Can Seven Vertices of a 19-Gon Form a Trapezoid Using the Pigeonhole Principle?
  • Context: Graduate
  • Thread starter Thread starter Numeriprimi
    Principle
The discussion revolves around whether it is possible to select seven vertices from a regular 19-gon such that four of those vertices can form a trapezoid. The participants explore the application of the Pigeonhole Principle in this context.
  • One participant suggests that a trapezoid requires two parallel sides, implying that the goal is to select points such that no connections between them are parallel.
  • Another participant enumerates families of parallel lines formed by the vertices of the 19-gon, providing examples of pairs that are parallel.
  • A participant calculates the total number of possible connections between seven points, arriving at the formula (n^2-n)/2, and discusses the implications of having more connections than families of parallel lines.
  • There is a clarification regarding the counting of connections, emphasizing that connections between two points are considered the same regardless of order, and that self-connections are not counted.
Participants express varying levels of understanding regarding the mathematical reasoning involved, particularly in relation to the counting of connections and the application of the Pigeonhole Principle. There is no consensus on the proof or the validity of the approach presented.
Some participants express uncertainty about the mathematical steps involved, particularly in relation to the counting of connections and the implications of the number of families of parallel lines. The discussion includes assumptions about the definitions and properties of trapezoids and parallel lines.
Numeriprimi
Hey!
I have got some question for you.
Decide if you can choose seven tops of the regular 19-gon and four of them are tops of trapezoid.
(I think - Pigeonhole principle, but how?)
Hi Numeriprimi! :smile:
What do you mean by "tops"? :confused:
I think he means the vertices. How I would try to prove it. Feel free to stop reading once you think that you have the answer...
1) A trapezoid is defined by having two parallel sides. So you want to construct a set of points and none of the connections between the points are to be parallel.
2) If we numerate the points we can start forming all the families of parallel lines.
3) If we enumerate in a circle one family is {(2,19),(3,18),(4,17),(5,16),..., (10,11)} You see that even one "length 1" pair is included.
4) There are 19 of these families, and they account for all the possible connections there are.
5) The possible connections between n points are (n^2-n)/2
6) Pidgeonhole
Yes, I mean vertices... Sorry for my English because is quite hard to choose right word with same meaning in my language when is a lot of words :-)
So, I will read and understand your answer after school because I going to sleep. Then I will write when I won't understand you.
For now... thanks very much :-)
Numeriprimi. You PM me, but maybe others are interested in the answer as well. So I'll discuss the questions here. I hope that is ok.
I understand to 4), it is okay, but no 5) and 6). How you know it and how do you prove it for choose seven of them?
A connection between two points is the same whether it is between say points (1,2) and or (2,1). Connections between a point and itself (1,1) don't count. There is more than one way to count the number of unordered dissimilar pairs of N numbers. What I did was taking a square NxN matrix, which has N^2 entries. Remove the diagonal where the indices are identical, and then take half of what is left. Similar to a distance table like this http://www.kznded.gov.za/portals/0/eim/durban_film_office/Distance-table.html where you can see the distances between any two South African cities in the table, and there are no double entries.
So between 7 points there are (7*7-7)/2=21 connections. If two of them are in parallel you are done. Connections are in parallel if they are in the same family. There are only 19 families.
