Negative Work or Positive Work? and gravitational potential energy
The discussion revolves around the concepts of negative and positive work in the context of gravitational potential energy, particularly focusing on the movement of objects in a gravitational field. Participants explore the implications of work done when moving objects from a reference point at infinity to another point in space, as well as the roles of different forces involved in these scenarios.
  • One participant notes that gravitational potential energy is considered negative when the reference point is at infinity, leading to confusion about the sign of work done when moving an object from infinity to a point "X" in space.
  • Another participant explains that positive work is done when separating two objects, as the force exerted is in the same direction as the displacement.
  • Concerns are raised about how an outward force can be applied while the object moves inward, prompting requests for further clarification.
  • A later reply uses the analogy of lifting and lowering a rock to illustrate the concept of work done by different forces, emphasizing that gravity does positive work while the person lowering the rock does negative work.
  • Some participants express understanding after the explanations, indicating that the examples helped clarify the concepts.
  • There is a discussion about the net work being zero when the work done by gravity and the work done by the person are equal in magnitude but opposite in direction.
Participants generally agree on the definitions of positive and negative work as they relate to gravitational potential energy, but there remains some confusion about the application of these concepts in specific scenarios. The discussion includes multiple viewpoints and clarifications without reaching a definitive consensus on all points.
Some participants express uncertainty regarding the application of forces and the direction of work, indicating a need for further exploration of these concepts. The discussion does not resolve all questions raised about the nature of work in gravitational fields.
This discussion may be useful for high school physics students and anyone interested in understanding the concepts of work and gravitational potential energy, particularly in the context of forces acting on objects in a gravitational field.
Tommy1995
Hi!
So, when we're calculating the potential energy of a mass in space we make it negative because we assign infinity as the reference point.
Now, to find the potential energy of something I understand that we find the work that is done to it to move it from the reference point to another point in space.
And I also understand that positive work is when the displacement and force are in the same direction.
Now here's the bit I don't get! When we find the potential energy of an object in space the potential energy is negative. Thus the work that is needed to move the object from a point at infinity to a point "X" in space will be negative.
But when we move an object from this infinity point to a point "X" in space wouldn't work be positive because the force and displacement of the object are in the same direction?
Please help, I'm seriously confused right now...
Btw I'm just a 12th grade high school physics student so go easy on me with the maths LOL
Imagine you have a planet and a rock out in space. Let's call the gravitational potential energy zero when they are infinitely far apart. If they were some finite distance X apart, it should make sense that you must do positive work to separate them further: The force you must exert on the rock is in the same direction as the displacement.
But when you bring the rock towards the planet (slowly, so as not to give them any kinetic energy) the force you exert on the rock is still outwards while the displacement is inwards. Thus the work you do is negative.
Make sense?
Sorry Doc Al but I don't understand, how can you apply an outwards force on the rock and yet have the rock move inwards...?
please explain further, it would be greatly appreciated.
Lol i didn't get that too..
Sure.
Imagine you are slowly lifting a heavy rock from the ground to put it on a shelf. What's the direction of the force you must exert on the rock as you lift it?
Now imagine you are slowly lowering that rock from the shelf to gently place it back on the ground. What's the direction of the force you must exert on the rock as you lower it?
I totally get it now! Thanks doc your a legend! :d
When you think about work, the first thing you must think of is "Work done by what?". In Doc Al's examples, there are two forces in question: gravity, and you.
When you are lowering the rock, gravity is doing positive work on it (the force on the rock by gravity is in the same direction as its displacement) and you are doing negative work on it (the force on the rock by you is opposite the direction of its displacement).
Also, if the work that you do has the same magnitude as the work that gravity does, then the net work is zero because one is negative and the other is positive. This means the final KE of the object is the same as the initial KE, as for example when you lower the object with constant speed.
Thank you guys heeeeaps, very nice responses helped so much xD
  • · Replies 54 ·
  • · Replies 46 ·
  • · Replies 27 ·
12K
