Stuck on derivation of Euler's equations in rigid body dynamics
The discussion centers on the derivation of Euler's equations for rotational dynamics as presented in John Taylor's "Classical Mechanics," specifically in Chapter 10. The key focus is on the moment of inertia tensor, which varies with the position of the rigid body, necessitating the use of a "body frame" that rotates with the body. The confusion arises regarding the angular momentum expression L = [I] w, where [I] is the moment of inertia tensor and w is the angular velocity, leading to the question of why w is not zero if the frame is fixed within the body. The clarification provided indicates that L represents the angular momentum components along the rotating axes at a given instant.
  • Understanding of Euler's equations in rigid body dynamics
  • Familiarity with moment of inertia tensor concepts
  • Knowledge of angular momentum in rotating frames
  • Basic principles of rotational dynamics
  • Study the derivation of Euler's equations in detail
  • Explore the properties and applications of the moment of inertia tensor
  • Learn about angular momentum in non-inertial reference frames
  • Investigate the implications of body-fixed frames in dynamics
Students and professionals in physics, mechanical engineering, and robotics who are studying rotational dynamics and seeking a deeper understanding of Euler's equations and their applications in rigid body motion.
bigerst
i was reading about derivation of Euler's equations for rotational dynamics (john taylor, classical mechanics, chapter 10) when i got stuck on one of the reasonings
essentially it refers to the moment of inertia tensor, since the tensor itself about a point is dependent on the position of the rigid body (hence the tensor would have to be a function of time) hence it is argued that it would be helpful to construct a "body frame" fixed within the body with its axis pointing at the principal axis of rotation of the body, this body frame would rotate along with the body (since it is fixed within the body). then came the part i didnt understand, it said the angular momentum measured in the body frame is L = w, where denotes the diagonal matrix and w the angular velocity. however since the frame is fixed inside the body, should the rigid body be stationary relative to the frame and hence w is zero? what is wrong with my reasoning?
I had the same question when I first encountered Euler Rigid body equations. What the author means by "L in rotating frame" is the components of L along the rotating axes at that instant.
