Saddle Point at (0,0): f(x,y)=x^2+y^3
  • Thread starter Thread starter cambo86
The discussion revolves around determining whether the function f(x,y) = x^2 + y^3 has a saddle point at the critical point (0,0). Participants are exploring the characteristics of saddle points and the implications of the function's shape.
  • Conceptual clarification, Assumption checking, Mathematical reasoning
  • Participants discuss the nature of saddle points and whether the function's shape affects this classification. There are inquiries about the critical point and the application of the second derivative test, as well as considerations of the Hessian matrix and its implications.
The discussion is active, with participants providing insights into the definitions and conditions for saddle points. Some have offered guidance on using the second derivative test and the Hessian, while others are questioning the assumptions regarding the function's shape and its implications for the classification of the critical point.
There is a mention of the potential limitations of the second derivative test and the Hessian in determining the nature of the critical point, indicating that the function may not fit neatly into typical classifications.
cambo86
For [tex]f(x,y)=x^2+y^3[/tex]
Is there a saddle point at (0,0) or does the function have to have 2 or more sides going down like [tex]g(x,y)=x^2-y^2[/tex]
Okay so have you taken the required derivative and found your critical points?
The critical point is (0,0). I'm just wondering if f(0,0) is a saddle point when the graph is shaped more like a chair than a saddle.
The exact shape doesn't matter. A saddle point is a stationary point that isn't a local max or min. Is yours?
Are you familiar with the second derivative test? As in where you check :
[itex]D = f_{xx}f_{yy} - f_{xy}^{2}[/itex]
This will allow you to see if your function has a saddle, min or max at a critical point ( Doesn't alwayyyyys work though ).
Yes, thank you.
The Hessian test fails in this case. If H is the Hessian evaluated at the stationary point, the exact second-order conditions are: (i) a necessary condition for a minimum is that H is positive semi-definite; and (ii) a sufficient condition for a strict local minimum is that H is positive definite. For testing a max, just test -H for a min of -f (or replace positive (semi) definite by negative (semi) definite).
Note that there is a bit of mismatch between the necessary and sufficient second-order conditions: there is no sufficient condition for a non-strict local min, so functions like that of the OP slip through the cracks. This happens as well in one dimension, where testing functions like f(x) = x^3 for an optimum at x = 0 cannot just rely on the second derivative.
For the OP's function f(x,y), the Hessian at (0,0) is positive semi-definite, so (0,0) cannot be a local *maximum *; it must either be a local minimum or a saddle point. In fact, f(x,0) = x^2, so x = 0 is a minimum along the line (x,0), and f(0,y) = y^3, so y = 0 is an inflection point along the line (0,y). Thus, there are points near (0,0) giving f(x,y) > f(0,0) and other points near (0,0) giving f(x,y) < f(0,0); that is more-or-less what we mean by a 'saddle point'.
  • · Replies 27 ·
