How do I test for UV light in colored LEDs?
The discussion revolves around concerns about potential UV light emission from RGB LED strips, particularly blue and green LEDs, which seem to cause fluorescent reactions in certain materials. Users suggest various home experiments to test for UV, including using tonic water and checking US dollar bills for fluorescent strips, although one participant notes they are in a non-US location. Despite extensive research, participants find that most LED datasheets indicate negligible UV output, yet the fluorescent effects observed suggest otherwise. The conversation highlights the difficulty in obtaining reliable information about the specific LED strips purchased and the challenges of testing for UV light at home. Ultimately, it is concluded that blue LED light may cause fluorescence in certain materials, but true UV emission from these LEDs is unlikely.
R4za
I recently purchased two strings of RGB LED lights, the kind you can set to all sorts of colors by combining red, green and blue in various amounts.
Unfortunately, I strongly suspect that the blue and green led-pieces produce light that is contaminated with UV. Various UV-reactive things in my bedroom light up especially strongly under these colors; especially neon green and orange items. White UV reactive items just light up in the normal color of the lights. I don't want UV light in my room because it causes sharply accelerated skin aging.
However, I've never before had the chance to see my room lighted so brightly under so many different colors; I'm not sure what things are supposed to look like. I'd like to test the LEDS, to be sure.
Can anybody think of a (cheap) home experiment I could do, to definitively distinguish bright green or bright blue light from the same light mixed with UV?
Science news on Phys.org
Maybe tonic water... Except that UV makes tonic water glow blue... So... Maybe not so helpful. Maybe though?
Try a US $20 dollar bill and look for the strip. Just make sure it is the correct year(s) of issue. Not sure what intensity and frequency is required for this to work.
http://0.tqn.com/d/chemistry/1/0/A/X/1/US_20_under_blacklight.jpg
Alos petroleum jelly spread on a surface will glow blue under a black light (UV)
I've never seen any R, G, or B LED datasheets that show any UV components whatsoever. They all look very narrow and Gaussian like in the spectrum with no higher frequency (UV) components. Dig up some datasheets on these and confirm for yourself. Likely, only the Blue LED's are worth looking at for this issue. For any fluorescent materials you may have, you also need to determine if the Blue color can activate them.
I'll try it with the green ones on, thanks for the tip.
I'm not in the US so no dollar bills available, but I'll try the petroleum jelly. Thanks. =)
That's interesting info, thanks. Where would I start looking for datasheets on a string of leds? I live in a european, non-english speaking country and bought these locally, so the word alone probably won't get me anywhere.
I would expect that your total LED light output is negligible compared to the UV component of sunlight. Even if some fraction of the LED emission is UV (and I would be surprised by that), I don't think that it has any relevant effect.
At the producer of the LEDs or the string.
http://www.stevespanglerscience.com/product/color-changing-uv-beads
Cheap plastic beads that change color in UV light.
Thanks again for the help, all of you. However, I'm getting conflicting and inconclusive results with these approaches.
Every SMD-5050 RGB LED datasheet I've found online lists focused wavelengths well out of the UV range. The manufacturer (and datasheets) specific to my own strips remains mysterious, however; I ordered them though Groupon, requiring no direct interaction between the supplier and myself, and the packaging doesn't list a company name. I've emailed Groupon about it, but not had a response yet.
That would indicate that LED strips like these don't generally produce UV light; however, every black-light-reactive item I've tried lights up intensely under these. Far more so than under the low-powered actual UV lamp I've been using for comparison manages. If this fluorescence is caused by UV light, it is far from negligible.
I can't find much of anything about blue light activated fluorescence online, except for some barely related stuff about animal proteins. Do you know if fluorescent reactions to blue light are possible/common in inorganic materials?
blue light can produce something that looks like a "fluorescent effect" on materials of certain colors, but there is actually no fluorescence at all.
Interesting. Does that give me anything I could use to tell the difference?
Anything I could reference for affected colors, maybe?
There was a roll of sticky tape whose edge would glow with a bluish halo when I carried it closer to an open window on a sunny day, I attributed that to UV fluorescence. I can't remember the brand, but it was the more costly vanishing/invisible sticky tape, quite colourless.
If it is summer where you are, string the lights near a window. Normal LEDs are reputed to emit practically no UV and so are not attractive to moths and insects, unlike fluoro-type globes which act like beacons to these Summer night nuisances.
That's a creative angle - thanks for the idea. S'too bad it's just nearing the end of fall here. I'll have to see if I can catch a straggler.
Well, I think I solved my problem. I took some of my reactive items to a store that sells colored LED strips, and found that theirs had the same effect. Combined with the various datasheets I've read that show fairly selective wavelengths to be the standard, I think that most likely all blue LED light causes the appearance of fluorescence in certain neon-colored materials.
Thanks for the help everybody! It was quite the puzzle.
It is unlikely that 'real' UV would be produced from a 'visible' LED because of the low supply voltage used. The energy of the photons produced will be limited by the electron energy - which will only be equal to or less than the supply voltage. You would need about 4eV to produce anything shorter than Violet light. What is the actual voltage across the diode itself?
The stripes on postage stamps and banknotes are fluorescent and a handy test.
That sounds like a useful approach. The packaging says "working voltage: 12 Vdc", and "Input Voltage: 100~240 Vac". Does that include the needed info?
I tried a bank note that's supposed to light up under UV, and it doesn't, but then it didn't under my 'real' blacklight either, leading me to think it might not respond to the whole spectrum of UV. Another explanation would be that the LEDs don't emit UV light and my old blacklight is just really crappy. =P
Thanks for your help. =)
"Working voltage 12V" implies there's an internal series resistance in the package. So the info is no use, I think. You could chop one open carefully... And use a meter.
Looks like all your money is fake too! Not your day is it? Lol.
Try stamps. UK stamps have uv strips.
