Does Euler's Proof of Pi's Irrationality Meet Modern Rigor Standards?
  • Thread starter Thread starter chaoky
    Pi Proof
Lambert's proof of π's irrationality, established in 1761, is recognized for its complexity and the introduction of a continued fraction for the tangent function. Euler's simpler derivation, presented in 1780, also utilizes a continued fraction based on Lagrange's work, yet raises questions about its adherence to modern rigor standards. The discussion centers on whether Euler's methods require further justification compared to Lambert's more detailed approach. Despite Euler's later date of publication, his manipulation of the continued fraction prompts scrutiny regarding its mathematical validity. Ultimately, the conversation highlights the need for a critical evaluation of historical proofs in light of contemporary standards.
chaoky
I was wondering about Lambert's proof of π's irrationality. Supposedly he was the first one to prove it in 1761 when he derived a continued fraction for the tangent function. Then I was reading through some of Euler's translated papers when I stumbled upon the same continued fraction in Euler's E750 paper (Commentatio in fractionem continuam, qua illustris La Grange potestates binomiales expressit) (English translation http://arxiv.org/abs/math/0507459). This was delivered to the St. Petersburg Academy of sciences in 1780 and Euler's derivation seems to be much simpler (based on Lagrange's binomial continued fraction) although Lambert's proof is more widely known (and a bit more involved). Do Euler's manipulation of the original continued fraction follow the modern standards of rigor? Or is there more justification needed when Euler was toying around with the fraction?
Mathematics news on Phys.org
Isn't 1780 later than 1761?
AD yes, BC no.
Well, yes, although Lambert's proof is much more involved. Are there any additional justifications to Euler's manipulation of Lagrage's fraction that are needed?
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
