Trying to find a simpler way to calculate this function
  • Context: Graduate
  • Thread starter Thread starter SeventhSigma
    Function
The discussion focuses on calculating the function S(N), which sums the largest divisor M(a,b,c) of the polynomial P(n) = n^4 + an^3 + bn^2 + cn for all combinations of a, b, and c within the range 1 to N. Participants noted that M(a,b,c) often results in values of the form 2^i * 3^j, indicating a pattern in the divisors. The approach to simplify the calculation involves analyzing the differences P(2) - P(1) = 15 + 7a + 3b, which can help eliminate variables and reduce the number of combinations needed for testing.
  • Understanding of polynomial functions and their properties
  • Familiarity with number theory, specifically divisibility
  • Knowledge of combinatorial mathematics
  • Experience with programming for algorithm optimization
  • Research polynomial factorization techniques to simplify P(n)
  • Explore number theory concepts related to divisors and their properties
  • Learn about combinatorial optimization methods to reduce variable testing
  • Investigate programming algorithms for efficient calculations of S(N)
Mathematicians, computer scientists, and algorithm developers interested in polynomial analysis and optimization techniques for divisor functions.
SeventhSigma
let P(n) = n^4 + an^3 + bn^2 + cn
M(a,b,c) returns largest m that divides P(n) for all n
then let function S(N) return the sum of all M(a,b,c) for 1 <= a,b,c <= N
I am trying to understand a simpler way to calculate S(N) so I don't have to actually process every single combination of a,b, and c but I am having trouble finding patterns to take advantage of on a broad scale.
So far I know from trying all sorts of values that M(a,b,c) tends to return values of form 2^i * 3^j where i,j>=0.
If m divides P(n) for all n, it also divides all differences: m divides P(2)-P(1) = 15+7a+3b, for example.
Using more values for n, you can eliminate more variables. This could help to reduce testing.
P(n) can be looked at as a base 'n' number. This would make a,b,c digits and a max value for that part.
  • · Replies 23 ·
  • · Replies 33 ·
  • · Replies 21 ·
