Charts of a torus (and other manifolds)
The discussion revolves around the concept of "charts" in the context of manifolds, specifically focusing on the torus. Participants explore what constitutes a chart, how they are represented, and the specific charts associated with a torus using stereographical projection. The conversation includes both theoretical and practical aspects of charts in manifold theory.
  • Homework-related
  • One participant seeks clarification on what a "chart" of a manifold looks like, expressing confusion over its representation and asking if the provided examples are valid charts for a torus.
  • Another participant describes the process of creating charts for a sphere, suggesting that four charts can be obtained by projecting hemispheres onto the xy-plane and rotating the sphere.
  • A further contribution explains that a chart is a map used to navigate an area, drawing an analogy to geographical maps and emphasizing that charts in manifold theory serve a similar purpose.
  • This participant also notes that a chart consists of an open set in the manifold and a bijective mapping to \(\mathbb{R}^n\), highlighting the need for multiple charts to cover the torus smoothly.
  • Another participant proposes a method of visualizing the torus as a rectangle in the plane with identified edges, suggesting various coordinate systems that can be derived from this representation.
Participants express varying interpretations of what constitutes a chart and how many charts are necessary for a torus. While there are some shared ideas about the nature of charts, there is no consensus on the specific charts or their representations.
Participants mention the need to specify domains and ranges for charts, indicating that the discussion may involve assumptions about the definitions and properties of charts that are not fully resolved.
mcafej
Ok, so this relates to my homework, but I really can't find an answer anywhere, so this is more of a general question. First off, what does a "chart" of a manifold look like? Is it a set, a function, a drawing, a table, what?! I have found so many things about charts, but nothing shows what they actually look like (either that or I am just not recognizing them). Secondly, using stereographical projection, what are the 4 charts of a torus? I saw something that looked something like
x1 = ((cosΘ, sinΘ), (cosφ, sinφ))= Θ
x2 = ((cosΘ, sinΘ), (cosφ, sinφ))= φ
and the other charts are similar. Would the other charts just be
y1 = ((cosΘ, sinΘ), (cosφ, sinφ))= Θ
y2 = ((cosΘ, sinΘ), (cosφ, sinφ))= φ
I'm just really confused on this topic and I would like to gain a little more confidence before going into my final. Are the "charts" that I gave actually charts, and are they the ones that describe a torus?
On the sphere of radius 1 in 3 space centered at the origin you have four charts. Project the upper hemisphere onto the xy-plane by dropping the z coordinate. Project the lower hemisphere the same way. then rotate the sphere 90 degrees and do it again.
A chart is a map that you use to navigate your way through some area. For example, the USGS makes a ton of maps so that you can look at the appropriate chart to check out the local terrain/landmarks. Usually, charts are marked to show latitude and longitude. These are coordinates that tell you where you are on that chart.
An atlas is a book of charts that covers all the places of interest.
The meaning of chart/atlas in manifold theory is the same in spirit. A chart is a map of the area near a point and the points on the charts have rectangular coordinates that tell you where you are on the chart. Given a manifold there are an infiinte number of charts. Just like on the globe there are an infinite number of possible charts because a chart is determined by the exact area I want to map and also by the manner in which I want to assign coordinates to the points on the chart (You dont' have to use latitude/longitude, you could make up another way to assign coordinates).
Formally speaking, a chart consists of an open set U in the manifold, and a bijective mapping
[itex]\varphi: U\rightarrow \mathbb{R}^n .[/itex]
The image of the mapping is your flat "map" of the region U.
The mapping you described does give a chart of the torus though to be precise you need to specify the domain and range so that you have a 1-1 mapping. The fact that you need more than 1 chart is a reflection of the fact that a single flat map cannot smoothly cover the torus unless you wrap it on itself.
If you think of the torus as a rectangle in the plane with opposite edges identified then you can get a coordinate system as
1) the interior of the rectangle
2) an open square around the corner,
3) an open rectangular strip along two perpendicular edges excluding the end points
Each of these is a diffeomorphism of an open neighborhood on the torus into an open neighborhood in the plane
  • · Replies 20 ·
  • · Replies 17 ·
