Quick question regarding kinetic energy, potential energy and velocity.
The discussion revolves around the calculation of the final velocity of a rollercoaster car as it descends a ramp, focusing on the relationship between kinetic energy, potential energy, and velocity. Participants explore different methods to arrive at the final velocity, including energy conservation and kinematic equations, while addressing the implications of ramp shape and friction.
  • One participant calculates the total energy at the bottom of the drop using kinetic and potential energy to find the final velocity.
  • Another participant notes that energy depends on the square of the velocity, suggesting that the final speed can be deduced from the kinetic energy gained during the drop.
  • A suggestion is made to use Newton's laws and kinematics for constant acceleration to find the final velocity, with a caveat regarding the ramp's shape affecting the approach.
  • Participants discuss the importance of treating the ramp as straight for the sake of the exercise, while noting that the ramp's shape does not affect the final velocity in a frictionless scenario.
  • One participant encourages expressing the problem symbolically to clarify the relationships involved in the calculations.
Participants generally agree on the validity of using energy conservation to find the final velocity, but there are differing views on the implications of the ramp's shape and the methods used to arrive at the solution. The discussion remains unresolved regarding the best approach to take in different scenarios.
There is uncertainty regarding the ramp's shape (straight vs. curved) and its impact on the calculations. The discussion also highlights the dependence on assumptions such as negligible friction and the use of specific equations for different conditions.
JackJJButler
Ok so I have got the right answer to my calculation however I do not understand part of it,
here is the question...
Q2: The rollercoaster car from Task 1 Q2 above is initially traveling at 6.5m/s at point A in the diagram below. Assuming negligible frictional forces as previously, what will be the final velocity of the car at point B?
The image shows that the cart drops by 3.5 m on a ramp, and point b is further along the track.
So here is what I did:
At the top of the drop the drop the carriage already has an amount of kinetic energy, and potential energy, the potential energy will add on to the kinetic energy as it begins to accelerate down the drop.
Initial Kinetic Energy = 0.5 x mass x velocity^2 = 0.5x440x6.5^2 = 9295 joules
Potential energy = mass x gravity x height = 440x9.8x3.5 = 15092 joules
Total Energy at bottom of drop = 15092+9295= 24387 joules.
Transpose this formula to find V: KE= 0.5 x mass x v^2
V = √2xKinetic Energy/Mass
V = √2x24387/440
V = 10.53 m/s
Now here is my question why is it that I have to calculate the energies to find the velocity rather than calculate the velocities individually, i.e. find the velocity of the carriage dropping using the initial velocity as 0.
Because energy depends on the square of the velocity ... what you are doing is working out the kinetic energy gained in the drop, and, from that, deducing the final speed.
Work it out symbolically instead of numerically and you'll see.
Thanks for that, however any chance you could slightly expand on that?
If the slope of the ramp is a straight line, you can use Newton's laws and the equations for kinematics at constant acceleration to find the final velocity, and you should get the same result. Try it, it's a good exercise!
If the slope isn't a straight line, then you can't do this (at least not easily!) because the acceleration isn't constant. But conservation of energy still works.
Yeah the diagram doesn't state whether its straight or not, cheers though.
Expand on which, I said two things?
You should (as well as working the problem for a constant slope ramp) try to express the idea you are asking questions about symbolically ... you know, with letters instead of numbers. Compare with the same thing using the proper conservation of energy approach.
eg. for conservation of energy you find:
##mgh+\frac{1}{2}mv_i^2=\frac{1}{2}mv_f^2## which gives you: ##v_f=\sqrt{2gh+v_i^2}##
Now you can see the relationship more clearly.
See if you can express the alternative idea you talked about as a relation and solve it for ##v_f## using only the symbols.
[edit]
Doesn't matter - treat it as straight for the exercise and you'll understand this type of question better ;)
Cheers for that, think I can get my head round it now.
In fact, as far as the final velocity is concerned, it doesn't matter whether the ramp is straight or curved. So long as it's frictionless, conservation of energy guarantees that you'll get the same answer either way. The difference is in the intermediate velocities at points between the beginning and the end.
Indeed. Part of why it is so useful as an exercise.
  • · Replies 138 ·
10K
  • · Replies 41 ·
