Buoyancy Correction: Is Equation 1 Correct?
  • Context: Undergrad
  • Thread starter Thread starter thedy
    Buoyancy Correction
The discussion revolves around the correctness of a specific equation related to buoyancy and mass, particularly focusing on the equation mass=density(density-density). Participants are exploring the implications of this equation in the context of air correction and dimensional analysis.
  • One participant questions the correctness of the equation mass=density(density-density), noting a dimensional inconsistency when applying the equation.
  • Another participant asserts that mass should be calculated as mass=density * volume, suggesting that multiplying densities is not appropriate.
  • A different participant seeks confirmation on the dimensional analysis, emphasizing that the right side of the equation does not yield units of mass.
  • One participant expresses confusion over the meaning of density(density-density), questioning the rationale behind multiplying a density by the difference of two densities.
  • A later reply proposes a different formulation for buoyancy correction, indicating a potential alternative approach to the problem.
Participants exhibit disagreement regarding the validity of the original equation and its dimensional consistency. Multiple competing views on how to approach the problem remain unresolved.
There are limitations in the clarity of definitions and assumptions regarding the densities involved, as well as the context of the air correction being discussed.
thedy
Is this equation correct?
equation 1: mass=density(density-density)
Im asking this because in air correction we have equation 2: mass=density(density-density)/density(density-density) -----here we get mass.But get we mass still in this case?:mass=density(density-density)
Because I was trying to derive this using a dimension principle,but it doesn t fit in equation 1,because:m=kg/m3*kg/m3 which is kg2/m6 and this doesn t equal to mass.
Please try to explain me this by using dimension principle as well.
Thanks
Mathematics news on Phys.org
Mass = density * volume. Why would you ever multiply densities?
If you are considering an 'air correction', it sounds like you're confusing mass with weight.
Thanks,I just want to know if mass=density(density-density) is correct,because as I said,mass has kg unit and right side of equation has kg2m6,so I think,that it is impossible.But I just want to ensure...Am i right?
I don't understand what you mean by density(density-density). Do you really mean taking the difference of two densities and multiplying another density? That would be bizarre. Where are you getting that from? And what are these two or three densities the densities of?
That should be
buoyancy correction=(volume sample-volume standard)density atmosphere
  • · Replies 16 ·
  • · Replies 23 ·
