How Do Projective and Affine Varieties Relate in P^n?
  • Context: Graduate
  • Thread starter Thread starter hlfmanhoffdor
The relationship between projective varieties and affine varieties in projective space P^n is established through the intersection with open sets U_i. According to Harris in his introductory book on algebraic geometry, a projective variety X is characterized by the property that X intersect U_i is an affine variety for each i=0,...,n. The discussion clarifies that if X is defined by homogeneous polynomials F_α(Z_0, ..., Z_n), then the affine representation f_α(z_1, ..., z_n) = F_α(1,z_1,...,z_n) allows for the identification of X intersect U_0 with its image in local coordinates. The zero locus of the constructed polynomials across all U_i ultimately yields the original projective variety X.
  • Understanding of projective varieties and affine varieties
  • Familiarity with homogeneous polynomials and their properties
  • Knowledge of algebraic geometry concepts, particularly in projective space
  • Proficiency in local coordinates and their applications in algebraic geometry
  • Study the definitions and properties of projective varieties in algebraic geometry
  • Learn about the construction and implications of homogeneous polynomials
  • Explore the concept of local coordinates in projective space P^n
  • Investigate the intersection properties of varieties in algebraic geometry
Students and researchers in algebraic geometry, mathematicians focusing on projective and affine varieties, and anyone seeking to deepen their understanding of the relationships between different types of varieties in projective space.
hlfmanhoffdor
I'm having a little trouble seeing something Harris says in his intro book on alg. geom. Say X is contained in P^n. Harris says that X is a projective variety iff X intersect U_i is an affine variety for each i=0,...,n, where U_i are the points [Z_0 , Z_1 , ... , Z_n] in P^n with Z_i =/ 0. I'm a little confused about how he claims this:
If X is a projective variety, say its the locus of the homogeneous polynomials F_α(Z_0, ..., Z_n). Say we define on A^n the polynomials f_α(z_1, ..., z_n) = F_α(1,z_1, ...,z_n) = F_α(Z_0, ..., Z_n) / Zd_0 where d is the degree of F_α and z_i are the local coords (z_i = Z_i/Z_0). Then he claims the zero locus of the f_α is X intersect U_0. Now since there's a bijection between U_0 and A^n, are we just identifying X intersect U_0 with its image via the local coordinates, meaning its an affine variety too?
For the other direction, I don't really see this. If for example X intersect U_0 is an affine variety, say its the locus of f_α(z_1, ..., z_n),then we can define homogeneous polynomials F_α(Z_0, ... Z_n) = Zd_0 f_α(Z_1/Z_0,..., Z_n/Z_0) where d = deg(f_α). But then is the zero locus of the F_α just X?
Any help would be appreciated!
Could you give the relevant page number in the book?
No, of course not. The entire set [itex]\mathbb{P}^n\setminus U_0[/itex] would also be in the zero locus of the [itex]F_\alpha[/itex] since it is easy to see that if [itex]Z_0=0[/itex], then [itex]F_\alpha(0,Z_1,...,Z_n)=0[/itex].
So you obtain [itex]X\cup (\mathbb{P}^n\setminus U_0)[/itex]. If you want to obtain just X, then you need to perform the same procedure on the [itex]U_1,...,U_n[/itex]. This will give you extra polynomials. The zero locus of everything will then be X.
Ooh, I see now! So the roots of the polynomial F_α are just (X intersect U_0) union (P^n \ U_0) = X union (P^n \U_0). Constructing similar polynomials for U_1, ..., U_n, we have that the zero locus for these polynomials is just the intersection of all the X union (P^n \U_i), which is just X. Cool! Thanks, that was helpful. (This was on page 5 in his book).
  • · Replies 17 ·
  • Poll Poll
  • · Replies 102 ·
12K
  • · Replies 175 ·
29K
