Entropy is a measure of energy availiable for work ?
The discussion centers around the statement "Entropy is a measure of energy available for work," exploring its validity and implications. Participants examine the relationship between entropy and energy, particularly in the context of thermodynamic processes, including examples involving gas expansion and Carnot cycles. The conversation includes technical reasoning and conceptual clarifications regarding the nature of work and energy in thermodynamic systems.
  • Some participants question the statement that "entropy is a measure of energy available for work," suggesting it is misleading and should include "not" to clarify that it refers to energy unavailable for work.
  • One participant argues that expanding a gas into a vacuum does no work, highlighting that work requires an opposing force.
  • Another participant discusses the conditions under which work can be done during gas expansion, emphasizing the need for pressure differentials.
  • There is a proposal that the relationship between entropy and energy in a Carnot cycle indicates that the energy unavailable for work is related to the temperature of the cold reservoir and the extracted entropy.
  • Several participants express confusion over the interpretation of "energy unavailable for work," noting that it requires a specific definition to avoid misinterpretation.
  • One participant mentions that the concept of "lost work" complicates the understanding of how entropy relates to energy availability.
Participants do not reach consensus on the interpretation of entropy in relation to energy availability for work. Multiple competing views remain, particularly regarding the clarity and accuracy of the original statement about entropy.
Participants note that the statement about entropy requires careful definition to avoid confusion, as it can lead to various interpretations without proper context. The discussion highlights the complexities involved in thermodynamic processes and the nuances in the relationship between entropy and energy.
Rap
"Entropy is a measure of energy availiable for work". Can someone explain this to me? Give some examples that show in what sense it is true. It has to come with a lot of caveats, proviso's etc. because its simply not true on its face.
I mean, if I have a container of gas at some temperature above 0 K, then I can extract all of its internal energy as work, just let it quasistatically expand to infinity.
Science news on Phys.org
Such a container has internal pressure P.
Expanding from P into a vacuum does no work.
Expanding from P against an external pressure P' < P does work, but as this happens P diminishes until P = P' when the system is in equilibrium.
How would you proceed from this equilibrium to infinity, where P = 0 ?
Yes, you would need initial pressure (P) greater than zero, and ambient pressure (P') equal to zero, i.e. in outer space. But the point remains, the statement that "entropy is a measure of energy unavailable for work" is contradicted by this example.
This is fundamental, pushing against something that offers no resistance does no work.
Where did you get that quote? It is wrong: it is missing the word "not"!
wiki said:
Entropy is ... the measure of a system's thermal energy per unit temperature that is unavailable for doing useful work.
http://en.wikipedia.org/wiki/Entropy
Agreed - I think that was a typo -, but we also need to dispel the misconception in the proposed counterexample that follows.
Once that is done it is easy to explain the correct reasoning.
Yes, sorry, I misquoted it. It should be something like "Entropy is a measure of the energy NOT available for useful work". I also see the point that the example I gave is not good. In order for the expansion to be slow, there has to be an opposing force almost equal to the pressure force, and that force has to diminish as the volume increases (and pressure decreases). This opposing force would be the mechanism by which work was done on the environment. Something like a mass in a gravitational field, in which the mass is slowly being reduced by removal.
I found a website http://web.mit.edu/16.unified/www/SPRING/propulsion/notes/node48.html which seems to give an explanation, I will have to look at it closely.
Also the Wikipedia quote says it is "energy per unit temperature" not available for work, which I cannot immediately decipher.
Looking at the above site, it seems to me what it is saying is that the amount of energy unavailable for useful work in a Carnot cycle is equal to the entropy extracted from the hot reservoir (which is equal to the entropy deposited in the cold reservoir) times the temperature of the cold reservoir. How you get from this to the idea that "Entropy is a measure of the energy unavailable for work" still eludes me.
Entropy of what? I tried assuming that the hot reservoir was actually a hot system with a finite amount of energy and entropy. Again, you can prove that if you extract entropy ∆S from the hot body, the amount of unavailable energy is Tc ∆S where Tc is the temperature of the cold reservoir. But you can only extract so much entropy from the hot body using a working body at the cold reservoir temperature. If their temperatures are very close, you can extract very little entropy and energy. The great majority of the internal energy of the hot body is unavailable for work in this case.
If you set the cold reservoir to zero degrees, then the amount of energy unavailable for work is zero. You could extract all of the internal energy of the hot body as work. (right?).
I still don't get it.
We have hashed this over before. The problem with "entropy is a measure of the energy unavailable for work" is that standing alone it is not clear and open to a number of interpretations. It requires a special definition of "energy unavailable for work" as the explanation shows. Without that explanation it can easily lead to misinterpretation.
For example, between two temperatures, Th and Tc, the heat flow Q is capable of producing an amount of work, W = Q(1-Tc/Th) ie. with a Carnot engine. So there is energy E = QTc/Th energy that is, in that sense, "unavailable" for doing work. Yet, as we know, ΔS = 0 for a Carnot engine. So one could well ask, how is 0 a measure of QTc/Th? The answer is: "well, that is not what we mean by 'energy unavailable to do work'. We really mean 'lost work' which is the potential work that could be extracted minus the work that was actually extracted, or the amount of additional work required to restore the system and surroundings to their original state if you saved the output work and used it to drive the process in reverse." Hence the confusion.
So, as I have said before, this particular statement should not be used to introduce the concept of entropy. By itself it explains nothing and leads to great confusion.
AM
AM
Well, I kind of thought that was case, but there was also the possibility I was missing something. Thanks for the clarification.
The time for hand waving is over, here is some mathematics.
Consider a universe consisting of a system contained in a heat bath or reservoir at uniform constant temperature T.
Consider changes in the function Z = entropy of bath plus entropy of the system = entropy of this universe.
dZ = dSb + dSs....1
Where b refers to the bath and s refers to the system.
If the system absorbs heat dq the same amount of heat is lost by the bath so the entropy change
dSb =-dq/T......2
substituting this into equation 1
dZ = dSs - dq/T.....3
Now consider a change of state of the system from state A to state B
By the first law
dUs = dq - dw .....4
Combining equations 3 and 4 and rearranging
dSs = (dUs+dw)/T + dZ
re-arranging
dw = TdSs - dUs -TdZ
Since TdZ is always a positive quantity or zero
dw ≤ TdSs - dUs
Where dw is the work done by the system
This is the principle of maximum work and calculates the maximum work that can be obtained from the system. As you can see it has two components vis from the entropy created and from the change in internal energy and these act in opposite directions so in this sense the TdSs term reduces the amount of work obtainable from the internal energy of the system and accounts for unavailable energy since TdSs has the dimensions of energy.
Note the usual caveat
The inequality refers to irreversible processes, the equality to reversible ones.
What you said is only possible if the gas expands both adiabatically and reversibly. In an adiabatic and reversible expansion, the change in entropy of the gas is zero. Under that condition, one could turn all the internal energy into work.
Any deviation from the conditions of adiabatic and reversible would result in some internal energy not being turned to work.
First, I prove that one can extract all the internal energy from a monotonic ideal gas using an expansion that is BOTH adiabatic and reversible.
Suppose one were to take an ideal gas in a closed chamber and expand it both adiabatically and slowly, so that it is in a state near thermal equilibrium at all times. No entropy goes in or out of the chamber.
At the end of the expansion, even in the limit of infinite volume, you would end up with a gas of finite temperature.
The ideal gas law is:
1) PV=nRT
where P is the pressure of the gas, V is the volume of the chamber, n is the molarity of the gas, R is the gas constant and T is the temperature.
The internal energy of the ideal gas is:
2) U=(3/2)nRT
where U is the internal energy of the gas and everything else is the same.
Substituting equation 2 into equation 1:
3)U=(3/2)PV
Before the gas starts expanding, let P=P0, V=V0, T=T0, and U=U0. The chamber is closed, so "n" is constant the entire time. There are three degrees of freedom for each atom in a mono atomic gas. Therefore, for a mono atomic gas:
3) U0=1.5 P0 V0
The adiabatic expansion of an mono-atomic gas is:
4) P0 V0 ^(5/3)= P V^(1.5)
Therefore,
5) P = P0 (V0/V)^(5/3)
The work, W, done by the gas is
6) W = ∫[V0→∞] P dV
Substituting equation 5 into equation 6:
7) W = (P0 V0^(5/3)))∫[V0→∞] V^(-5/3) dV
Evaluating the integral in equation 6:
8) W = (3/2)(P0 V0^5/3)V0^(-2/3)
9) W=(1.5) P0 V0
The expression for W in equation 9 is the same as the expression for U0 in equation 3. Therefore, the internal energy has been taken out completely.
I’ll solve the problem later (a week or so) for an expansion with sliding friction. There, the increase in entropy characterizes the amount of internal energy not turned into work. However, I will set up the problem. I will show the two equations that makes the case with sliding friction different from the reversible condition.
One remove the reversibility condition by adding sliding friction,
10) Wf = ∫[V0→Vf] (P-Pf) dV
where Pf is the pressure due to sliding friction and Vf is the volume when the P=Pf. The chamber stops expanding when P=Pf.
However, another expression is necessary to describe how much entropy is created.
11) dQ = Pf dV
Equation merely says that the energy used up by the sliding friction causes entropy to be created. The heat energy, dQ, is the energy used up by friction.
I don’t have time now, so I leave it as an exercise. Honest, moderator, I promise to get back to it. However, he wants an example where the creation of entropy limits the work that can be extracted. This is a good one.
Spoiler
Wf<W. Not all the internal energy is turned into work with sliding friction included. Let Q be the work done by the sliding force alone. The increase in entropy is enough to explain why the internal energy is not being turned into work.
Do you not agree that the maximum possible work is extracted in a reversible isothermal expansion?
Are you sure you mean this: you have different values of gamma on each side?
In an isothermal expansion, energy is entering the gas from a hot reservoir. Therefore, one can't say that one is extracting the energy from the ideal gas. Most of the energy is being extracted from the hot reservoir, not from the ideal gas.
In the corresponding isothermal expansion, the ideal gas is acting like a conduit for energy and entropy. The ideal gas is not acting as a storage matrix for the energy.
The OP was saying that the work was being extracted from the internal energy that was initially embedded in the ideal gas. All work energy comes from the container of gas, not outside reservoirs. So the walls of the container have to be thermal insulators.
If you allow heat energy to conduct through the walls of the container, then the work may exceed the initial value of the internal energy. The hot reservoir can keep supplying energy long after the internal energy is used up.
So I stick to my guns with regards to the specificity of the OPs hypothesis. He was unconsciously assuming that the expansion is both adiabatic and reversible.
I diagree with those people who said that the gas would remain the same temperature during the expansion, and that not all the energy could be extracted from the internal energy. I showed that the internal energy could be entirely extracted for an ideal monotonic gas under adiabatic and reversible conditions.
The big problem that I have with the OP's question is with the word "quasistatic". I conjecture that the OP thought that "quasistatic" meant "both adiabatic and reversible".
A quasistatic process can be both nonadiabatic and irreversible. However, "quasistatic" is a useful hypothesis. The word "quasistatic" implies spatial uniformity. In this case, the word quasistatic implies that the temperature and the pressure of the ideal gas is uniform in the chamber.
Quasistatic implies that enough time has passed between steps that both temperature and pressure are effectively constant in space. Thus, temperature is not a function of position. Pressure is not a function of position.
I think this is correct. I didn't spend much time checking my work. If you see an arithmetic blunder, feel free to correct me.
Also, I specified a specific case to simplify the problem. So even if I did it correctly, the gamma value that I used was atypical. Next time, I will let gamma be a parameter of arbitrary value.
I specified a monotonic gas. The gas is comprise of individual atoms. There are no internal degrees of freedom in these atoms. Any correlation between coefficients may be due to my choice.
There are many ways an expansion can be irreversible. I think the one most people think of is where the expansion is not quasistatic. Suppose the gas is allowed to expand freely, so that temperature and pressure are not uniform. This is irreversible. However, the mathematics is way beyond my level of expertise.
The problem is tractable if the process is quasistatic. So, I think the best thing would be to show how it works with an quasistatic but irreversible. For instance, what happens if one turns on the sliding friction and the static friction in this expansion. That would result in a process where entropy is created. In other words, friction would result in an irreversible expansion even under quasistatic conditions.
I don't have time now. I will post a solution to that later. For now, just remember that not all quasistatic processes are reversible.
I wanted to be more subtle and polite but
[tex]{P_1}{V_1}^\gamma = {P_2}{V_2}^\gamma[/tex]
Whereas you have
[tex]{P_0}{V_0}^{\frac{5}{3}} = {P_1}{V_1}^{\frac{3}{2}}[/tex]
Is this a rejection of Joule's experiment and the definition of an ideal gas?
If so you should make it clear that your view is not mainstream physics.
It should be noted that Joules experiment was both adiabatic and isothermal and has been repeated successfully many times.
You are correct in observing that during an isothermal expansion neither q nor w are zero.
However what makes you think the internal energy is the same at the beginning and end, in the light of your above statement?
One definition (or property derivable from an equivalent definition) of an ideal gas is that its internal energy is a function of temperature alone so if the temperature changes the internal energy changes. To remove all the internal energy you would have to remove all the kinetic energy of all its molecules.
Studiot said:
I wanted to be more subtle and polite but [tex]{P_1}{V_1}^\gamma = {P_2}{V_2}^\gamma[/tex]Whereas you have[tex]{P_0}{V_0}^{\frac{5}{3}} = {P_1}{V_1}^{\frac{3}{2}}[/tex]
I think it was a typo. Darwin did write: P = P0 (V0/V)^(5/3) a little farther down.
I am not sure that you are both talking about the same process. Darwin was referring to a quasi-static adiabatic expansion of an ideal gas. Temperature is given by the adiabatic condition:
[tex]TV^{(\gamma - 1)} = \text{constant}[/tex]
So, if volume changes this cannot be isothermal. Temperature has to change.
I think you (Studiot) may be talking about free expansion, not quasi-static expansion, in which case T is constant for an ideal gas.
AM
Studiot - I agree with your derivation but with regard to the OP, the correct statement would then be: "an infinitesimal change in entropy is a measure of the minimum infinitesimal amount of energy unavailable for work given a particular ambient temperature."
Darwin123 - Thank you for clarifying the muddled OP. Depending on conditions, all, some, or none of a system's internal energy can be converted to work, and so the statement "Entropy is a measure of the energy unavailable for work" is ambiguous at best, wrong at worst. You are right, I was assuming adiabatic and reversible. Adiabatic or else you are potentially using energy from somewhere else to do the work. Reversible, because it will give the miniumum amount of work unavailable. I should have said that instead of quasistatic. I take quasistatic to mean, by definition, a process can be described as a continuum of equilibrium states.
Oops. My typo. I meant,
Studiot said:
I [tex]{P_0}{V_0}^{\frac{5}{3}} = {P_1}{V_1}^{\frac{5}{3}}[/tex]
No, it was a typo. Certainly not mainstream physics. However, I did not insert that mistake into my later equations.
Good for Joule! More power to him!
The internal energy of an ideal gas varies only with its temperature. The internal energy is not explicitly determined by either its pressure or its temperature. If you know how many atoms are in a molecule of the ideal, the number of molecules and the temperature, then you can uniquely determine the internal energy.
The quantity of the ideal gas in the closed container is constant. The number of atoms per molecule is constant. For an isothermal expansion, the temperature of the ideal gas is constant.
Therefore, the internal energy of the ideal gas is constant for an isothermal expansion. The internal energy never changes during the entire expansion, even in the limit of infinite volume. However, work is being done for the entire time. Therefore, the work can't come from the internal energy.
An isothermal expansion is actually the most inefficient way to use the internal energy of the ideal gas. None of the internal energy of the ideal gas becomes work in an isothermal expansion. All heat energy absorbed by the ideal gas instantly turns into work on the surroundings.
In an isothermal expansion, not a single picojoule of work comes from the internal energy of the gas. It all comes from the heat reservoir connected to the ideal gas.
One should note that the total amount of work done by the gas in the isothermal expansion is infinite. The work done by the gas increases with the logarithm of volume. So an infinite volume means that an infinite amount of work is performed. Do the calculations for yourself.
Obviously, the infinite energy that is going to become work is not in the internal energy of the gas. In fact, the internal energy of the gas remains the same even in the extreme limit of infinite work.
The energy for work is being supplied by the heat reservoir, not the ideal gas. In order to maintain a constant temperature, the container has to be in thermal contact with
Therefore, the kinetic energy of the molecules in the gas can not change during an isothermal expansion.
If you want to extract all the internal energy of the ideal gas to work on the surroundings, then you have to decrease the temperature to absolute zero. This can be done in an adiabatic expansion. It can't be done in an isothermal expansion.
Entropy can change only two ways. It can move or it can be created. In an adiabatic process, entropy can't move. The temperature changes instead. In an isothermal process, the entropy moves in such a way as to keep the temperature constant.
Note, that is only for a simple system (homogeneous).
For complex systems contained inside a thermally insulating boundary, entropy may move around inside the system, driven by temperature differences inside the system, equalizing them when possible, but can never be transferred across the boundary. During these internal sub-processes, entropy may also be created. In an isothermal process, the boundary is thermally open, and entropy may move across the boundary, again driven by temperature differences between the system and the environment, in such a way as to equalize internal temperatures at the constant temperature of the environment, when possible.
Entropy transfer goes hand in hand with energy transfer via dU=T dS. If a process is converting energy to work, and you want to know how much of that energy is converted to work, in order to keep the bookwork straight, you cannot bring in energy or entropy from somewhere else to accomplish that work. To ensure this, the process has to be adiabatic, i.e. inside a thermally insulating boundary which prevents entropy and energy coming in from somewhere else.
For finite temperature differences, transfer of entropy across a thermally open boundary causes creation of entropy at the boundary which is transferred to the lower temperature system. The transfer of entropy is of order ∆T, the creation of entropy at the boundary is of order ∆T^2, so, in the limit of small ∆T, entropy may be transferred without creation at the boundary. If ∆T is identically zero, there will be no transfer of entropy, since only temperature differences will drive entropy transfer.
I think you have to qualify this statement. You have to speaking about a reversible process. Entropy can and certainly does change in an adiabatic irreversible expansion.
And I wouldn't say it moves because entropy is not a conserved quantity such as energy or momentum. We can speak of energy or momentum transfer because the loss of energy/momentum must result in the gain of energy/momentum of some other body so it behaves as if it moves. Entropy does not behave like. So I would suggest that the concept of entropy moving is not a particularly helpful one.
In a reversible isothermal process total entropy change is 0. In a real isothermal process, the entropy of the system + surroundings inevitably increases. It is not entropy that moves. It is energy. And the faster the energy moves, the greater the increase in entropy. So I might suggest that entropy increase is related more to the speed of energy transfer (heat flow) than to the fact that a body remains at the same temperature.
AM
AM
When entropy is conserved, i.e. when a process is reversible, the concept of entropy moving is just as valid as the concept of conserved energy moving, and is therefore very helpful. If you can identify the location at which entropy is created (e.g. at the thermally open boundary between two systems with a finite temperature difference), and identify into which system the created entropy is deposited, then I see no conceptual problem with Dirac123's statement resulting from the non-conservation of entropy. Not yet being totally certain of this concept, I would be interested in any specific process you can think of where this concept is inappropriate.
Is that really correct? It seems to me that a thermally insulating boundary does not prevent entropy or energy "coming in" from somewhere else: it only prevents heat flow across the boundary.
Rap said:
When entropy is conserved, i.e. when a process is reversible, the concept of entropy moving is just as valid as the concept of conserved energy moving, and is therefore very helpful. If you can identify the location at which entropy is created (e.g. at the thermally open boundary between two systems with a finite temperature difference), and identify into which system the created entropy is deposited, then I see no conceptual problem with [STRIKE]Dirac123[/STRIKE]'s [Darwin123] statement resulting from the non-conservation of entropy. Not yet being totally certain of this concept, I would be interested in any specific process you can think of where this concept is inappropriate.
It is not necessarily inappropriate and it may be a helpful concept when analysing reversible processes in which entropy does not change.
But I think that, overall, the concept of entropy "moving" just adds to confusion about an already very difficult concept. It gives the impression that entropy is a physical quantity. Entropy is a statistical. It is a bit like temperature in that respect. We would not say that temperature moves between bodies or is lost or created.
We do say that Q (= mass x temperature x heat capacity) moves or is lost or created (heat flow) but we relate it to U and W, which together are always conserved. You can't do that with entropy.
AM
It is not necessarily inappropriate and it may be a helpful concept when analysing reversible processes in which entropy does not change. AM
I think it is correct: dQ=TdS means the flow of heat energy into a boundary is the temperature of the "in" side of the boundary times the entropy flow into the boundary. The flow of heat energy out of a boundary is temperature of the "out" side of the boundary times the entropy flow out of the boundary. No heat flow (dQ=0) means no entropy flow (dS=0) and vice versa. Energy into the boundary equals energy out, so if the temperatures are different, entropy in does not equal entropy out - entropy is being created at the boundary and deposited in the low temperature system.
AM
Temperature is also statistical, but it is an intensive quantity, not extensive. The concepts of "conserved" and "created" and "destroyed" do not apply to intensive quantities like temperature, pressure, chemical potential. They do apply to extensive quantities. For a simple system undergoing a reversible process,
1. Volume is conserved in a mechanically isolated system and volume changes are driven by pressure differences alone.
2. Particle number is conserved in a materially isolated system and particle number changes are driven by chemical potential differences alone.
3. Similarly, entropy is conserved in a thermally isolated system, entropy flows are driven by temperature differences alone.
If X is intensive, then differences in X drive changes in an extensive Y, where X and Y are conjugate variables. T and S, P and V, µ and N, are conjugate variables. The product of X and dY has units of energy and the fundamental law states that the sum of all those products is a conserved, extensive internal energy dU=TdS-PdV+µdN. (No worry about the sign of PdV)
If you relax the above constraints on the systems, conservation becomes more problematical. Volume is still always conserved in a mechanically isolated system. For a homogeneous system in which there may be chemical reactions, particle number is not conserved in a materially isolated system (although conservation of "component particles" is). Similarly, in an irreversible process, entropy is not conserved, it is created, in a thermally isolated system.
I think the simple fact that entropy is extensive implies that the concept of entropy flow, entropy creation at particular locations, entropy density, etc. is viable. I don't think it adds confusion, I think it brings insight and clarity to the concept of "classical entropy". If its true, I fully expect statistical mechanics to verify this, rather than muddying the waters.
This I disagree with, at least in the OP's scenario.
The OP said that the expansion is quasistatic. This means that the expansion is so slow, the ideal gas is in a state infinitesimally close to thermal equilibrium. This means that variation of temperature and pressure within the ideal gas are negligible. If there is a significant amount of entropy created, it is not from the temperature differences in the gas.
Similarly, there can't be any coherent sound energy. The gas can't "squeak". A coherent sound wave would imply that the macroscopic pressure and the macroscopic temperature were inhomogeneous.
The only thing that we can be sure of from his description is that the expansion is adiabatic. Otherwise, work won't entirely come from the internal energy of the gas. Therefore, I presume that the container of ideal gas is comprised of a piston and cylinder made of some thermal insulator with zero heat capacity. The pressure outside the container doesn't really matter. It could be zero.
In the OP's scenario, there could be friction between the piston surface and the cylinder surface that contains the gas. Because of heat conduction from surface to gas, the "heat energy" created by the friction goes right back into the ideal gas. Because the expansion is adiabatic, neither entropy nor heat energy can be conducted out of the container. Therefore, work done by the friction can't affect the internal energy of the ideal gas.
In the simplest case that I can imagine, the friction is a combination of sliding friction and static friction. Simple formulas for sliding friction and static friction are taught in introductory physics classes. Although real friction is more complicated, I think this approximation is good enough as an illustration.
I intend to show a calculation for this situation, where all entropy created comes from sliding fiction. In this example, there will be no aerodynamic friction or temperature differences in the ideal gas. The expansion will be adiabatic and quasistatic, but not reversible.
I guess I don't know which point you disagree with in the quote, but I will try to make the same calculation. A quasistatic expansion of a gas in a thermally and materially isolated system, but mechanically open, with sliding friction. Specifically a cylinder with one circular end (the piston) a movable boundary. I'm guessing the force of friction can be considered constant and opposing the motion of the piston. So the heat energy created by friction is K F x where K is a constant, F is the friction force and x is the distance moved. If the force of the gas on the piston is ever less than F, the piston stops. I will try to do that calculation.
The dQ is the reversible heat flow, not the actual heat flow.
If the reversible heat flow, dQrev = 0, dS = 0. But for an irreversible adiabatic process ΔS>0.
Entropy is conserved only if all processes within the thermally isolated system are reversible.
AM
Yes, and looking at what I said, I failed to specify that the process needed to be quasistatic. Then there is no entropy created in the hot body as a result of energy flowing from the hot body into the boundary. Likewise, there is no entropy created in the cold body as a result of energy flowing out of the boundary into the cold body. In other words, both bodies' equilibria are not disturbed by the energy flow across the boundary. Their state parameters may change, but the state parameters stay homogeneous in both bodies.
There is no entropy creation inside either body, yet the drop in entropy of the hot body is less than the increase of entropy of the cold body as a result of the entropy transfer, so the process is irreversible. Entropy is created in or at the boundary.
If the process were not quasistatic, there would be temperature gradients inside the bodies as well (rather than just at the boundary) and temperature gradients create entropy, so entropy would be created in the bodies themselves, not just at the boundary.
Right - I stated before I listed those 3 points "For a simple system undergoing a reversible process,"
I am just trying to understand what you are saying here. It appears that you saying that entropy is created as the result of a quasi-static heat flow. I don't follow this. The only way to make heat flow quasi-static is to have an infinitessimal temperature difference. If that is the case, ΔS = 0 so I don't see entropy being created anywhere. If there is entropy "created" at a boundary, it is not a quasi-static process.
Temperature gradients are not the only sources of increased entropy. Heat does not have to flow to create entropy eg. the mixing of two different gases.
AM
Help us out, here. Maybe you can find us a formal definition of the word "quasistatic".
I assumed that the word “quasistatic” used by the OP was the same as near-equilibrium. A later post by the OP confirmed that he was talking about a process which was the sum of a series of small processes where the state of the ideal gas was near equilibrium.
Entropy can be created even if a system is “near equilibrium” at each infinitesimal step. Maybe you are right in that there is a temperature gradient where the entropy is created. At the point of contact between two surfaces, the temperature gradient magnitude can be very large. However, the inverse of the temperature gradient may not be completely macroscopic. On the length scale determined by the dimensions of the container of gas, the inverse gradient is microscopic. On the length scale determined by the dimensions of a molecule, the inverse gradient is rather large.
Frictional forces do create entropy. Most of the container of gas in an adiabatic expansion can be near thermal equilibrium. The important thing about a system that is “near equilibrium” is that the intensive quantities will be uniform over most of the system. There may be a large temperature in a 1 cubic micron volume at the point of contact. However, the temperature of the ideal gas over most of the volume will be at a single value, T. Similarly, the pressure at the point of contact may be huge, resulting in a large stress at the point of contact. However, one can approximate the pressure over most of the system by a single value, P.
The following article addresses the issue of how friction is treated in a thermodynamic analysis. Note that there was at least one investigator, Rymuza, who examined sliding friction in a near equilibrium process.
http://www.mdpi.com/1099-4300/12/5/1021
“On the Thermodynamics of Friction and Wear―A Review
Abstract: An extensive survey of the papers pertaining to the thermodynamic approach to tribosystems, particularly using the concept of entropy as a natural time base, is presented with a summary of the important contributions of leading researchers.
Friction is an energy transformation process. Using a near-equilibrium analysis, one can
demonstrate (see Section 4) how sliding energy is dissipated. Rymuza [31] considers friction as a process that transforms the external mechanical energy to the energy of internal processes. Rymuza proposes that the traditional ‘laws’ of friction is incapable of reflecting its energetic nature and suggests a new parameter called ‘coefficient of friction losses’ (CFL), so as to reflect both the dissipative nature of friction process and simultaneously provide a useful formulation for applicationin engineering practice.
As discussed in Sections 4 and 5, the temperature, and particularly temperature gradient within the mating bodies plays an important role in assessment of entropy generation in a tribosystem. Both theoretical and experimental methods have been developed for determination of temperature rise at the contact surface. Blok [69] is credited to be the first researcher who proposed a model for determination of the temperature rise at the surfaces of contacting bodies under boundary lubricated condition.”
The authors point out that the generation of entropy is caused by the large temperature gradient at the point of contact. However, the temperature gradient is caused by friction. The inhomogeneity in temperature is confined to “the point of contact”. I find it reasonable to assume that this is a “quasistatic” case.
Maybe if you find a formal definition of quasistatic, then I would be forced to agree with you. If quasistatic were formally defined by dS=0, then the OP and I are making a mistake. However, I didn’t know that quasistatic was defined so precisely.
Scientists established early that friction can generate caloric (another word for entropy). That famous cannon investigated by Count Rumford was probably an excellent example of a quasistatic system. The cannon bore was placed in water, so that the system was isothermal. The temperature of the cannon and the water it was immersed in was 100 degrees centigrade, and did not fluctuate enough for scientists to measure. Except at the point of contact, that cannon remained at the boiling point of water. Obviously, the temperature of the iron must have been much higher in the region near the point of contact. This contact temperature could not and probably cannot be measured by ordinary thermometry. However, it is enough to know that friction creates entropy.
“Carnot based his views of heat partially on the early 18th century "Newtonian hypothesis" that both heat and light were types of indestructible forms of matter, which are attracted and repelled by other matter, and partially on the contemporary views of Count Rumford who showed (1789) that heat could be created by friction as when cannon bores are machined.
In the 1850s and 1860s, German physicist Rudolf Clausius objected to this supposition, i.e. that no change occurs in the working body, and gave this "change" a mathematical interpretation by questioning the nature of the inherent loss of usable heat when work is done, e.g. heat produced by friction.”
The following link provides a free copy of the article. However, you have to request it.
This looks like a great article. I have never seen anyone handle the problem of friction in thermodynamics so thoroughly. I may have to read it carefully before I get back into the thread.
AM
All reversible processes are quasistatic but not vice versa. Reversible processes do not create entropy, quasistatic processes may or may not. Quasistatic processes are described by a continuum of equilibrium states. (A curve on a PV or TS diagram). The only way to make heat flow REVERSIBLE is to have an infinitesimal temperature difference, because entropy is not created. I'm calling the process quasistatic because it is so slow that the two systems are always in practical equilibrium, but irreversible because entropy is being created.
I sound like I know exactly what I am talking about, but I'm still trying to piece this together, so I am looking for cases that challenge this viewpoint that Darwin123 put forth, that the entropy of classical thermodynamics can be treated sort of like a fluid that is both transported and created at particular places, but never destroyed. Like entropy of mixing - there are no temperature or pressure gradients, only a chemical potential gradient, yet entropy is created. I guess entropy transport is driven by temperature differences, but entropy creation is not limited to a temperature gradient.
  • · Replies 17 ·
  • · Replies 26 ·
  • · Replies 22 ·
  • · Replies 16 ·
