Difference between blast, shock, pressure and sound waves?
The discussion centers around the differences between blast waves, shock waves, pressure waves, and sound waves, particularly in the context of explosions. Participants explore the characteristics, behaviors, and effects of these wave types, as well as their implications in various scenarios, including space shuttle launches.
  • Some participants seek to understand the distinctions between blast, shock, pressure, and sound waves, particularly regarding their roles in explosions and damage causation.
  • One participant notes that shock waves travel faster than sound waves due to their intensity heating the gas medium adiabatically, affecting the speed of sound.
  • Another participant describes pressure waves as general disturbances that can be classified as sound waves, emphasizing that any amplitude could be perceived as sound with a sensitive enough device.
  • A participant explains that a blast wave is a type of pressure wave generated by an explosion, which may or may not be classified as a shock wave depending on the explosion's nature.
  • Discussion includes the mechanics of shock waves, detailing how they can create significant pressure spikes and dynamic pressures that contribute to damage.
  • Participants mention the effects of detonating bombs at ground level versus in the air, noting the differences in pressure and dynamic pressure resulting from reflected shock waves.
  • Some participants express interest in the educational context of these topics, questioning their presence in first-year physics curricula and their relevance to engineering disciplines.
Participants do not reach a consensus on the distinctions and implications of the different wave types, indicating multiple competing views and unresolved questions regarding their characteristics and effects.
Some participants highlight that shock waves and related phenomena have been phased out of traditional physics curricula in favor of topics like quantum mechanics and relativity, suggesting a shift in educational focus.
This discussion may be of interest to students and professionals in physics, engineering (particularly aerospace and mechanical), and those studying acoustics or fluid mechanics.
autodidude
What are the differences (I'm really trying to understand the differences in the context of an explosion). When you hear it, are you hearing all 4 waves? Which waves cause the damage and why - why not the others?
Also, when NASA launches the space shuttle, they release water to absorb the 'acoustical energy', these are soundwaves?
EDIT: I read somewhere that a sound wave turns into a pressure wave if exceeds some dB - what happens to it here?
One thing that distinguishes a shock wave from a normal sound wave is that it travels faster than what we typically call sound. This is because its intensity is such that it significantly heats the gas media adiabatically. The speed of "sound" is an increasing function of temperature. The wavefront is pushing into undisturbed air, so the excess velocity is not due to the immediate effect of the pressure at the front. What happens is that any other pressure waves behind the front in the region of significantly excess pressure propagate faster than the front, and therefore catch up with the front and help it push that much harder.
See also "Partin Brisance".
They are all essentially the same phenomena with different amplitudes... in a sense.
A pressure wave is just a general term for a pressure disturbance moving through a medium. This happens to be exactly what a sound wave is. These disturbances move at the speed of sound in the medium in which they are traveling. There is no formal distinction between the two, as any amplitude of pressure wave could be heard as sound provided the listening device was sensitive enough.
A blast wave would be a pressure wave created by an explosive blast. Depending on the nature of the explosion, it may or may not be a shock wave.
A shock wave is a specific type of pressure disturbance moving through a fluid (or stationary in the fluid depending on the situation. Consider a pressure wave (sound wave) moving through a fluid. For small amplitudes, the wave passes by and the medium more or less returns to its initial state. However, if the amplitude is large enough, it will drag a little bit of the air along with it. That means any sound waves propagating behind it will tend to catch up with the original wave and drag the fluid behind them still faster. That process stacks up and eventually you can have a number of pressure waves coalesce into a shock wave.
Shocks waves are near discontinuous changes in pressure, velocity, temperature and density in the fluid (changes occur over 6 or so mean free paths between molecules). To the stationary observer, they can appear to be moving faster than the speed of sound, though they will always be traveling below the speed of sound in the medium out of which they are propagating, even if they are traveling faster the speed of sound in the medium into which they are propagating.
When an explosion occurs such that a shock is generated, a few things happen when the shock passes over you. First, there is a sharp rise in pressure, temperature and density, so that pressure spike itself can do a lot of damage. However, at least as important is the flow behind the shock. When the shock passes, it is dragging an awful lot of fluid with it. In fact, the flow being dragged behind the shock can even be supersonic if the shock is strong enough! The potentially high velocities combined with high density behind the shock means that a lot of the real damage correlates with the incredibly high dynamic pressure behind a passing shock wave.
As a quick example, if you were to explode a bomb at ground level such that the shock was moving at Mach 1.8, the simple shock wave that passes by would cause the pressure to spike to about 3.6 times the ambient pressure. Additionally, say the ambient pressure was 0.3 atm and the ambient temperature was 220 K. You would have over 0.5 atm of dynamic pressure behind that passing shock as well due to an induced velocity of just shy of 310 m/s. That is where a lot of the damage comes from.
However, consider a second case. A bomb is usually detonated in the air such that the shock is coming down at the ground at an angle. That results in not only the original shock, but a reflected shock, which effectively compresses the flow twice. The pressure would increase almost 10 times over ambient! The induced velocity doesn't change much, but because of the increased pressure and density, the dynamic pressure would now be roughly twice as high as the single shock case. That is why bombs are usually detonated in the air and not at ground level.
That probably went a lot farther in-depth than you wanted. Oops. :blushing:
Thanks very much guys!
@Hetware: Are you referring to the Oklahoma City lectures on Youtube? I'm going to watch that now
@boneh3ad: No way - the more details the better!
By the way, do you generally get to learn this in first year physics (if not, what subjects would it usually be taught under?). I have a 'Physics for Scientists and Engineers' text and it doesn't really go into this sort of stuff
Shock waves and pressure waves and the like were originally typically part of physics curricula, but they were phased out years ago to save time for things like quantum mechanics and relativity. These sorts of things are primarily fluid mechanic phenomena and fall under various engineering disciplines most of the time these days, most notably aerospace and mechanical engineering. It would be given quite a bit of treatment in any physics department doing acoustics research as well.
Yeah I did them for my mechanical and aerospace engineering degree. My Undergrad and Masters theses were pretty much simulating shock waves at around mach 15-20. That's funny bonehead, your answers are usually vague or extremely detailed... that answer in particular is awesome. I was going to write a couple of sentences.
It all depends on my mood and how swamped I am with real work. Generally the more swamped I am, the more detailed my answer since (A) I am already in work mode and (B) I'll take any excuse possible to procrastinate. Take right now, for example, when I am supposed to be writing up some stuff for a review session for my class tomorrow.
  • · Replies 236 ·
18K
17K
  • · Replies 22 ·
22K
13K
