What happens when you vary sigma in the s-plane?
The discussion centers on understanding the s variable in the context of the Laplace transform, specifically the components σ (decay rate) and jω (frequency). The user seeks clarification on the significance of varying σ in the s-plane. It is noted that while frequency is straightforward, the implications of changing the decay rate are less clear. Varying σ affects system stability and response characteristics, influencing how signals decay over time. Understanding this relationship is crucial for analyzing dynamic systems in engineering and control theory.
gtr32x
Hi all,
I'm studying Laplace transform right now. And I am trying to understand the s variable in the s-plane. I found online that s = σ + jω where ω is the frequency and σ is the decay rate. Frequency is pretty easy to understand but I can't seem to find anywhere that explains what is the decay rate. Can anybody help please?
Thanks!
Mathematics news on Phys.org
Welcome to PF;
Have a look at how the variable s is used ... what happens when you vary that sigma?
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
