What is the L'Hospital proof problem regarding limits at a point?
  • Context: Undergrad
  • Thread starter Thread starter pk1234
    Proof
The discussion revolves around understanding a specific part of the proof of L'Hospital's rule, particularly the conditions under which the limit of the ratio of derivatives exists and the implications of those conditions. Participants explore the nature of functions and their derivatives in the context of limits approaching a point.
  • One participant seeks clarification on why the derivative of g, g', must be finite and non-zero in the interval around a when the limit of the ratio of derivatives exists.
  • Another participant argues that the limit existing implies that the fraction f'(x)/g'(x) must be a specific real number, which cannot happen if g'(x) is zero or infinite.
  • There is a discussion about the nature of real-valued functions and the definition of limits, with emphasis on the distinction between ratios of numbers and limits of ratios.
  • Some participants express confusion over the treatment of 0/∞, questioning whether it is defined or not.
Participants express differing views on the conditions necessary for the limit to hold, particularly regarding the finiteness of g' and the implications of having g' equal to infinity. The discussion remains unresolved, with no consensus reached on these points.
Participants highlight limitations in understanding the definitions and properties of derivatives, particularly in relation to limits and the behavior of functions near a point.
pk1234
Hey guys, first year university math student here. I need some help explaining the proof used in the scripts I'm studying from - just part of the proof to be more precise. English isn't my first language and I don't have much experience writing/rewriting down proofs and I don't know how to write those nice latex symbols, so sorry in advance if something doesn't make sense:
Presuming:
(1), a is element of R (|a| =/= +oo)
(2), f and g are real functions
(3), limit x->a_+ (f'(x) / g'(x)) exists (must be element of R, or +-oo)
(4), limit x->a_+ (f(x)) = limit x->a_+ (g(x)) = 0
then
limit x->a_+ (f(x))/(g(x)) = limit x->a_+ (f'(x))/(g'(x))
I think I understand most of the proof but there's something right at the start that I'm completely stuck at and still don't understand precisely enough:
Let L=limit x->a_+ (f'(x) / g'(x)).
There exists delta>0, such that for all x element of (a,a+delta), f and g are both defined on this interval,
- I think this can be proved easily from (4), correct? Also, |f| and |g| are both smaller than some Epsilon>0. The following however, I don't understand at all:
and both f' and g' have a finite (not = oo or -oo) derivation on this interval, and also g'=/=0.
Why is the derivation necessarily finite?
EDIT:
To explain where I see the problem a bit more precisely, let's say:
L=0
f(x)=0 for all x element R, and therefore f'(x)=0 for all x element R
Now, from limit x->a_+ (f'(x) / g'(x)) = 0 , it should be possible to somehow prove, that there exists a delta>0, such that for all x element (a,a+delta), g'(x) is finite and non zero. I really don't see it though, why can g'(x) not be +oo somewhere in that interval?
Pick [itex]\epsilon = 0.5[/itex] Since the above limit exists, there exists a [itex]\delta > 0[/itex] such that [itex]a < x < a + \delta[/itex] implies [itex]| \frac{f'(x)}{g'(x) } - 0 | < 0.5[/itex]
The statement [itex]| \frac{f'(x)}{g'(x)}| < 0.5[/itex] is not true unless the fraction [itex]\frac{f'(x)}{g'(x)}[/itex] exists, i.e. is a specific number with an absolute value than can be compared to 0.5. When [itex]g'(x)[/itex] is 0, the fraction doesn't exist. When [itex]g'(x)[/itex] doesn't exist by virtue of being "equal" to [itex]\infty[/itex] the fraction doesn't exist.
Thanks I think I'm starting to see where the problem is -
Why does it not exist, if it's equal to +oo?
Real valued functions exist at those real numbers where their values are real numbers. [itex]\infty[/itex] is not a real number.
Why does g'(x) have to be a real valued function?
The fraction [itex]| f'(x)/g'(x)|[/itex] isn't comparable to the real number [itex]\delta[/itex] by the relation "<" unless the fraction is a real number. The fraction isn't a real number unless it is the ratio of real numbers.
Oooh. I thought that 0/oo = 0, and instead it is undefined?
Yes, it's undefined. Don't confuse a ratio of numbers with limit of ratios.
Thank you very much!
  • · Replies 20 ·
