Spatial Reasoning behind the Maxwell-Boltzman distribution: A Question
  • Context: Graduate
  • Thread starter Thread starter corey2157
    Distribution
The discussion centers around the implications of molecular shape on the Maxwell-Boltzmann distribution, particularly in the context of gas behavior and collisions. Participants explore whether the assumption of spherical molecules affects the distribution and how different shapes, such as carbon nanotubes, might require alternative modeling approaches.
  • Some participants question how the shape of gas molecules is accounted for in the Maxwell-Boltzmann distribution, noting that the theory assumes spherical shapes.
  • Others assert that the distribution is derived under the assumption of thermal equilibrium and is independent of molecular shape, focusing instead on molar mass and temperature.
  • A participant suggests that if molecules were not spherical, such as 1 meter long carbon nanotubes, a different equation might be necessary to accurately model their behavior and interactions.
  • Concerns are raised about how collisions between molecules contribute to the positive skew of the distribution, with references to external resources for further clarification.
  • One participant distinguishes between Maxwell's and Boltzmann's derivations of the distribution, arguing that Maxwell's approach does not depend on molecular shape, while Boltzmann's may be more complex and potentially yield different results for non-spherical shapes.
Participants express differing views on the relevance of molecular shape to the Maxwell-Boltzmann distribution. While some agree that the theory assumes spherical molecules, others argue that the distribution can apply to various shapes under certain conditions. The discussion remains unresolved regarding the necessity of alternative models for non-spherical molecules.
Participants note the limitations of the Maxwell-Boltzmann distribution in accounting for intermolecular forces and the complexities involved in applying the Boltzmann equation to different molecular shapes.
corey2157
I have been trying to figure out if, and if so, just how is the shape of the molecules in a gas is taken into account by the Maxwell-Boltzmann distribution. I know the assumption is perfect spheres, but still, a square hit and a glancing blow on a pool table yield different results. My intuition is also telling me that repeated off center collisions would be required to get those situations where atoms are traveling many-fold faster than the mean. It seems like SIN would have to be in there somewhere.
Any insights?
The Maxwell-Boltzmann distribution describes velocities of molecules in the situation of thermal equilibrium. It depends on molar mass and temperature of the gas, but not on the shape of the molecules.
Well that is true, the theory has an explicit assumption that the molecules are spherical. And that is a reasonable assumption since molecules of a gas are more or less spherical. But is the spherical shape factored into the equation; that is my question.
If somehow 1 meter long carbon nanotubes were the molecules of the gas, wouldn't you need a different equation to get a reasonable model? I would think that equation would need to take into account the physical interactions between cylinders of a certain ratio.
The Maxwell Boltzmann distribution describes an ideal gas - so no intermolecular or intramolecular potentials are taken into consideration. It is a special case of the more general Boltzmann distribution.
... the theory has an explicit assumption that the molecules are spherical.
Not necessarily. It is important to distinguish the difference between Maxwell's and Boltzmann calculation of the distribution. They both lead to the same distribution in equilibrium, but via different, non-equivalent route.
Maxwell derived his equilibrium distribution from general statistical considerations, with no assumption as to the shape of the molecules. His result is therefore independent of the shape of the molecules. It is also independent of the intermolecular interactions, as long as they are described by weak potential energy function. Even long stick-like molecules are subject to Maxwell's derivation and the general conclusion from this theory is that they have the same velocity distribution as atom gases of the same mass and temperature.
Another way to understand Maxwell's result is to apply the general Boltzmann probability [itex]e^{-\frac{\frac{p^2}{2m}}{k_B T}}[/itex] to individual molecule. The only parameters this probability depends on are the temperature [itex]T[/itex] of the gas and the mass [itex]m[/itex] of the molecule.
Boltzmann's calculation is more complicated and I do not know it in detail, but if it gave different equilibrium distributions for other shapes than spheres (which is hard to calculate), I think this would be seen rather as imperfection of the Boltzmann equation.
Thanks Jano. You've given me more food for thought.
No problem.
  • · Replies 21 ·
  • · Replies 27 ·
12K
