · Replies 77 ·
