What is the process for designing a bolt joint for a static assembly?
The discussion focuses on designing a bolt joint for a static assembly, specifically calculating the number of M6 Button head screws needed to support a 40 kg door panel under a lateral force of 700N. Participants emphasize the importance of determining the shear strength of the bolts for shear joints or tensile strength for tension joints. They recommend using material properties from suppliers or standard tables found in Bickford or Shigley, as these resources provide essential data for accurate calculations.
  • Understanding of bolt joint design principles
  • Knowledge of shear and tensile strength calculations
  • Familiarity with M6 Button head screws specifications
  • Access to material property tables from Bickford or Shigley
  • Research the shear strength of M6 Button head screws
  • Learn how to calculate tensile strength for bolt joints
  • Explore the design methodologies outlined in Bickford's "Introduction to the Design and Behavior of Bolted Joints"
  • Study the relevant chapters in Shigley's "Mechanical Engineering Design" for additional insights
Mechanical engineers, structural designers, and anyone involved in the design and analysis of bolted joints in static assemblies will benefit from this discussion.
gunneet
I have to calculate the number of M6 Button head screws required to hold a door panel of 40 kg when 700N (calculate at the center line of the mounting holes) of force is applied laterally. I want to consider only lateral case when the force is applied perpendicular to the door panel. Any idea for this case I will really appreciate.
Basically, If someone explain me that how to design the bolt joint for a static assembly of 2 parts that will give a direction.
Thanks
There are many different ways to model a bolted joint, some very complicated. You might check out Bickford if you have an interest in those details.
But to keep it both simple and safe, first find the shear strength of the bolts if you have a shear joint, or the tensile strenth if it is a tension joint. Divide the total load by the number of fasteners to find the strength of the joint. I normally get my material properties for my fasteners from the supplier, or from standard generic tables in Bickford or Shigley. (Bickford wrote the bolt chapter for Shigley, so they are the same.)
  • · Replies 18 ·
  • · Replies 22 ·
9K
