Why do triangular shapes work best for distributing weight in bridge building?
  • Thread starter Thread starter HeJind
    Load Weight
Triangular shapes are optimal for weight distribution in bridge building due to their intrinsic strength, as they are the only convex polygons that maintain their shape under load. When constructing a bridge with popsicle sticks, understanding the tension and compression forces acting on each side of the triangle is crucial. A well-designed truss can effectively distribute pressure, as evidenced by a previous project that supported over 570 lbs. The rigidity of triangles prevents deformation, ensuring stability and strength in bridge designs.
  • Understanding of truss structures and their variations
  • Basic principles of tension and compression in engineering
  • Knowledge of materials used in bridge construction, such as popsicle sticks
  • Familiarity with load distribution concepts in structural design
  • Research the mechanics of truss design in civil engineering
  • Explore the properties of different polygon shapes in structural applications
  • Learn about load testing methodologies for bridge structures
  • Investigate software tools for simulating structural integrity in bridge designs
Civil engineers, architecture students, hobbyists building model bridges, and anyone interested in the principles of structural design and weight distribution.
HeJind
Sorry if my English is bad. We're building bridges and learning about truss and truss variations, but I'm still confused as to why the triangular shapes work best and what they achieve. How would I know side would be compressed and which would be tense?
We have to build a bridge using roughly 10 dozen popsicle sticks. If I want to apply pressure/load to the middle, how would I design the bridge to distribute this evenly?
Apparantly last year someone got over 570llbs
Triangles "work best" because they're the only convex polygon that has intrinsic strength. You cannot change any angle of a triangle without also changing the length of one of the sides. You can change the angles of any other convex polygon without changing the length of any side; e.g. a square can be deformed into a parallelogram.
19K
14K
53K
