Build a Reusable Stripboard for Easy Circuit Tweaking
  • Thread starter Thread starter RhysGM
    Homemade
A reusable solderless stripboard has been created to facilitate easier component swapping without constant soldering. The builder utilized 18-pin DIL sockets, which were modified and glued together for this purpose. While some participants suggested using commercially available solderless breadboards, the creator highlighted the cost-effectiveness and immediate availability of their DIY solution. Discussions also touched on the historical context of breadboards in electronics. Overall, the thread emphasizes the balance between DIY innovation and existing solutions in circuit prototyping.
RhysGM
Hello, after failing on a few circuits I thought I need to be able to swap and change my components a little more easily then soldering all the time. So I've built a reusable solderless stripboard, that I can swap and change my components around.
I had a bunch of 18pin DIL sockets that I got for free so I chopped them up, super glued them together and then soldered them (a little bit messy, but they work). Now I can play with my circuits until they work then transfer them to a real stripboard once I've perfected the circuit.
Anyway just thought I would share that with you.
hi and welcome to PF
you do know you can buy solderless breadboards don't you ? :)
no point reinventing the wheel ;) but a great attempt
Dave
A breadboard is something I keep in my kitchen :smile:
And mine only cost £1 plus I didn't have to wait for delivery. :cool:
well there you go, therein lies the problem ... see you need to broaden you view from outta the kitchen ;)
seriously tho, those ones like I showed are very good, various sizes and some are able to clip together to make much larger arrangements. no electronics shack, hobbiest or professional should be without one or two
Dave
Just been checking them out on Maplin.co.uk, they look quite good but prices are from £1.99 to £19.99. Can you recommend a good one, how well do the components hold in, they're a little loose on my version. I was thinking I could make a big board with lots of fixed springs to hold them in place.
I think the term 'bread board' came from the use of an actual bread board with copper nails driven into it as soldering points - way back. Those guys were REAL enthusiasts! Solder flux came only in tins; none of your reels of ready fluxed solder.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
