Tsiolkovsky's rocket equation question
  • Context: Undergrad
  • Thread starter Thread starter enfield
    Rocket Rocket equation
The discussion revolves around the Tsiolkovsky rocket equation and its relationship to specific impulse and exhaust velocity. Participants explore how the equation might change if thrust is known instead of effective exhaust velocity, and they examine the implications of different definitions of specific impulse in various contexts.
  • One participant questions how the Tsiolkovsky rocket equation would be affected if thrust is known instead of effective exhaust velocity, specifically asking if ΔV would still be proportional to the log of the mass ratio.
  • Another participant asserts that ΔV does not depend on thrust but only on the specific impulse (Isp) of the propellant, maintaining that ΔV is always proportional to the natural logarithm of the mass ratio as long as Isp is constant.
  • Several participants discuss the relationship between specific impulse and effective exhaust velocity, with one noting that effective exhaust velocity can be expressed as thrust divided by the mass flow rate, while another emphasizes that specific impulse is directly proportional to effective exhaust velocity.
  • There is a discussion about the different conventions for defining specific impulse, with some participants stating that Isp can be defined per weight or per mass, depending on the application.
  • One participant argues that effective exhaust velocity and specific impulse are not identical unless the nozzle is perfectly expanded, indicating that there can be differences based on operational conditions.
  • Another participant points out the regional differences in how specific impulse is specified, noting that American engineers often use seconds while European engineers may use meters per second.
Participants express differing views on the definitions and implications of specific impulse and effective exhaust velocity, indicating that multiple competing views remain. There is no consensus on whether the second definition of specific impulse is standard or whether effective exhaust velocity is always identical to exhaust velocity.
Participants highlight that the definitions of specific impulse can vary based on context and application, and there are unresolved nuances regarding the relationship between effective exhaust velocity and specific impulse, particularly in different engineering practices.
enfield
How would the equation look if instead of knowing the effective exhaust velocity we knew the force the exhaust was exerting on the rocket.
The equation is:
[tex]\Delta V = v_e * ln(\dfrac{m_0}{m_1})[/tex]
would [tex]\Delta V[/tex] still be proportional to the log of the initial mass over the final mass?http://en.wikipedia.org/wiki/Tsiolkovsky's_rocket_equation
[itex]\Delta v[/itex] does not depend on thrust. Only on Isp of the propellant. As long as Isp is some constant, the [itex]\Delta v[/itex] will always be proportional to natural log of the mass ratio.
ah k. i followed the link to specific impulse and it helped me understand.
http://en.wikipedia.org/wiki/Specific_impulse
Specific impulse (usually abbreviated Isp) is a way to describe the efficiency of rocket and jet engines. It represents the force with respect to the amount of propellant used per unit time.[1] If the "amount" of propellant is given in terms of mass (such as in kilograms), then specific impulse has units of velocity. If it is given in terms of weight (such as in kiloponds), then specific impulse has units of time. The conversion constant between the two versions of specific impulse is g.[2] The higher the specific impulse, the lower the propellant flow rate required for a given thrust, and in the case of a rocket the less propellant is needed for a given delta-v per the Tsiolkovsky rocket equation.
and it says the effective exhaust velocity is also the thrust divided by the rate of the flow of mass from the rocket. that makes sense. (and yeah, this is with the specific impulse being constant).
Actually, your parenthetical note at the end there is somewhat irrelevant - specific impulse is directly proportional to effective exhaust velocity. The two terms are just two different representations of the same value (specifically, effective exhaust velocity = Isp*g0)
Depending on definition. For impulse per weight, v = Isp*g. For impulse per mass, v = Isp. Both conventions are used, mostly, depending on application. For rocket taking off from Earth's surface, Isp per weight is a more directly useful quantity. For rocket accelerating in deep space, you just want the exhaust velocity, so Isp per mass.
Nope. Isp*g0 = Ve, effective. It isn't a matter of per weight or per mass, and g0 is strictly a conversion factor in this case. That's simply the definition of specific impulse and effective exhaust velocity. No matter where the rocket is, an Isp of 300 seconds is exactly the same as an effective exhaust velocity of 2940 meters per second.
(Note that I use g0 rather than g - this is because no matter where you are in the solar system (or elsewhere), g0 = 9.8 m/s2, and since it is a conversion factor rather than a variable, it is independent of the local gravity field)
There are two alternative definitions of Isp.
1) Isp = dp/dw = (dp/dm)/g
2) Isp = dp/dm = ve
Both are used in the literature and you differentiate by the units. First definition gives you units of inverse seconds. Second definition gives you units of m/s and is identical to exhaust velocity for a conventional rocket.
I've never seen the second one called Isp - everywhere I've seen it used, it was called effective exhaust velocity. If it is called Isp anywhere, it is at least a somewhat nonstandard usage. Also, just because I'm in a somewhat nitpicky mood at the moment, it's not necessarily identical to exhaust velocity. It's identical to exhaust velocity if and only if the nozzle is perfectly expanded (and thus the pressure thrust is zero). Otherwise, there will be a difference between effective exhaust velocity and actual exhaust velocity.
Not necessarily. Americans tend to specify Isp in seconds, Europeans in units of meters/second. American engineers tend to use customary units, where there's a problem with the pound: Is it a unit of mass or a unit of force? This problem doesn't exist in SI units, and since "specific" typically means per mass, European engineers tend to specify Isp in units of meters/second.
  • · Replies 41 ·
  • · Replies 37 ·
12K
  • · Replies 25 ·
  • · Replies 26 ·
